Data Sheet | Item Number: 721-133/001-000
THT male header; 1.0 x 1.0 mm solder pin; straight; 100% protected against misma
ting; Pin spacing 5 mm; 3-pole; light gray
https://www.wago.com/721-133/001-000
Color:
light gray
Dimensions in mm
L = (pole no. – 1) x pin spacing + 8.2 mm
Horizontal or vertical PCB mounting via straight or angled solder pins
Pin cross-section: 1 x 1 mm
100 % protected against mismating
With coding fingers
Notes
Safety Information
The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capaci
ty in accordance with DIN EN 61984. When used as intended, these connectors must
not be connected/disconnected when live or under load.When used as intended, these
connectors must not be connected/disconnected when live or under load. The circuit
design should ensure header pins, which can be touched, are not live when unmated.
Variants:
Gold-plated or partially gold-plated contact surfaces
Other versions (or variants) can be requested from WAGO Sales or configured at https://
configurator.wago.com/.
Other pole numbers
3.8 mm pin projection for male headers with straight solder pins
Page 1/6
Version 15.07.2024
Continued on next page
Electrical data
Ratings per
IEC/EN 60664-1
Approvals per
Overvoltage category
III
III
II
Use group
Pollution degree
3
2
2
Nominal voltage
320 V
320 V
630 V
Rated surge voltage
4 kV
4 kV
4 kV
Rated current
12 A
12 A
12 A
UL 1059
B
C
D
Rated voltage
300 V
300 V
Rated current
10 A
10 A
Approvals per
UL 1977
Approvals per
Rated voltage
600 V
Use group
Rated current
10 A
CSA
B
C
D
Rated voltage
300 V
300 V
Rated current
10 A
10 A
Connection data
Total number of potentials
3
Connection 1
Number of connection types
1
Pole number
Number of levels
1
3
Physical data
Pin spacing
5 mm / 0.197 inches
Width
18.2 mm / 0.717 inches
Height
17 mm / 0.669 inches
Height from the surface
12 mm / 0.472 inches
Depth
11.4 mm / 0.449 inches
Solder pin length
5 mm
Solder pin dimensions
1 x 1 mm
Drilled hole diameter with tolerance
1.4 (+0.1) mm
Mechanical data
Variable coding
Yes
Anti-rotation protection
Yes
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Mating direction to the PCB
90 °
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire male connector (in-line)
Number of solder pins per potential
1
Page 2/6
Version 15.07.2024
Material data
Note (material data)
Information on material specifications can be found here
Color
light gray
Material group
I
Insulation material (main housing)
Polyamide (PA66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact Plating
Tin
Fire load
0.023 MJ
Weight
1.2 g
Environmental requirements
Limit temperature range
-60 … +100 °C
Processing temperature
-35 … +60 °C
Commercial data
Product Group
3 (Multi Conn. System)
eCl@ss 10.0
27-44-04-02
eCl@ss 9.0
27-44-04-02
ETIM 8.0
EC002637
ETIM 7.0
EC002637
PU (SPU)
200 pcs
Packaging type
Box
Country of origin
DE
GTIN
4044918868822
Customs tariff number
85366930000
Environmental Product Compliance
RoHS Compliance Status
Compliant,No Exemption
Approvals / Certificates
General approvals
Declarations of conformity and manufacturer's declarations
Approval
Standard
Certificate Name
Approval
Standard
Certificate Name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756/A1
Railway
WAGO GmbH & Co. KG
Railway Ready
CSA
C22.2
1466354
KEMA/KEUR
EN 61984
71-121453
UL
Underwriters Laboratories
Inc.
UL 1059
E45172
UR
Inc.
UL 1977
E45171
Page 3/6
Version 15.07.2024
Approvals for marine applications
Approval
Standard
Certificate Name
ABS
American Bureau of Ship
ping
19-HG1869876-PDA
BV
Bureau Veritas S.A.
IEC 60998
11915/D0 BV
DNV
DNV GL SE
TAE000016Z
Downloads
Compliance Search
Compliance
721-133/001-000
Documentation
Additional Information
Technical Section
03.04.2019
pdf
2027.26 KB
CAD/CAE-Data
CAD data
CAE data
2D/3D Models
721-133/001-000
EPLAN Data Portal
721-133/001-000
ZUKEN Portal
721-133/001-000
PCB Design
Symbol and Footprint
via SamacSys
721-133/001-000
via Ultra Librarian
721-133/001-000
Page 4/6
Version 15.07.2024
1 Compatible Products
1.1 System counterpart
1.1.1 Female connector/socket
Item No.: 722-103/026-000
1-conductor female connector, angled;
CAGE CLAMP®; 2.5 mm²; Pin spacing 5
mm; 3-pole; 100% protected against mis
mating; 2,50 mm²; light gray
Item No.: 722-203/026-000
Item No.: 721-303/031-000
mating; clamping collar; 2,50 mm²; light
gray
Item No.: 721-303/008-000
mating; Snap-in mounting feet; 2,50 mm²;
light gray
Item No.: 721-103/026-000
1-conductor female connector; CAGE
CLAMP®; 2.5 mm²; Pin spacing 5 mm; 3pole; 100% protected against mismating;
Item No.: 721-103/031-000
clamping collar; 2,50 mm²; light gray
Item No.: 721-103/037-000
Lateral locking levers; 2,50 mm²; light
gray
Item No.: 2721-1103/326-000
1-conductor female connector; lever; Pu
sh-in CAGE CLAMP®; 2.5 mm²; Pin spa
cing 5 mm; 3-pole; 100% protected
against mismating, coding finger; 2,50
mm²; light gray
Item No.: 2721-1103/037-000
against mismating, coding finger; Lateral
locking levers; 2,50 mm²; light gray
Item No.: 2721-103/026-000
1-conductor female connector; pushbutton; Push-in CAGE CLAMP®; 2.5 mm²;
Pin spacing 5 mm; 3-pole; 100% protec
ted against mismating; 2,50 mm²; light
gray
Item No.: 2721-103/031-000
ted against mismating; clamping collar;
Item No.: 2721-103/037-000
1-conductor female connector; push-but
ton; Push-in CAGE CLAMP®; 2.5 mm²; Pin
spacing 5 mm; 3-pole; 100% protected
against mismating; Lateral locking levers;
Item No.: 2721-103/026-000/133-000
against mismating; Strain relief plate; 2,50
mm²; light gray
Item No.: 721-2103/037-000
2-conductor female connector; Push-in
mating; Lateral locking levers; 2,50 mm²;
light gray
Item No.: 721-2103/026-000
mating; with integrated end plate; 2,50
mm²; light gray
1.2 Optional Accessories
1.2.1 Coding
1.2.1.1 Coding
Item No.: 231-129
Coding key; snap-on type; light gray
1.2.2 Marking
1.2.2.1 Marking strip
Item No.: 210-833
Marking strips; 25 m on roll; 6 mm wide;
plain; Self-adhesive; white
Item No.: 210-834
Marking strips; on reel; 5 mm wide; plain;
Page 5/6
Version 15.07.2024
Installation Notes
Coding
Coding a male header – fitting coding key
(s).
Subject to changes. Please also observe the further product documentation!
Current addresses can be found at:: w w w.wago.com
Page 6/6
Version 15.07.2024
很抱歉,暂时无法提供与“721-133/001-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.93370
- 200+2.64000
- 400+2.63890
- 国内价格
- 1+4.12560
- 10+3.34800
- 30+2.95920
- 200+2.57040
