DYW
MIC5205
300mA Low Noise LDO Regulator
Features
Description
• Input Voltage Range: 2.5V to 20V
• Output Voltage Range:
• Adjustable Operation: 1.2V to 18V
• Fixed Operation: 1.8V, 2.5V, 3.0V, 3.3V, 5.0V
• Maximum output current: 300mA
• Very Low Dropout Voltage: 152mV at 300mA
• Ultra-Low Noise When Using External Bypass Cap
• Low Quiescent Current
• Output Voltage Accuracy: 2% over Line, Load and
Temperature
• Excellent Load and Line Transient Responses
• Thermal Shutdown and Over-Current Protection
• Stable with 1µ F or Larger Ceramic Capacitor
The device is an efficient linear voltage regulator with
300mA output current capability, very low dropout
voltage (typically 152mV at 300mA), and very low
ground current. The device offers better than 1% initial
accuracy.
Key features include a reference bypass pin to improve
its already excellent low-noise performance, overcurrent limiting, and over-temperature shutdown as well
as automatic discharge function to quickly discharge
VOUT in the disabled states.
• Operating Junction Temperature: -40C to +125C
• Available packages: SOT23-5
Applications
Cellular Phones
Laptop computers
Portable Equipment
Battery-Powered Systems
High-Efficiency Linear Power Supplies
Typical Application Circuits
VIN
IN
VOUT
OUT
VIN
IN
LDO
LDO
CIN
1µF
EN
GND
BYP
CBYP
10nF
COUT
2.2µF
CIN
1µF
GND
R1
ADJ
R2
COUT
2.2µF
Adjustable Output Voltage
Low Noise Fixed Output Voltage
鼎研微电子 (www.dymicro.com)
EN
VOUT
OUT
Company Confidential
Rev 1.0, Page 1
DYW
MIC5205
Pin Configuration and Functions
IN
1
GND
2
EN
3
5
OUT
4
ADJ/BYP
5-Pin SOT-23 (Top View)
Pin Descriptions
PIN Number
PIN Name
I/O
Function
1
IN
I
Input supply voltage pin. It is recommended to use a
1µF or larger ceramic capacitor from IN pin to ground
to get a good power supply decoupling.
2
GND
Ground.
3
EN
I
Enable Pin. Drive EN high to turn on the regulator.
Drive EN low to turn off the regulator.
4
ADJ/BYP
I
For adjustable voltage version this is feedback
voltage input pin. Connect this pin to the midpoint of
an external resistor divider to adjust the output
voltage. Place the resistors as close as possible to
this pin. For fixed voltage version this is reference
bypass pin. Connect an external 10nF capacitor from
this pin to ground can reduce the output to a very low
noise level. This pin can be left open if low noise at
the output is not required.
5
OUT
O
Regulator output voltage pin. A 2.2µF or larger
ceramic capacitor from OUT to ground is required to
ensure regulator stability. The capacitor should be
placed as close to the output as possible. Minimize
the impedance from the OUT pin to the load.
Ordering Information
DEVICE
PACKAGE TYPE
MARKING
OUTPUT VOLTAGE
PACKING OPTION
MIC5205-18YM5-TR
SOT23-5
KB18
1.8V
Tape and Reel, 3000
MIC5205-25YM5-TR
SOT23-5
KB25
2.5V
Tape and Reel, 3000
Rev 1.0, Page 2
DYW
MIC5205
MIC5205-30YM5-TR
SOT23-5
KB30
3.0V
Tape and Reel, 3000
MIC5205-33YM5-TR
SOT23-5
KB33
3.3V
Tape and Reel, 3000
MIC5205-50YM5-TR
SOT23-5
KB50
5.0V
Tape and Reel, 3000
MIC5205YM5-TR
SOT23-5
KBAA
ADJ
Tape and Reel, 3000
Rev 1.0, Page 3
DYW
MIC5205
Electrical Specifications
Absolute Maximum Ratings
Parameter
Symbol
IN, OUT and EN Pins
Value
Unit
IN, OUT and EN
−0.3 to 22
V
ADJ/BYP
-0.3 to +6
V
Storage temperature range
T STG
−65 to +150
C
Output current
I OUT
ADJ Pin
300
mA
Notes:
1. Exposure of the device under conditions beyond the limits specified by Maximum Ratings for extended periods may cause
permanent damage to the device and affect product reliability. These conditions represent a stress rating only, and functional
operations of the device at these or any other conditions above the operational limits noted in this specification is not imp lied.
