MBR80200PT
http://www.osen.net.cn
Power Schottky Rectifier - 80Amp 200Volt
Features:
High switching frequency
开关频率高
Low forward voltage drop
正向压降低
High efficiency and low power loss
高效低功耗
High volume of current and good capability of surge current
大电流浪涌能力强
TO-247S
Applications
High frequency rectifier of switching mode power supplies
高频整流器开关电源
Freewheeling diodes
续流二极管
Polarity protection application
极性保护应用
DC-DC converters
直流-直流变换器
Publication Order Number:[MBR80200PT]
@OSEN*Rev 21.2.10
1
MBR80200PT
Absolute Maximum Ratings (Tc=25°C)
Symbol
VRRM
VRWM
VR
IF(AV)
IFSM
Tj
Tstg
Parameters
Ratings
Unit
200
V
200
V
最大直流反向电压
200
V
Maximum average forward rectified current Total device
最大正向平均电流
80
A
Peak Forward Surge Current
正向峰值浪涌电流
400
A
Operating junction temperature range
结温
175
-40~175
Repetitive Peak Reverse Voltage
最大反向重复峰值电压
Working peak reverse voltage
反向峰值工作电压
Maximum DC blocking voltage
Storage temperature range
贮存温度
Electrical characteristics
Symbol
Parameters
Min
Typical
Max
Units
1
uA
0.90
0.95
V
1.5
℃/W
10000
V/μs
Maximum Reverse Leakage
IR
Current (Note 1)
最大反向瞬态电流
Conditions
VR=VRRM
TC = 25 °C
Maximum Instantaneous Forward
VF
Voltage(Note 2)
IF= 30 A,TC = 25 °C
最大瞬态正向压降
Typical Thermal
Rth(j-c)
Resistance,Junction to Case
结到外壳的典型热阻
Voltage Rate of Change
dV/dt
电压变化率
Note 1: 2.0uS Pulse Width, f=1.0KHz
Note 2: Pulse Test : 300us Pulse Width, 1% Duty Cycle
@OSEN*Rev 21.2.10
2
很抱歉,暂时无法提供与“MBR80200PT”相匹配的价格&库存,您可以联系我们找货
