LD1117DT33TR
LD1117DT33TR
    DYW(鼎研微电子)
    TO-252(DPAK)
    低压降电压调节器,能够提供高达1A的输出电流。固定版本提供以下输出电压:1.2V、1.8V、2.5V、3.3V和5.0V。采用TO-252封装。
LD1117DT33TR 数据手册
DYW LD1117 1A 20V Low Dropout Linear Regulator Features Description • • • • LD1117 is a high voltage, high PSRR and low dropout voltage linear regulator with much improved dropout voltage and quiescent current over conventional x1117 LDOs. The device provides fixed output voltage of 1.8V, 2.5V, 3.3V and 5V. • • • • • Very Low Dropout Voltage: 580mV at 1A Low Quiescent Current: 128µ A Typical Wide Input Voltage Range: 2.5V to 20V Output Voltage Range: • Fixed Operation: 1.8V, 2.5V, 3.3V, 5V Maximum output current: 1A Output Voltage Accuracy: 2% Fast Load and Line Transient Responses Thermal Shutdown and Over-Current Protection Stable with 2.2µ F or Larger Ceramic Capacitor The LD1117 also features over current limit and thermal shutdown protection, as well as automatic discharge function to quickly discharge VOUT in the disabled states. • Operating Junction Temperature: -40C to +125C • TO-252 Package Applications • • • • Post Regulator for Switching DC-DC Converter Battery Chargers Portable Equipment High-Efficiency Linear Regulators Typical Application Circuits VIN CIN 1µF IN OUT LD1117 GND VOUT COUT 2.2µF Fixed Output Voltage 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 1 DYW LD1117 Pin Configuration and Functions Fixed Output (Top View) 2 1 OUT GND 3 IN TO-252 Pin Descriptions PIN Number PIN Name I/O Function 1 GND - Ground. 2 OUT O Regulator output voltage pin. A 2.2µF or larger ceramic capacitor from OUT to ground is required to ensure regulator stability. The capacitor should be placed as close to the output as possible. Minimize the impedance from the OUT pin to the load. 3 IN I Input supply voltage pin. It is recommended to use a 1µF or larger ceramic capacitor from IN pin to ground to get a good power supply decoupling. Package/Ordering Information DEVICE PACKAGE TYPE LD1117DT18CTR TO-252 MARKING OUTPUT VOLTAGE L1117 1.8V 18 LD1117DT25CTR TO-252 L1117 2.5V 25 LD1117DT33CTR TO-252 L1117 3.3V 33 LD1117DT50CTR TO-252 L1117 50 鼎研微电子 (www.dymicro.com) Company Confidential 5.0V PACKING OPTION Tape and Reel, 1000 Tape and Reel, 1000 Tape and Reel, 1000 Tape and Reel, 1000 Rev 1.0, Page 2 DYW LD1117 Electrical Specifications Absolute Maximum Ratings Parameter Symbol IN and OUT Pins Value Unit IN and OUT −0.3 to 22 V Storage temperature range T STG −65 to +150 C Output current I OUT 1 A Notes: 1. Exposure of the device under conditions beyond the limits specified by Maximum Ratings for extended periods may cause permanent damage to the device and affect product reliability. These conditions represent a stress rating only, and functiona l operations of the device at these or any other conditions above the operational limits noted in this specification is not imp lied. ESD Ratings Value V ESD Electrostatic Discharge HBM (Human Body Model) 3000 CDM (Charge Device Model) 1000 Unit V Recommended Operation Conditions Over operating temperature range unless otherwise noted Parameter Symbol Min Max Unit Input Supply Voltage V IN 2.5 20 V Output Voltage V OUT 1.8 5 V Output Capacitance C OUT 2.2 47 µF Output Current I OUT 0 1 A Operating Junction Temperature TJ -40 125 C Thermal Information Package R θJA