DYW
TLV700
300mA Low IQ Small-Size Low-Dropout Regulator
Features
Description
• Input Voltage Range: 2.5V to 6.5V
• Output Voltage Range:
• Fixed Operation: 1.2V, 1.8V, 2.5V, 3.0V, 3.3V
• Maximum output current: 300mA
• Low Dropout Voltage: 152mV at 300mA
• Output Voltage Accuracy: 2%
• Low Quiescent Current
• Excellent Load and Line Transient Responses
• Thermal Shutdown and Over-Current Protection
• Stable with 1µ F or Larger Ceramic Capacitor
The device is an ultra-small, low quiescent current, lowdropout regulator that sources 300mA with fast line and
load transient performance. The output voltage is fixed
and spans from 1.2V to 3.3V.
The device also features short-circuit current limit and
thermal shutdown protection, as well as automatic
discharge function to quickly discharge VOUT in the
disabled states.
• Operating Junction Temperature: -40C to +125C
• Available package: SOT23-5
Applications
Set-Top Boxes, TV, and Gaming Consoles
Portable and Battery-Powered Equipment
Desktops, Notebooks, and Ultrabooks
Tablets and Remote Controls
White Goods and Appliances
Grid Infrastructure and Protection Relays
Camera Modules and Image Sensors
Typical Application Circuits
VIN
IN
OUT
VOUT
LDO
CIN
1µF
鼎研微电子 (www.dymicro.com)
EN
GND
NC/BYP
Company Confidential
COUT
2.2µF
Rev 1.0, Page 1
DYW
TLV700
Pin Configuration and Functions
IN
1
GND
2
EN
3
5
OUT
4
NC/BYP
5-Pin SOT-23 (Top View)
Pin Descriptions
PIN Number
PIN Name
I/O
Function
1
IN
I
Input supply voltage pin. It is recommended to use a
1µF or larger ceramic capacitor from IN pin to ground to
get a good power supply decoupling.
2
GND
Ground.
3
EN
I
Enable Pin. Drive EN high to turn on the regulator. Drive
EN low to turn off the regulator.
4
NC/BYP
Do not connect (NC) or Connect a 10nF to ground to
reduce output noise (BYP).
5
OUT
O
Regulator output voltage pin. A 2.2µF or larger ceramic
capacitor from OUT to ground is required to ensure
regulator stability.
Package/Ordering Information
DEVICE
PACKAGE TYPE
MARKING
OUTPUT VOLTAGE
PACKING OPTION
TLV70012DDCR
SOT23-5
ODO
1.2V
Tape and Reel, 3000
TLV70018DDCR
SOT23-5
ODK
1.8V
Tape and Reel, 3000
TLV70025DDCR
SOT23-5
DAU
2.5V
Tape and Reel, 3000
TLV70030DDCR
SOT23-5
ODM
3.0V
Tape and Reel, 3000
TLV70033DDCR
SOT23-5
ODN
3.3V
Tape and Reel, 3000
Rev 1.0, Page 2
DYW
TLV700
Electrical Specifications
Absolute Maximum Ratings
Parameter
Symbol
IN, OUT and EN Pins
Value
Unit
IN, OUT and EN
−0.3 to 7
V
Storage temperature range
T STG
−65 to +150
C
Output current
I OUT
300
mA
Notes:
1. Exposure of the device under conditions beyond the limits specified by Maximum Ratings for extended periods may cause
permanent damage to the device and affect product reliability. These conditions represent a stress rating only, and functiona l
operations of the device at these or any other conditions above the operational limits noted in this specification is not imp lied.
