SPH0641LM4H-1
SPH0641LM4H-1
    SYNTIANT
    是一款微型、高性能、低功耗、底部端口的硅数字麦克风,具有单比特PDM输出。采用高性能SiSonic™ MEMS技术,由声学传感器、低噪声输入缓冲器和sigma-delta调制器组成。适用于需要出色宽带...
SPH0641LM4H-1 数据手册
SPH0641LM4H-1 MORELLO MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE The SPH0641LM4H-1 is a miniature, high-performance, low power, bottom port silicon digital microphone with a single bit PDM output. Using Knowles’ proven high performance SiSonic™ MEMS technology, the SPH0641LM4H-1 consists of an acoustic sensor, a low noise input buffer, and a sigma-delta modulator. These devices are suitable for applications such as cellphones, smart phones, laptop computers, sensors, digital still cameras, portable music recorders, and other portable electronic devices where excellent wideband audio performance and RF immunity are required. In addition, the SPH0641LM4H-1 offers multiple performance modes. Charge Pump Control Buffer Σ∆ ADC Power Mode • Flat Frequency Response • High Drive Capability • Sensitivity Matching • Supports Dual Multiplexed Channels • Multiple Performance Modes (Sleep, SELECT CLK MEMS Transducer • High SNR • Low Current Consumption in Low- • RF Shielded • Bottom Port Vdd Regulator PRODUCT FEATURES DATA Low-Power, Normal) • Ultra-Stable Performance • Standard SMD Reflow GND ABSOLUTE MAXIMUM RATINGS • Omnidirectional • Small Size • LGA Package Parameter Absolute Maximum Rating Units TYPICAL APPLICATIONS • Portable Electronics • Cellphones • Laptop Computers • Tablets • Digital Still Cameras • Portable Music Recorders knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE ACOUSTIC & ELECTRICAL SPECIFICATIONS1 Parameter 2 Symbol Conditions Min Typ Max knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. Units MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE Parameter Symbol Conditions Min Typ Max Units Parameter Symbol Conditions Min Typ Max Units 3 knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE Parameter Symbol Conditions Min Typ Max Units Parameter Symbol Conditions Min Typ Max Units 4 knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE 1/Fclock MIC1 Vdd Vih Vdd Tedge CLOCK Tedge SEL Vil Rterm Vdd CLOCK GND DATA (SELECT = Vdd) Tdd Thold Voh SEL Tdv High Z Vdd Tdd Tdz PDM Mic Interface CLOCK DATA MIC2 Vdd High Z Mic (High) Data Vol DATA (SELECT = Ground) Rterm Tdz Tdv CODEC OR APPLICATION PROCESSOR DATA Rterm DATA GND CLOCK GND Thold Voh Mic (Low) Data Vol Vhyst High Microphone SELECT Asserts DATA on Latch DATA on Internal Logic Level Low Ext CLOCK Input Vh-l Vl-h Normal Mode 1.0 MHz ≤ Fclock ≤ 4.8 MHz 1.6V ≤ Vdd ≤ 3.6V Powered Down Mode Vdd = 0V Sleep Mode Fclock < 280 kHz 1.6V ≤ Vdd ≤ 3.6V 5 Low-Power Mode 351 kHz ≤ Fclock ≤ 815 kHz 1.6V ≤ Vdd ≤ 3.6V knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE PERFORMANCE CURVES 6 knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE 7 knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE MECHANICAL SPECIFICATIONS Item Dimension Example Land Pattern 8 Tolerance Pin # Pin Name Type Description Example Solder Stencil Pattern knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE PACKAGING & MARKING DETAIL Model Number 9 Suffix Reel Diameter Quantity Per Reel Component Surface Resistance (ohms) knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE RECOMMENDED REFLOW PROFILE TP tP Ramp-up TL TSMAX TSMIN tL tS Preheat Ramp-down 25°C Time 25°C to Peak Profile Feature 10 Time Pb-Free knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE MATERIALS STATEMENT RELIABILITY SPECIFICATIONS Test 11 Description knowles.com | DATASHEET SPH0641LM4H-1 Rev D © 2018, Knowles Electronics, LLC, Itasca, IL, USA, All Rights Reserved. SiSonic, Knowles and the logo are trademarks of Knowles Electronics, LLC. MULTIMODE DIGITAL BOTTOM PORT SISONIC™ MICROPHONE SPECIFICATION REVISIONS Revision 12 Specification Changes Knowles Corporation 1151 Maplewood Drive Itasca, Illinois 60143 Date Phone: 1 (630) 250-5100 Fax: 1 (630) 250-0575 sales@knowles.com Model/Reference Number: Datasheet SPH0641LM4H-1 Rev D © Copyright 2018 Knowles
SPH0641LM4H-1 价格&库存
很抱歉,暂时无法提供与“SPH0641LM4H-1”相匹配的价格&库存,您可以联系我们找货
SPH0641LM4H-1
  • 5900+4.795925900+0.59562
库存:6708
SPH0641LM4H-1
  • 1+10.870641+1.35005
  • 10+8.4957610+1.05510
  • 25+7.7247825+0.95936
  • 50+7.1947050+0.89352
  • 100+6.70702100+0.83296
  • 250+6.11943250+0.75998
  • 500+5.71510500+0.70977
库存:6708
