MH282KSO
MH282KSO
    MST.(美伽)
    SOT-23
    MH282是一款单极霍尔效应传感器IC。它采用了先进的斩波稳定技术,以提供精确且稳定的磁开关点。
MH282KSO 数据手册
MH282 General Sensitivity Unipolar Hall Effect Switch MH282 is an unipolar Hall effect sensor IC. It incorporates advanced chopper stabilization technology to provide accurate and stable magnetic switch points. The design, specifications and performance have been optimized for applications of solid state switches. The output transistor will be switched on (BOP) in the presence of a sufficiently strong South pole magnetic field facing the marked side of the package. Similarly, the output will be switched off (BRP) in the presence of a weaker South field and remain off with “0” field. The package type is in a Halogen Free version was verified by third party organization. Halogen Free package is available by customer’s option. Features and Benefits ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ DMOS Hall IC Technology. Reverse bias protection on power supply pin. Solid-State Reliability. Chopper stabilized amplifier stage. Unipolar, output switches with absolute value of South pole from magnet. Operation down to 2.5V. High Sensitivity for direct reed switch replacement applications. 100% tested at 125℃ for K Spec. Custom sensitivity / Temperature selection are available. Good ESD Protection. RoHS compliant 2011/65/EU and Halogen Free Applications ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ 073119 Solid state switch. Limit switch. Current limit. Interrupter. Current sensing Magnet proximity sensor for reed switch replacement. Page 1 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch Ordering Information Company Name and Product Category MH:MST Hall Effect/MP:MST Power IC Part number 181,182,183,184,185,248,249,276,477,381,381F,381R,382….. If part # is just 3 digits, the forth digit will be omitted. Temperature range E: 85 ℃, I: 105 ℃, K: 125 ℃, L: 150 ℃ Package type UA:TO-92S,VK:TO-92S(4pin),VF:TO-92S(5pin),SO:SOT-23, SQ:QFN-3,ST:TSOT-23,SN:SOT-553,SF:SOT-89(5pin), SS:TSOT-26,SD:DFN-6 Sorting α,β,Blank….. Part No. MH282KUA MH282KSO MH282EUA MH282ESO Temperature Suffix K (-40℃ to + 125℃) K (-40℃ to + 125℃) E (-40℃ to + 85℃) E (-40℃ to + 85℃) Package Type UA (TO-92S) SO (SOT-23) UA (TO-92S) SO (SOT-23) KUA spec is using in industrial and automotive application. Special Hot Testing is utilized. Functional Diagram VDD Out Voltage Regulator Amp Hall Sensor GND 073119 Page 2 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch Absolute Maximum Ratings At (Ta=25℃) Characteristics Supply voltage,(VDD) Output Voltage,(Vout) Reverse Voltage , (VDD) Magnetic flux density Output current , (IOUT) “E” version “K” version Operating Temperature Range, (Ta) Storage temperature range, (Ts) Maximum Junction Temp,(Tj) (θja) UA / SO (θjc) UA / SO Thermal Resistance Package Power Dissipation, (PD) UA / SO Values 28 28 -28 Unlimited 50 -40 to +85 -40 to +125 -55 to +150 150 206 / 543 148 / 410 606 / 230 Unit V V V Gauss mA ℃ ℃ ℃ ℃ ℃/W ℃/W mW Note: Do not apply reverse voltage to VDD and VOUT Pin, It may be caused for Miss function or damaged device. Electrical Specifications DC Operating Parameters: TA=+25℃, VDD=12V Parameters Test Conditions Supply Voltage,(VDD) Supply Current,(IDD) Output Saturation Voltage, (Vsat) Output Leakage Current, (Ioff) Output Rise Time, (TR) Output Fall Time, (TF) Electro-Static Discharge Operating BBOP IOFF BBop [(110) ~ (70)] Low Open (Pull-up Voltage) Null or weak magnetic field -Brp ~ +Brp Open (Pull-up Voltage) Open (Pull-up Voltage) North pole B< -Bop (-70~-110) Open (Pull-up Voltage) Low South Pole OUT=Low OUT=Low (VDSon) (VDSon) UA package SO package 073119 Page 4 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch Performance Graph Typical Temperature(TA) Versus Flux Density 200.0 200.0 150.0 150.0 100.0 100.0 Flux Density(Gauss) Flux Density(Gauss) Typical Supply Voltage(VDD) Versus Flux Density 50.0 0.0 -50.0 BOP -100.0 BRP -150.0 50.0 0.0 -50.0 BOP -100.0 BRP -150.0 -200.0 -200.0 2.5 5 8 12 15 18 20 -40 24 -20 0 Typical Temperature(TA) Versus Supply Current(IDD) 4.5 4.0 4.0 Supply Current (mA) 5.0 4.5 Supply Current (mA) 3.5 3.0 2.5 2.0 1.5 2.5 2.0 1.5 1.0 0.5 0.0 50 75 100 0.0 125 2.5 5 Temperature(℃) 12 15 18 20 24 Typical Temperature(TA) Versus Output Voltage(VDSON) 400.0 400.0 350.0 350.0 Output