ER8 Series
Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch,
Board-to-Board Connectors
Product Page
https://www.hirose.com/en/product/series/ER8
Sep. 2022
ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors
Features
1. Pitch : 0. 8mm
2. Variations :
Right Angle / Parallel /
Coplanar
3. Stacking Height :
7/ 9/ 10/ 12mm
4. Number of Positions :
10/ 20/ 30/ 40/ 50/ 60
70/ 80/ 100/ 120/ 140pos.
5. Large Guide for Easy Mating
Self- alignment Range:±1. 6mm
6. Unique Contact Design for
Smooth Mating
7. Samtec“ Edge Rate® ”
Licensed Second Source
2
High Speed Transmission Characteristics
Differential Insertion Loss
Supports PCIe Gen. 4 with sufficient margin.
Differential Impedance
85Ω ( Tr= 35ps, 20% - 80% )
Insertion Loss
Impedance
-0.5
-1
-2
Z(Ω)
S
(dB)
-1.5
-2.5
-3
-3.5
-4
IL SDD82
PCI-E-Gen4 Spec. IL
-4.5
-5
0 2 4 6 8 10 12 14 16
Frequency (GHz)
18 20
Times (ns)
Product Specification
Rated Current (Note 1)
0.5A (Signal)
Operating Temperature (Note 2)
-55 to +125℃
Rated Voltage
100V AC
Storage Temperature (Note 3)
-10 to +60℃
Item
Specifications
Conditions
Contact Resistance
50m Ω Max.
100mA
Insulation Resistance
1000M Ω Min.
100V DC
Withstanding Voltage
No flashover or insulation breakdown
300V AC for 1 min.
Mating Durability
Contact resistance change : 15m Ω Max.
No flash over or insulation breakdown.
No damage, cracks or part dislocation.
100 times
Vibration Resistance
No electrical discontinuity of 1μ s Min.
Frequency : 20 to 500Hz,
Power spectral density : 0.02G2/Hz
3 times in each of the 3 directions
Shock Resistance
980m/s2, Duration of pulse 6ms,
90 minutes each of 3-axis direction
Temperature Cycles
Insulation resistance : 1000M Ω Min.
Note 1 :
Note 2 :
Note 3 :
Note 4 :
25℃ , 90-95% RH : 120 min.
120 min.
65℃ , 90-95% RH : 120 min.
12 times
Current rating per 1 contact is used.
Includes temperature rise due to current flow.
The term“storage”refers to products stored for long period of time prior to mounting and use.
Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific
part number shown.
3
Materials / Finish
Straight Receptacle / Header
Component
Material
Color / Finish
Remarks
Insulation
LCP
Black
UL94V-0
Signal Contact
Copper Alloy
Contact Area : Gold Plating
Mounting Area : Tin Plating
Right Angle Receptacle / Header
Component
Material
Color / Finish
Remarks
Insulation
LCP
Black
UL94V-0
Signal Contact
Copper Alloy
Retention Peg
Copper Alloy
Retention Pin
Copper Alloy
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Straight Header
■ Straight Receptacle
ER8 # - ### # - 0.8 SV - #H (##)
❶
❷
❸
❹
❺
❻
❼
❽
■ Right Angle Header
■ Right Angle Receptacle
ER8 # - ### # - 0.8 SH (##)
❶
❷
❸
❹
❺
❻
❽
❶
Series Name
ER8
❺
Contact Pitch
0.8mm
❷
Specification
Blank : Standard Product
L : With Latch (140pos. only)
❻
Contact Type
SV : Straight Type
SH : Right Angle Type
❸
No. of Pos.
10-140
❼
Height
2, 5 : Header
5, 7 : Receptacle
❹
Connector Type
S : Receptacle
P : Header
❽
Plating
Specification
4
Blank : Contact Area Gold(0.76μ m) +Ni
(2.54μ m)
(10) : Contact Area Gold(0.25μm)+Ni(1.25
μ m)
Function Chart
Parallel Connection (10 to 120pos.)
Straight Header
ER8-###P-0.8SV-2H
Stacking Height
7mm
ER8-###S-0.8SV-5H
ER8-###P-0.8SV-5H
9mm
10mm
12mm
ER8-###S-0.8SV-7H
Straight Receptacle
5
Right Angle Connection
(120pos. only)
(120, 140pos. )
Straight Header
Right Angle Header
ER8-120P-0.8SV-2H
ER8-120P-0.8SV-5H
ER8#-###P-0.8SH
2H Type W=(13.03)
5H Type W=(16.03)
5H Type W=(16.41)
7H Type W=(18.33)
ER8#-###S-0.8SV-5H
ER8-120S-0.8SV-77H
ER8-120S-0.8SH
Right Angle Recectaple
Straight Receptacle
Coplanar Connection (120pos. only)
Right Angle Header
ER8-120P-0.8SH
ER8-120S-0.8SH
● Stacking
Height Variation
No. of Pos.
