ADP7118AUJZ-3.3-R7
ADP7118AUJZ-3.3-R7
    DYW(鼎研微电子)
    SOT23-5
    这是一款CMOS、低压差(LDO)线性稳压器,采用2.5V至20V电源供电,最大输出电流为300mA,这款高输入电压LDO适用于调节20V至1.2V~5V供电的高性能模拟和混合信号电路。
ADP7118AUJZ-3.3-R7 数据手册
DYW ADP7118 300mA 20V High Voltage Low Noise Low Dropout LDO Features Description • Input Voltage Range: 2.5V to 20V • Output Voltage Range: • Adjustable Operation: 1.2V to 18V • Fixed Operation: 1.8V, 3.3V, and 5.0V • Maximum Output Current: 300mA • Low Dropout Voltage: 152mV at 300mA • Low noise: 45µ VRMS • Output Voltage Accuracy: 2% over Line, Load and Temperature • Low Quiescent Current: IGND = 69µ A • Fast Load and Line Transient Responses • Thermal Shutdown and Over-Current Protection • Stable with 1µ F or larger ceramic capacitors ADP7118 is a high voltage, high PSRR and low dropout voltage linear regulator capable of sourcing 300mA current. The output voltage can be adjusted from 1.2V to 18V by using external resistor divider for the adjustable version. The fixed version output voltage spans from 1.8V to 5.0V. The ADP7118 also features internal current limit and thermal shutdown protection, as well as automatic discharge function to quickly discharge VOUT in the disabled states. • Operating Junction Temperature: -40C to +125C • SOT23-5 Package Applications • • • • Regulation to Noise Sensitive Applications: ADC and DAC Circuits, Power for VCO Control Communications and Infrastructure Medical Devices Industrial and Instrumentation Typical Application Circuits VIN IN VOUT OUT VIN IN ADP7118 CIN 1µF EN GND ADP7118 BYP CBYP 0.01µF COUT 2.2µF CIN 1µF Fixed Output Voltage 鼎研微电子 (www.dymicro.com) EN VOUT OUT GND R1 ADJ R2 CFF (Opt) COUT 2.2µF Adjustable Output Voltage Company Confidential Rev 1.0, Page 1 DYW ADP7118 Pin Configuration and Functions IN 1 GND 2 EN 3 5 OUT 4 ADJ/BYP SOT23-5 (Top View) Pin Descriptions PIN Number PIN Name I/O Function 1 IN I Input supply voltage pin. It is recommended to use a 1uF or larger ceramic capacitor from IN pin to ground to get a good power supply decoupling. 2 GND - Ground. 3 EN I Enable Pin. Drive EN high to turn on the regulator. Drive EN low to turn off the regulator. 4 ADJ/BYP I For adjustable voltage version this is feedback voltage input pin. Connect this pin to the midpoint of an external resistor divider to adjust the output voltage. Place the resistors as close as possible to this pin. For fixed voltage version this is reference bypass pin. Connect an external capacitor to this pin can reduce the output to low noise level. 5 OUT O Regulator output voltage pin. A 1µF or larger ceramic capacitor from OUT to ground is required to ensure regulator stability. The capacitor should be placed as close to the output as possible. Minimize the impedance from the OUT pin to the load. Package/Ordering Information DEVICE PACKAGE TYPE OUTPUT VOLTAGE PACKING OPTION ADP7118AUJZ-1.8-R7 SOT23-5 1.8V Tape and Reel, 3000 ADP7118AUJZ-3.3-R7 SOT23-5 3.3V Tape and Reel, 3000 ADP7118AUJZ-5.0-R7 SOT23-5 5.0V Tape and Reel, 3000 ADP7118AUJZ-R7 SOT23-5 ADJ Tape and Reel, 3000 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 2 DYW ADP7118 Electrical Specifications Absolute Maximum Ratings Parameter Symbol IN, OUT and EN Pins Value Unit IN, OUT and EN -0.3 to 22 V ADJ/BYP -0.3 to +6 V Storage temperature range T STG -65 to +150 C Output current I OUT 300 mA ADJ Pin Notes: 1. Exposure of the device under conditions beyond the limits specified by Maximum Ratings for extended periods may cause permanent damage to the device and affect product reliability. These conditions represent a stress rating only, and functiona l operations of the device at these or any other conditions above the operational limits noted in this specification is not imp lied. ESD Ratings Value V ESD Electrostatic Discharge HBM (Human Body Model) 3000 CDM (Charge Device Model) 1000 Unit V Recommended Operation Conditions Over operating temperature range unless otherwise noted Parameter Symbol Min Max Unit Input Supply Voltage V IN 2.5 20 V Enable Input Voltage EN 0 20 V Output Voltage V OUT 1.2 18 V Adjustable/Bypass Pin Voltage ADJ/BYP 0 5 V Output Capacitance C OUT 1 47 µF Output Current I OUT 0 300 mA Operating Junction Temperature TJ -40 125 C Thermal Information Package R θJA Unit SOT23-5 195 C/W 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 3 DYW ADP7118 Electrical Characteristics V IN = 2.5V or V IN = V OUT + 1V (whichever is greater), I OUT = 1mA, COUT = 2.2µF, typical values are at T A = 25°C unless otherwise noted Parameter Symbol Input Voltage V IN Reference Voltage V