FT5-30-01.0-L-DV-TH-P-TR
    SAMTEC(申泰)
    SMD,P=0.5mm
    板对板连接器 SMT 针脚数:60Pin 间距:0.5mm 排数:2
FT5-30-01.0-L-DV-TH-P-TR 数据手册
REVISION F DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] FT5-XX-XX.X-X-DV-XX-X-TR C DO NOT SCALE FROM THIS PRINT 30 PACKAGING -TR: TAPE & REEL (SEE NOTES 3, 4 & 5) No OF POSITIONS -15, -30 (PER ROW) C "D" 0.50 .020 (TYP) LEAD STYLE ** -01.0: 1MM ** -03.0: 3MM *-06.0: 6MM *-08.0: 8MM *-10.0: 10MM 02 "A" 1.50 .059 REF 2.30 .091 REF 5.50 .217 REF OPTION -P: PICK AND PLACE PAD (USE PPP-71) (SEE FIG. 4, SHT 3) PLATING SPECIFICATION -L: LIGHT GOLD ON CONTACT AREA, MATTE TIN ON TAIL (USE T-1M84-XX.X-L) WELD TAB -TH: THRU HOLE (USE WT-63-XX.X-TH-X) *-SM: SURFACE MOUNT (USE WT-63-XX.X-SM-X) ROW SPECIFICATION -DV: DOUBLE VERTICAL "A" 29 POSITION 1 INDICATOR 01 (* = NOT TOOLED) ** = -P OPTION MANDATORY. NOT MANDATORY FOR EXISTING CUSTOMERS ONLY "A" REF "B" REF 0.90 .035 REF FT5-XX-XX.X-DV-X "J" REF WT-63-XX.X-TH-X 1.40 .055 0.20 .008 (TYP) (REF) NOTES: "B" 1. C REPRESENTS A CRITICAL DIMENSION. 2. PUSH OUT FORCE 1.80N [.40LBS]. 3. TAPE & REEL WILL BE SUPPLIED WHETHER OR NOT -TR IS SPECIFIED. 4. FOR QUANTITIES UP TO 49 PCS., NO LEADER, TRAILER OR EIA-481 REEL WILL BE SUPPLIED. 5. FOR QUANTITIES OF 50 TO 124 PCS., NO LEADER, TRAILER OR EIA-481 REEL WILL BE SUPPLIED. C 1.27 .050 REF "G" 2.60 .102 REF "B" C FIG 1 FT5-15-01.0-X-DV-TH-X-TR SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS[INCHES]. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 2 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, COLOR: BLACK CONTACT: PHOS BRONZE WT: PHOS BRONZE F:\DWG\MISC\MKTG\FT5-XX-XX.X-X-DV-XX-X-TR-MKT.SLDDRW SHEET SCALE: 6:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: FT5 TERMINAL ASSEMBLY DWG. NO. FT5-XX-XX.X-X-DV-XX-X-TR BY: R MUSSER 08/04/2009 SHEET 1 OF 3 REVISION F "E" REF 1.09 .043 REF 1.32 .052 REF CL 1.32 .052 REF 1.75 .069 REF CL 3.05 .120 REF 0.50 .020 (TYP) C "F" C SECTION "B"-"B" WT-63-XX.X-SM-X C 1.30±0.05 .051±.002 0.63 .025 REF T-1M84-XX.X-X 2.32 .091 REF 0.10[.004] C "K"±0.08[.003] C 0.10[.004] C (APPLIES TO WT'S AND SIGNAL PINS) C "H" FIG 2 -SM WELD TAB (FT5-15-03.0-X-DV-SM-X-TR SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (NOT TOOLED) 5.00 .197 SECTION "A"-"A" SCALE 10 : 1 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 6:1 F:\DWG\MISC\MKTG\FT5-XX-XX.X-X-DV-XX-X-TR-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: FT5 TERMINAL ASSEMBLY DWG. NO. FT5-XX-XX.X-X-DV-XX-X-TR BY: R MUSSER 08/04/2009 SHEET 2 OF 3 REVISION F C "B" REF 1.30±0.05 .051±.002 "C" 0.63 .025 FT5-XX-03.0-DV-X "J" REF C "K"±0.08[.003] TFHH-XX-XX.X-X 0.10[.004] WT-63-XX.X-TH-X C 1.27 .050 REF "C" SECTION "C"-"C" SCALE 6 : 1 "G" C FIG 3 -06.0 THRU -10.0 LEAD STYLES (FT5-15-06.0-X-DV-TH-X-TR SHOWN) (SAME AS FIG 1, EXCEPT AS SHOWN) (NOT TOOLED) C 5.00 .197 REF "D" 0.50±0.25 .020±.010 5.50 .217 REF 5.50 .217 REF PROPRIETARY NOTE "D" "L"±0.50[.020] C "A" REF FIG 4 PPP-71 "M" C SECTION "D"-"D" -P: PICK AND PLACE PAD (FT5-15-01.0-X-DV-TH-P-TR SHOWN) THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 6:1 F:\DWG\MISC\MKTG\FT5-XX-XX.X-X-DV-XX-X-TR-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: FT5 TERMINAL ASSEMBLY DWG. NO. FT5-XX-XX.X-X-DV-XX-X-TR BY: R MUSSER 08/04/2009 SHEET 3 OF 3
FT5-30-01.0-L-DV-TH-P-TR 价格&库存
很抱歉,暂时无法提供与“FT5-30-01.0-L-DV-TH-P-TR”相匹配的价格&库存,您可以联系我们找货
  • 575+30.15465575+3.75126
  • 1150+29.955261150+3.72646
库存:163
  • 1+55.612591+6.91825
  • 10+47.2504210+5.87799
  • 25+44.2902525+5.50974
  • 50+42.1735550+5.24642
  • 100+40.16008100+4.99595
  • 250+38.22013250+4.75462
库存:163
