A2361WRA-2P
A2361WRA-2P
    CJT(长江连接器)
    弯插,P=10mm
    线对板针座 间距P=10.00mm 2Pin(1x2P) 弯插
A2361WRA-2P 数据手册
A2361 SERIES 10.00mm pitch wire to board connector Specifications Current rating:50A AC,DC Voltage rating:600V AC,DC Temperature range:-40°C~+105°C Contact resistance:10mΩMax. Insulation resistance:1000MΩMin. Withstanding voltage:5000V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-277 A2361 SERIES A2361WVA-XP-S 10.00mm pitch wire to board connector 10.00mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 46+30%GF,UL94V-0 *Color:Black B±0.25 A±0.10 A±0.20 5.73 4.40 10.00±0.10 10.00±0.10 0.36 ∅2.80±0.05 ∅3.00±0.05 P.C.B LAYOUT 21.00±0.25 18.70±0.20 5.50±0.20 16.00±0.20 3.00 12.50±0.20 Ordering Information & Dimensions: PART NO. 5.00 2P 3P 4P 5P 6P ∅2.40 2.00 Dimensions A B 10.00 30.30 20.00 40.30 30.00 50.30 60.30 40.00 50.00 70.30 Unit: mm A2361WRA-XP-S 10.00mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 46+30%GF,UL94V-0 *Color:Black B±0.25 A±0.10 A±0.20 5.73 5.00 10.00±0.10 ∅3.00±0.05 9.00 10.00±0.10 ∅2.80±0.05 P.C.B LAYOUT 3.85 ∅2.40 14.00±0.25 Ordering Information & Dimensions: 29.10 PART NO. 2.00 6.25 11.60 3.10 8.40 3.68 2P 3P 4P 5P 6P Dimensions A B 10.00 30.30 20.00 40.30 30.00 50.30 40.00 60.30 50.00 70.30 Unit: mm CHANGJIANG CONNECTORS TEL:+86-755-29959119 29959129 FAX:+86-755-29959139 Http://www.CJT.cn A-278
A2361WRA-2P 价格&库存
很抱歉,暂时无法提供与“A2361WRA-2P”相匹配的价格&库存,您可以联系我们找货