REF Output Voltage Accuracy Test Conditions Min Typ Max Unit 2.5 - 20 V 1.2 0.1mA ≤ I OUT ≤ 300mA -2.0 V 0 2.0 % V IN = 2.5V, No Load 69 µA V IN = 2.5V, I OUT = 300mA 128 µA I SHDN V IN = 2.5V, V EN = 0V 2.3 µA Dropout Voltage V DO V OUT = 3.3V, I OUT = 300mA 152 mV Output Current Limit I LIM V OUT = 90%V OUT(NOM) 600 mA Line Regulation ΔV OUT(Line) V IN = V OUT +1V to 20V 0.05 mV/V Load Regulation ΔV OUT /(V OUT Δ/I OUT ) V IN = 6V, I OUT = 1mA to 300mA 0.8 %/A EN pin low-level input voltage (device disabled) V IL(EN) EN pin high-level input voltage (device enabled) V IH(EN) EN PIN Leakage Current I EN Power Supply Ripple Rejection PSRR Output Noise Voltage VN Thermal Shutdown Temperature Thermal Shutdown Hysteresis GND Pin Current I GND Shutdown Current 0.5 1.6 V V V EN = 20V 0.8 µA f = 1kHz, V OUT = 3.3V, I OUT = 300mA 76 dB BW = 100Hz to 100kHz, C BYP = 10nF, C OUT = 2.2µF, V OUT = 1.8V, I OUT = 300mA 45 µV RMS TSD 160 C T HYS 20 C 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 4 DYW ADP7118 Typical Characteristics 90 5.1 80 5.08 70 5.06 Output Voltage (V) PSRR (dB) CIN = 1µF, COUT = 2.2µF, IOUT = 300mA, T A = 25°C unless otherwise noted 60 50 40 30 20 10 5.04 5.02 5 4.98 4.96 4.94 4.92 0 4.9 10 100 1K 10K 100K 1M 10M -40 -20 0 20 40 60 80 100 Frequency (Hz) Temperature ( C) V IN = 5V, V OUT = 3.3V, I OUT = 300mA, C OUT = 2.2 µ F V IN = 6V, V OUT = 5V, I OUT = 0.1mA Fig. 1 PSRR Fig. 2 Output Voltage vs Temperature 160 Ground Pin Current (µA) 180 160 Dropout Voltage (V) 120 o 140 120 100 80 60 40 20 0 140 120 100 80 60 40 20 0 0 50 100 150 200 250 300 0 Output Current (mA) 50 100 150 200 250 Load Current (mA) V IN = 6V V OUT = 1.2V, I OUT = 0.1mA Fig. 3 Dropout Voltage Fig. 4 Ground Current vs Load Current 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 5 300 DYW ADP7118 Functional Block Diagram VIN VOUT Internal Regulator Current Limit R1 Bias and TSD EN BYPASS R2 GND Block Diagram of Fixed Output Voltage VIN VOUT Internal Regulator Current Limit R Bias and TSD ADJ EN EN GND Block Diagram of Adjustable Output Voltage 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 6 DYW ADP7118 Feature Description Enable The enable pin for ADP7118 is active high. The device is enabled when the enable pin voltage is greater than V IH(EN) and disabled with the enable pin voltage less than V IL(EN) . If independent control of chip enable is not needed, then connect the enable pin to the input. The ADP7118 has an internal pulldown MOSFET that connects a discharge resistor from V OUT to ground when the device is disabled to actively discharge the output voltage. Output Current Limit and Short-Circuit Protection When overload events happen, the output current is internally limited. Undervoltage Lockout (UVLO) ADP7118 uses an undervoltage lockout circuit to keep the output shut off until the internal circuitry is operating properly. Thermal Protection ADP7118 contains a thermal shutdown protection circuit to turn off the output current when excessive heat is dissipated in the LDO. 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 7 DYW ADP7118 Application Information Typical Application for Fixed and Adjustable Output Voltage VIN IN VIN VOUT OUT IN ADP7118 CIN 1µF EN GND ADP7118 BYP CBYP 0.01µF COUT 2.2µF CIN 1µF EN VOUT OUT GND R1 CFF (Opt) ADJ R2 Fixed Output Voltage COUT 2.2µF Adjustable Output Voltage Adjustable Output Voltage The output voltage of the ADP7118 can be adjusted from 1.2V to 18V according to the following equation. 𝑉𝑂𝑈𝑇 = 1.2𝑉 × (1 + 𝑅1 ) 𝑅2 Input Capacitor and Output Capacitor The ADP7118 is designed and characterized for operation with ceramic capacitors of 1 µ F or greater at the input and 1 µ F or greater at the output. Locate the input and output capacitors as near as practical to the input and output pins to minimize the trace inductance from the capacitor to the device. Feed Forward Capacitor A Feed-Forward Capacitor (C FF ) in parallel with the R1 resistor as shown in the Figure above can be used to improve the output noise and PSRR performance. This C FF is user optional for performance improvements not for LDO stability. 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 8 DYW ADP7118 PACKAGE OUTLINE DIMENSIONS SOT23-5 Dimensions (mm) Symbol A Dimensions (mm) Symbol Min Max 2.82 3.02 e 0.95 (BSC) Min Max C 1.05 1.15 C1 0.03 0.15 b 0.28 0.45 C2 0.12 0.23 B 1.50 1.70 L 0.35 0.55 B1 2.60 3.00 θ 0 8 鼎研微电子 (www.dymicro.com) Company Confidential Rev 1.0, Page 9
ADP7118AUJZ-3.3-R7 价格&库存
很抱歉,暂时无法提供与“ADP7118AUJZ-3.3-R7”相匹配的价格&库存,您可以联系我们找货