10
40
50
60
70
80
100
120
7mm
〇
〇
〇
〇
〇
〇
〇
〇
〇
〇
9mm
〇
〇
〇
〇
〇
〇
〇
〇
〇
〇
10mm
〇
〇
〇
〇
〇
〇
〇
〇
〇
〇
12mm
〇
〇
〇
〇
〇
〇
〇
〇
〇
〇
Stacking Height
〇 =Available
6
Signal Integrity
Pin Assignment
To match 85Ω differential impedance and to reduce crosstalk, a staggered GSSG pin assignment is
recommended for ER8.
* Analysis results only.
Row a
Straight Header
Row b
Row a
Signal
Row b
Diff pair
Ground pin
Impedance
The differential impedance is 85Ω at 35ps rise time ( 20% to 80% )
7mm Height
12mm Height
Z
Z
Straight Receptacle
Times (ns)
Times (ns)
7
Insertion Loss
12mm Height
-0.5
-1
-1
-1.5
-1.5
S
(dB)
S
(dB)
S
(d
B)
7mm Height
-2.5
-2
-2.5
-3
-3
-3.5
-3.5
-4
IL SDD82
PCI-E-Gen4 Spec. IL
-5
Frequency (GHz)
-4
IL SDD82
PCI-E-Gen4 Spec. IL
-4.5
-5
18 20
Frequency (GHz)
7mm Height
12mm Height
-10
-20
-20
S (dB)
-50
-50
-60
-30
-40
-40
RL SDD22
PCI-E-Gen4 Spec. RL
Frequency (GHz)
18 20
Return Loss
S (dB)
-4.5
18 20
-60
RL SDD22
PCI-E-Gen4 Spec. RL
Frequency (GHz)
Crosstalk
The below diagram shows the NEXT and FEXT in the same row with the highest influence.
8
18 20
Near-end Crosstalk (NEXT)
12mm Height
S (dB)
S (dB)
7mm Height
NEXT SDD21
PCI-E-Gen4 Spec. NEXT
NEXT SDD21
Frequency (GHz)
Frequency (GHz)
Far-end Crosstalk (FEXT)
7mm Height
12mm Height
Frequency (GHz)
Frequency (GHz)
9
(1.07)
(D)
A±0.13
(1.32)
(1.5)
B±0.13
(E)
5.6±0.13
Straight Header
C±0.13
(1.1)
(φ1.32)
Pin No.1
N-0.23±0.06
0.8±0.1
Unit : mm
Part No.
HRS No.
No.
of Pos.
A
B
C
D
E
Purchase
Unit
450pcs
per reel
ER8-10P-0.8SV-2H(##)
CL0625-0008-8-##
10
10
6.8
3.2
1.605
5.965
ER8-20P-0.8SV-2H(##)
CL0625-0011-0-##
10.8
7.2
1.605
5.965
ER8-30P-0.8SV-2H(##)
CL0625-0012-0-##
30
18
14.8
11.2
1.605
5.965
ER8-40P-0.8SV-2H(##)
CL0625-0013-0-##
40
22
18.8
15.2
1.605
5.965
ER8-50P-0.8SV-2H(##)
CL0625-0009-0-##
50
26
22.8
19.2
1.605
5.965
ER8-60P-0.8SV-2H(##)
CL0625-0017-0-##
60
30
26.8
23.2
1.605
5.965
ER8-70P-0.8SV-2H(##)
CL0625-0021-0-##
70
34
30.8
27.2
1.605
5.965
ER8-80P-0.8SV-2H(##)
CL0625-0022-0-##
80
38
34.8
31.2
1.605
5.965
ER8-100P-0.8SV-2H(##)
CL0625-0023-0-##
100
46
42.8
39.2
1.605
5.965
ER8-120P-0.8SV-2H(##)
CL0625-0003-4-##
120
54
50.8
47.2
1.605
5.965
ER8-10P-0.8SV-5H(##)
CL0625-0024-0-##
10
10
6.8
3.2
4.605
8.905
ER8-20P-0.8SV-5H(##)
CL0625-0025-0-##
10.8
7.2
4.605
8.905
ER8-30P-0.8SV-5H(##)
CL0625-0026-0-##
30
18
14.8
11.2
4.605
8.905
ER8-40P-0.8SV-5H(##)
CL0625-0020-0-##
40
22
18.8
15.2
4.605
8.905
ER8-50P-0.8SV-5H(##)
CL0625-0027-0-##
50
26
22.8
19.2
4.605
8.905
ER8-60P-0.8SV-5H(##)
CL0625-0019-0-##
60
30
26.8
23.2
4.605
8.905
ER8-70P-0.8SV-5H(##)
CL0625-0028-0-##
70
34
30.8
27.2
4.605
8.905
ER8-80P-0.8SV-5H(##)
CL0625-0029-0-##
80
38
34.8
31.2
4.605
8.905
ER8-100P-0.8SV-5H(##)
CL0625-0030-0-##
100
46
42.8
39.2
4.605
8.905
ER8-120P-0.8SV-5H(##)
CL0625-0031-0-##
120
54
50.8
47.2
4.605
8.905
10
475pcs
per reel
350pcs
per reel
375pcs
per reel
325pcs
per reel
250pcs
per reel
61±0.13
69±0.13
(5.75)
54±0.13
(0.35)
(2.23)
(4)
(8)
55.25±0.13
(1.1)
(φ1.57)
63.25±0.13
(φ1.57)
(φ
1.3
1.3
0.8±0.1
X
(1.1)
(φ
120-0.3±0.05
(0.35)
(2.23)
(4)
(8)
(62)
(1)
(2.19)
(6.12)
(2.46)
(6.35)
(0.3)
(1.32)
(0.3)
(1.68)
(1)
(1.4)
(6.12)
(6.35)
(4.36)
(4.36)
11±0.13
11±0.13
(5.75)
(1.32)
Right Angle Header
2)
2)
0.8
140-0.3±0.05
▽▽▽ 0.26 X
55.2
(63.25)
47.2±0.13
55.25±0.13
ER8-120P-0.8SH(##)
ER8L-140P-0.8SH(##)
Unit : mm
Part No.