ESD Ratings
Value
V ESD
Electrostatic Discharge
HBM (Human Body Model)
3000
CDM (Charge Device Model)
1000
Unit
V
Recommended Operation Conditions
Over operating temperature range unless otherwise noted
Parameter
Symbol
Min
Max
Unit
Input Supply Voltage
V IN
2.5
V
Enable Input Voltage
EN
V
Output Voltage
V OUT
1.2
18
V
Adjustable/Bypass Pin Voltage
ADJ/BYP
V
Output Capacitance
C OUT
1
220
µF
Output Current
I OUT
mA
TJ
-40
125
C
Thermal Information
Package
R θJA
Unit
SOT23-5
205
C/W
Rev 1.0, Page 4
DYW
MIC5205
Electrical Characteristics
V IN = 2.5V or V IN = V OUT + 1V (whichever is greater), I OUT = 1mA, COUT = 2.2µF, typical values are at
T A = 25°C unless otherwise noted
Rating
Parameter
Symbol
Input Voltage
V IN
Reference Voltage
V REF
Conditions
Min
Typ
Max
2.5
0.1mA ≤ I OUT ≤ 300mA
-2.0
Unit
V
V
2.0
V IN = 2.5V, No Load
80
µA
V IN = 2.5V, I OUT = 300mA
156
µA
I SHDN
V IN = 2.5V, V EN = 0V
2.3
µA
Dropout Voltage
V DO
V OUT = 3.3V, I OUT = 300mA
152
mV
Output Current Limit
I LIM
V OUT = 0
Line Regulation
ΔV OUT(ΔVIN)
V IN = V OUT +1V to 20V
Load Regulation
ΔV OUT(ΔIOUT)
V IN = 6V, I OUT = 1mA to 300mA
EN pin low-level input
voltage (device disabled)
V IL(EN)
EN pin high-level input
voltage (device enabled)
V IH(EN)
EN PIN Leakage Current
I EN
Power Supply Ripple
Rejection
PSRR
GND Pin Current
I GND
Shutdown Current
Output Noise Voltage
VN
300
mA
0.15
mV/V
5
mV/A
0.5
1.6
V
V
V EN = 20V
0.8
µA
f = 1kHz, V OUT = 5V, I OUT = 300mA
64
dB
f = 10kHz, V OUT = 1.8V, I OUT =
300mA
720
300mA, C BYP = 10nF
170
nV/ √𝐻𝑧
Thermal Shutdown
Temperature
TSD
160
C
Thermal Shutdown
Hysteresis
T HYS
C
Rev 1.0, Page 5
DYW
MIC5205
Typical Characteristics
CIN = 1µF, COUT = 2.2µF, IOUT = 300mA, T A = 25°C unless otherwise noted
Noise Sensity (nV/sqrt(Hz))
80
70
PSRR (dB)
60
50
40
30
100
1K
10K
100K
1M
1000
100
10
10
10M
100
1K
10K
100K
1M
Frequency (Hz)
Frequency (Hz)
V IN = 2.5V, V OUT = 1.8V, I OUT = 300mA, C OUT =
2.2 µF
Fig. 1 PSRR
Fig. 2 Output Noise Density
180
5.1
160
5.08
140
5.06
Output Voltage (V)
Dropout Voltage (V)
V IN = 6V, V OUT = 5V, I OUT = 300mA, C OUT = 2.2 µ F
120
100
80
60
40
5.02
5
4.98
4.96
4.94
4.92
100
150
200
250
300
-40
-20
60
80
100
Output Current (mA)
Temperature ( C)
V IN = 6V
V IN = 6V, V OUT = 5V, I OUT = 0.1mA
Fig. 3 Dropout Voltage
Fig. 4 Output Voltage vs Temperature
120
o
Rev 1.0, Page 6
DYW
MIC5205
140
180
Ground Pin Current (µA)
200
160
140
120
100
80
60
40
100
80
60
40
100
150
200
250
300
Load Current (mA)
2.5
5
7.5
10
12.5
15
17.5
Input Voltage (V)
V IN = 6V
V OUT = 1.2V, I OUT = 0.1mA
Fig. 5 Ground Current vs Load Current
Fig. 6 Ground Current vs Input Voltage
Rev 1.0, Page 7
DYW
MIC5205
Functional Block Diagram
VIN
VOUT
Internal
Regulator
Current
Limit
R1
Bias and
TSD
EN
BYPASS
R2
GND
Block Diagram of Fixed Output Voltage
VIN
VOUT
Internal
Regulator
Current
Limit
R
Bias and
TSD
ADJ
EN
EN
GND
Block Diagram of Adjustable Output Voltage
Rev 1.0, Page 8
DYW
MIC5205
Feature Description
Enable
The enable pin for the LDO is active high. The device is enabled when the enable pin voltage is
greater than V IH(EN) and disabled with the enable pin voltage less than V IL(EN) . If independent
control of chip enable is not needed, then connect the enable pin to the input. The LDO has an
internal pulldown MOSFET that connects a discharge resistor from VOUT to ground when the
device is disabled to actively discharge the output voltage.
When overload events happen, the output current is internally limited.
Undervoltage Lockout (UVLO)
The LDO uses an undervoltage lockout circuit to keep the output shut off until the internal
circuitry is operating properly.
Thermal Protection
The LDO contains a thermal shutdown protection circuit to turn off the output current when
excessive heat is dissipated in the LDO.
Rev 1.0, Page 9
DYW
MIC5205
Application Information
Typical Application for Fixed and Adjustable Output Voltage
VIN
IN
VOUT
OUT
VIN
IN
LDO
LDO
CIN
1µF
EN
GND
BYP
CBYP
10nF
COUT
2.2µF
CIN
1µF
EN
VOUT
OUT
GND
R1
ADJ
R2
COUT
2.2µF
Input Capacitor and Output Capacitor
The LDO is designed and characterized for operation with ceramic capacitors of 1 µ F or greater
at the input and 1 µ F or greater at the output. Locate the input and output capacitors as near as
practical to the input and output pins to minimize the trace inductance from the capacitor to the
device.
The output voltage of the LDO can be adjusted from 1.2V to 18V according to the following
equation.
𝑉𝑂𝑈𝑇 = 1.2𝑉 × (1 +
𝑅1
𝑅2
Rev 1.0, Page 10
DYW
MIC5205
PACKAGE OUTLINE DIMENSIONS
SOT23-5
Rev 1.0, Page 11