ESD Ratings
Value
V ESD
Electrostatic Discharge
HBM (Human Body Model)
3000
CDM (Charge Device Model)
1000
Unit
V
Recommended Operation Conditions
Over operating temperature range unless otherwise noted
Parameter
Symbol
Min
Max
Unit
Input Supply Voltage
V IN
2.5
6.5
V
Enable Input Voltage
EN
V IN
V
Output Voltage
V OUT
1.2
5.0
V
Output Capacitance
C OUT
1
47
µF
Output Current
I OUT
mA
TJ
-40
125
C
Thermal Information
Package
R θJA
Unit
SOT23-5
195
C/W
Rev 1.0, Page 3
DYW
TLV700
Electrical Characteristics
V IN = 2.5V or V IN = V OUT + 1V (whichever is greater), I OUT = 1mA, COUT = 2.2µF, typical values are at
T A = 25°C unless otherwise noted
Parameter
Input Voltage
Symbol
Test Conditions
V IN
0.1mA ≤ I OUT ≤ 300mA
Min
Typ
Max
Unit
2.5
6.5
V
-2.0
V IN = 2.5V, No Load
69
µA
V IN = 2.5V, I OUT = 300mA
128
µA
I SHDN
V IN = 2.5V, V EN = 0V
2.3
µA
Dropout Voltage
V DO
V OUT = 3.3V, I OUT = 300mA
152
mV
Output Current Limit
I LIM
V OUT = 0V
Line Regulation
ΔV OUT(LINE)
Load Regulation
ΔV OUT
/(V OUT ΔI OUT )
EN pin low-level input
voltage (device disabled)
V IL(EN)
EN pin high-level input
voltage (device enabled)
V IH(EN)
EN PIN Leakage Current
I EN
Power Supply Ripple
Rejection
PSRR
Thermal Shutdown
Temperature
Thermal Shutdown
Hysteresis
GND Pin Current
I GND
Shutdown Current
300
mA
V IN = V OUT +1V to 6.5V
0.15
mV/V
V IN = 6V, I OUT = 1mA to 300mA
0.3
%/A
0.5
1.6
V
V
V EN = 6.5V
0.8
µA
f = 1kHz, V OUT = 3.3V, I OUT = 300mA
64
dB
TSD
160
C
T HYS
C
Rev 1.0, Page 4
DYW
TLV700
Typical Characteristics
CIN = 1µF, COUT = 2.2µF, IOUT = 300mA, T A = 25°C unless otherwise noted
1.9
70
1.88
Output Voltage (V)
80
PSRR (dB)
60
50
40
30
1.86
1.84
1.82
1.8
1.78
1.76
1.74
1.72
10
100
1K
10K
100K
1M
10M
-40
-20
60
80
100
Frequency (Hz)
Temperature ( C)
V IN = 6V, V OUT = 3.3V, I OUT = 300mA, C OUT = 2.2 µ F
V IN = 6V, V OUT = 3.3V, I OUT = 0.1mA
Fig. 1 PSRR
Fig. 2 Output Voltage vs Temperature
180
Ground Pin Current (µA)
180
160
Dropout Voltage (V)
120
o
140
120
100
80
60
40
140
120
100
80
60
40
100
150
200
250
300
Output Current (mA)
50
100
150
200
250
Load Current (mA)
V IN = 6V
V IN = 2.5V
Fig. 3 Dropout Voltage
Fig. 4 Ground Current vs Load Current
300
Rev 1.0, Page 5
DYW
TLV700
Functional Block Diagram
VIN
VOUT
Internal
Regulator
Current
Limit
R1
Bias and
TSD
EN
R2
NC/BYP
GND
Feature Description
Enable
The enable pin for the LDO is active high. The device is enabled when the enable pin voltage is
greater than V IH(EN) and disabled with the enable pin voltage less than V IL(EN) . If independent
control of chip enable is not needed, then connect the enable pin to the input. The LDO has an
internal pulldown MOSFET that connects a discharge resistor from V OUT to ground when the
device is disabled to actively discharge the output voltage.
When overload events happen, the output current is internally limited.
Undervoltage Lockout (UVLO)
The LDO uses an undervoltage lockout circuit to keep the output shut off until the internal
circuitry is operating properly.
Thermal Protection
The LDO contains a thermal shutdown protection circuit to turn off the output current when
excessive heat is dissipated in the LDO.
Rev 1.0, Page 6
DYW
TLV700
PACKAGE OUTLINE DIMENSIONS
SOT23-5
Dimensions (mm)
Dimensions (mm)
Symbol
A
Symbol
Min
Max
2.82
3.02
e
0.95 (BSC)
Min
Max
C
1.05
1.15
C1
0.03
0.15
b
0.28
0.45
C2
0.12
0.23
B
1.50
1.70
L
0.35
0.55
B1
2.60
3.00
θ
Rev 1.0, Page 7
