ERM8-030-08.0-L-DV-TR
    SAMTEC(申泰)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:60Pin 间距:0.8mm 排数:2
ERM8-030-08.0-L-DV-TR 数据手册
RUGGED HIGH-SPEED STRIPS FEATURES & BENEFITS Edge Rate® rugged high-speed connector strips are designed for high-speed, high cycle applications, and enabled by Samtec's signal integrity-optimized Edge Rate® contact system. • Up to 1.5 mm contact wipe for a reliable connection • 20 to 200 positions • Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch • 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch • 0.635 mm pitch system with extremely slim 2.5 mm body width • Rugged latching, extended guide posts and 360° shielding Signal integrity-optimized Edge Rate® contact system reduces broadside coupling • Severe Environment Testing qualified (ERM8/ERF8); aligns with MIL-DTL-55302. Visit samtec.com/set EDGE RATE® STACK HEIGHT FLEXIBILITY (shown in mm) 5 7 8 ERM6/ ERF6 10 9 12 11 ERM5/ERF5 13 14 15 16 18 17 ERM8/ERF8 Rugged 360º shielding reduces EMI KEY SPECIFICATIONS SERIES PITCH ERM5 / ERF5 0.50 mm ERM6 / ERF6 0.635 mm ERM8 / ERF8 0.80 mm F-224 INSULATOR MATERIAL TERMINAL MATERIAL Phosphor Bronze or BeCu (ERM5), BeCu (ERF5) Black LCP Copper Alloy Phosphor Bronze or BeCu (ERM8), BeCu (ERF8) PLATING Au or Sn over 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE -55 °C to +125 °C CURRENT RATING VOLTAGE RATING 1.5 A 190 VAC 1.4 A 155 VAC 1.4 A 225 VAC LEAD-FREE SOLDERABLE Yes samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • RUGGED HIGH-SPEED HEADERS & SOCKETS TYPE - POSITIONS PER ROW –005, –010, –011, –013, –020, –025, –030, –035, –040, –049, –050, –060, –070, –075, –100 ERM8 = Header ERF8 = Socket - - LEAD STYLE - PLATING OPTION DV - –L SPECIFY LEAD STYLE FROM CHART –DS = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –S = Tape & Reel (100 Positions N/A) –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) (100 Positions N/A) –L ERM8 = Latching (ERM8 –03.0, –05.0 & –09.0 Lead Styles only & –EGP Option not available) (ERF8 –05.0,–07.0 & –09.0 Lead Style only, –L & –EGP Options not available) Cable Mates: ERCD, ERDP = Extended Guide Post (ERM8 –05.0 & ERF8 –07.0 Lead Style Only & –L Option not available) Board Mates: ERF8 "X"R –TR = Differential Pair (ERM8 –05.0 Lead Style with –010, –013, –025, –049 Positions only) (–P not available) = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail (100 Position Only Available with ERM8–09.0 & ERF8–05.0 Lead Styles; –L or –EGP N/A) - OPTIONS –EGP 1RRI3RVLWLRQV[     ²/ ²(*3 1RRI3RVLWLRQV[        ERM8 LEAD STYLE A –02.0 (5.97) .235 N/A –03.0 (6.97) .274 (1.60) .063 –DSP B –05.0 (8.91) .351 (1.17) .046 –08.0 (11.91) .469 N/A -09.0 (12.91) .508 (1.60) .063  = Differential Pair with Extended Guide Post (ERM8 –05.0 Lead Style with –013 and –025 Positions only) –K = Polyimide Film Pick & Place Pad (–02.0 Lead Style not available) –P   $   %   = Pick & Place Pad (ERM8 –02.0, –03.0 & –05.0 Lead Styles only) (–DS not available) –L –EGP MATED HEIGHT* View complete specifications at: samtec.com?ERM8 (1.50 mm) .059" Nominal Wipe ERF8 Board Mates: ERM8 ERF8 Cable Mates: ERCD, ERDP 1RRI3RVLWLRQV[     ²/ ²(*3 1RRI3RVLWLRQV[     ERF8 LEAD STYLE C D –05.0 (5.34) .210 (1.60) .063 –07.0 (7.25) .285 (1.17) .046 -09.0 (9.34) .368 (1.60) .063   Notes: Severe Environment Testing qualified; aligns with MIL-DTL-55302. Visit samtec.com/set Some lengths, styles and options are non-standard, non-returnable.   & –L –05.0 –07.0 –09.0 –02.0 (7.00) .276 (9.00) .354 (11.00) .433 –03.0 (8.00) .315 (10.00) .394 (12.00) .472 –05.0 (10.00) .394 (12.00) .472 (14.00) .551 –08.0 (13.00) .512 (15.00) .591 (17.00) .669 –09.0 (14.00) .551 (16.00) .630 (18.00) .709 *Processing conditions will affect mated height.   '   ERF8 LEAD STYLE ERM8 LEAD STYLE –EGP View complete specifications at: samtec.com?ERF8 samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
ERM8-030-08.0-L-DV-TR 价格&库存
很抱歉,暂时无法提供与“ERM8-030-08.0-L-DV-TR”相匹配的价格&库存,您可以联系我们找货
  • 1+59.080321+7.34964
  • 25+52.1962125+6.49325
  • 50+48.4959650+6.03294
  • 100+46.71481100+5.81136
库存:180
  • 200+46.71487200+5.81137
  • 600+40.72294600+5.06597
  • 1000+38.678801000+4.81168
库存:180