Saturation Voltage (mV) Output Saturation Voltage (mV) 8 Supply Voltage(V) Typical Supply Voltage(VDD) Versus Output Voltage(VDSON) 300.0 250.0 200.0 150.0 100.0 50.0 0.0 300.0 250.0 200.0 150.0 100.0 50.0 0.0 2.5 5 8 12 15 18 20 24 -40 -20 0 25 50 75 100 125 Temperature(℃) Supply Voltage(V) 073119 125 3.0 0.5 25 100 3.5 1.0 0 75 Typical Supply Voltage(VDD) Versus Supply Current(IDD) 5.0 -20 50 Temperature(℃) Supply Voltage(V) -40 25 Page 5 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch Typical Supply Voltage(VDD) Versus Leakage Current(IOFF) Power Dissipation versus Temperature(TA) 700 1.00 Package power Dissipation(mW) 0.90 Output Leakage Current(uA) 0.80 0.70 0.60 0.50 0.40 0.30 0.20 0.10 UA Package 600 R θja = 206℃/w 500 400 300 200 SO Package 100 Rθja = 543℃/w 0 0.00 2.5 5 8 12 15 18 20 24 -40 0 40 80 120 160 Temperature(℃) Supply Voltage(V) Package Power Dissipation The power dissipation of the Package is a function of the pad size. This can vary from the minimum pad size for soldering to a pad size given for maximum power dissipation. Power dissipation for a surface mount device is determined by TJ(max), the maximum rated junction temperature of the die, RθJA, the thermal resistance from the device junction to ambient, and the operating temperature, Ta. Using the values provided on the data sheet for the Package, PD can be calculated as follows: PD = TJ(max) - Ta R j a The values for the equation are found in the maximum ratings table on the data sheet. Substituting these values into the equation for an ambient temperature Ta of 25°C, one can calculate the power dissipation of the device which in this case is 606 milliwatts. PD (UA) = 150C - 25C = 606mW 206C/ W The 206℃/W for the UA package assumes the use of the recommended footprint on a glass epoxy printed circuit board to achieve a power dissipation of 606 milliwatts. There are other alternatives to achieving higher power dissipation from the Package. Another alternative would be to use a ceramic substrate or an aluminum core board such as Thermal Clad. Using a board material such as Thermal Clad, an aluminum core board, the power dissipation can be doubled using the same footprint. 073119 Page 6 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch Sensor Location, Package Dimension and Marking UA Package Hall Chip location NOTES: 1).Controlling dimension: mm 2).Leads must be free of flash and plating voids 3).Do not bend leads within 1 mm of lead to package Output Pin Assignment (Top view) interface. 4).PINOUT: Pin 1 VCC Pin 2 GND Pin 3 Output SO Package Hall Plate Chip Location (Top View) (Bottom view) (For reference only)Land Pattern NOTES: 1. PINOUT (See Top View at left :) Pin 1 VCC Pin 2 Output Pin 3 GND 2. Controlling dimension: mm 3. Lead thickness after solder plating will be 0.254mm maximum 073119 Page 7 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch Sot-23 package Tape On Reel Dimension NOTES: 1. Material: Conductive polystyrene; 2. DIM in mm; 3. 10 sprocket hole pitch cumulative tolerance ±0.2; 4. Camber not to exceed 1mm in 100mm; 5. Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole; 6. (S.R. OHM/SQ) Means surface electric resistivity of the carrier tape. 073119 Page 8 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch IR reflow curve SO Soldering Condition UA Soldering Condition 073119 Page 9 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch Packing specification: Package Bag Box Carton Carton Carton TO-92S-3L 1,000pcs/Bag 10 Bags/Box 10 Boxes/Carton 5 Boxes/Carton 4 Boxes/Carton SOT-23-3L 3,000pcs/Reel 5 Reels/Box 6 Boxes/Carton 6 Boxes/Carton 6 Boxes/Carton TO-92S-3L Weight SOT-23-3L Weight 1000pcs/Bag 10 Bags/Box 10 Boxes/Carton 0.11kg 1.26kg 13.38kg 5 Boxes/Carton 4 Boxes/Carton 6.82kg 5.54kg 3000pcs/Reel 5 Reels/Box 6 Boxes/Carton 6 Boxes/Carton 6 Boxes/Carton 0.13kg 0.73kg 4.84kg 4.84kg 4.84kg SOT Package Inner box label:Size: 5cm*8cm SOT Carton label:Size: 6 cm * 9cm 073119 Page 10 of 11 Rev. 2.05 MH282 General Sensitivity Unipolar Hall Effect Switch UA Package Inner box label:Size: 5cm*8cm UA Carton label:Size: 6 cm * 9cm Combine: When combine lot, one reel could have two D/C and no more than two DC. One carton could have two devices, no more than two; 073119 Page 11 of 11 Rev. 2.05
MH282KSO 价格&库存
很抱歉,暂时无法提供与“MH282KSO”相匹配的价格&库存,您可以联系我们找货