Unit TO-252 70 C/W 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 3 DYW LD1117 Electrical Characteristics V IN = 2.5V or V IN = V OUT + 1V (whichever is greater), I OUT = 1mA, COUT = 2.2µF, typical values are at T A = 25°C unless otherwise noted Parameter Input Voltage Symbol Test Conditions V IN Output Voltage Accuracy 0.1mA ≤ I OUT ≤ 1A Min Typ Max Unit 2.5 - 20 V -2.0 0 2.0 % V IN = 20V, No Load 128 µA V IN = 20V, I OUT = 1A 220 µA V DO V OUT = 3.3V, I OUT = 1A 580 mV Output Current Limit I LIM V OUT = 0 1.6 A Line Regulation ΔV OUT(LINE) 1 mV Load Regulation ΔV OUT /ΔI OUT 0.2 %/A EN pin low-level input voltage (device disabled) V IL(EN) EN pin high-level input voltage (device enabled) V IH(EN) EN PIN Leakage Current I EN Power Supply Ripple Rejection PSRR Thermal Shutdown Temperature Thermal Shutdown Hysteresis GND Pin Current I GND Dropout Voltage V IN = (V OUT + 1V) to 20V V IN = 6V, I OUT = 1mA to 1A 0.5 1.6 V V V EN = 20V 0.8 µA f = 1kHz, V OUT = 5V, I OUT = 1A 64 dB TSD 160 C T HYS 20 C 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 4 DYW LD1117 Typical Characteristics CIN = 1µF, COUT = 2.2µF, IOUT = 1A, T A = 25°C unless otherwise noted 700 70 600 Dropout Voltage (V) 80 PSRR (dB) 60 50 40 30 20 10 0 500 400 300 200 100 0 10 100 1K 10K 100K 1M 10M 0 100 200 Frequency (Hz) 300 400 500 600 700 900 1000 800 900 1000 Output Current (mA) V IN = 6V, V OUT = 5V, I OUT = 1A, C OUT = 2.2 µ F V IN = 6V Fig. 1 PSRR Fig. 2 Dropout Voltage 5.1 300 Ground Pin Current (µA) 5.08 Output Voltage (V) 800 5.06 5.04 5.02 5 4.98 4.96 4.94 4.92 4.9 250 200 150 100 50 0 -40 -20 0 20 40 60 80 100 120 0 o Temperature ( C) 100 200 300 400 500 600 700 Load Current (mA) V IN = 6V, I OUT = 0.1mA V IN = 20V Fig. 3 Output Voltage vs Temperature Fig. 4 Ground Current vs Load Current 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 5 DYW LD1117 Functional Block Diagram VIN VOUT Internal Regulator Current Limit R1 Bias and TSD R2 GND Block Diagram of Fixed Output Voltage Feature Description Dropout Voltage Dropout voltage is defined as the input voltage minus the output voltage at the rated output current where the pass transistor is fully on. The pass transistor is in the ohmic or triode region of operation and acts as a switch. LD1117 has a very low dropout voltage compared to most of the x1117 LDOs on the market. Output Current Limit and Short-Circuit Protection When overload events happen, the output current is internally limited to 1.6A. Undervoltage Lockout (UVLO) LD1117 uses an undervoltage lockout circuit to keep the output shut off until the internal circuitry is operating properly. Thermal Protection LD1117 contains a thermal shutdown protection circuit to turn off the output current when excessive heat is dissipated in the LDO. 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 6 DYW LD1117 PACKAGE OUTLINE DIMENSIONS TO-252 Dimensions (mm) Dimensions (mm) Symbol Symbol Min Max A 6.50 6.70 A1 0.64 0.74 Min Max C2 0.375 0.45 L 1.45 1.65 A2 2.286 TYP D1 3.166 REF A3 4.572 TYP E1 4.826 REF B 6.00 6.20 Θ1 0º ~ 8º B1 9.95 10.25 Θ2 10º TYP2 B2 1.06 1.16 Θ3 10º TYP C 2.15 2.35 Θ4 8.5º TYP4 C1 0.00 0.10 Θ5 70º TYP 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 7
LD1117DT33TR 价格&库存
很抱歉,暂时无法提供与“LD1117DT33TR”相匹配的价格&库存,您可以联系我们找货
LD1117DT33TR
库存:1000