HRS No.
No.
of Pos.
Purchase
Unit
200pcs
per reel
ER8-120P-0.8SH(##)
CL0625-0047-0-##
120
ER8L-140P-0.8SH(##)
CL0625-1002-0-##
140
11
5.6±0.13
Straight Receptacle
(1.1)
0.8±0.1
N-0.23±0.06
(1.5)
C±0.13
(1.32)
B±0.13
(φ1.32)
1.04
(D)
A±0.13
Pin No.1
Unit : mm
Part No.
HRS No.
No.
of Pos.
A
B
C
D
Purchase
Unit
ER8-10S-0.8SV-5H(##)
CL0625-0007-5-##
10
10
6.8
3.2
5.335
475pcs
per reel
ER8-20S-0.8SV-5H(##)
CL0625-0014-0-##
10.8
7.2
5.335
500pcs
per reel
ER8-30S-0.8SV-5H(##)
CL0625-0015-0-##
30
18
14.8
11.2
5.335
475pcs
per reel
ER8-40S-0.8SV-5H(##)
CL0625-0016-0-##
40
22
18.8
15.2
5.335
ER8-50S-0.8SV-5H(##)
CL0625-0010-0-##
50
26
22.8
19.2
5.335
ER8-60S-0.8SV-5H(##)
CL0625-0018-0-##
60
30
26.8
23.2
5.335
ER8-70S-0.8SV-5H(##)
CL0625-0032-0-##
70
34
30.8
27.2
5.335
ER8-80S-0.8SV-5H(##)
CL0625-0033-0-##
80
38
34.8
31.2
5.335
ER8-100S-0.8SV-5H(##)
CL0625-0034-0-##
100
46
42.8
39.2
5.335
ER8-120S-0.8SV-5H(##)
CL0625-0035-0-##
120
54
50.8
47.2
5.335
ER8-10S-0.8SV-7H(##)
CL0625-0036-0-##
10
10
6.8
3.2
7.25
400pcs
per reel
ER8-20S-0.8SV-7H(##)
CL0625-0037-0-##
10.8
7.2
7.25
375pcs
per reel
ER8-30S-0.8SV-7H(##)
CL0625-0038-0-##
30
18
14.8
11.2
7.25
400pcs
per reel
ER8-40S-0.8SV-7H(##)
CL0625-0039-0-##
40
22
18.8
15.2
7.25
ER8-50S-0.8SV-7H(##)
CL0625-0040-0-##
50
26
22.8
19.2
7.25
ER8-60S-0.8SV-7H(##)
CL0625-0041-0-##
60
30
26.8
23.2
7.25
ER8-70S-0.8SV-7H(##)
CL0625-0042-0-##
70
34
30.8
27.2
7.25
ER8-80S-0.8SV-7H(##)
CL0625-0043-0-##
80
38
34.8
31.2
7.25
ER8-100S-0.8SV-7H(##)
CL0625-0044-0-##
100
46
42.8
39.2
7.25
ER8-120S-0.8SV-7H(##)
CL0625-0045-0-##
120
54
50.8
47.2
7.25
12
375pcs
per reel
300pcs
per reel
(1.04)
(0.94)
63.5±0.13
(5.335)
5.6±0.13
(0.64)
(0.25)
(61.8)
55.2
0.8
140-0.23±0.06
▽▽▽ 0.26
(1.32)
(1.5)
58.8±0.13
X
(φ1.32)
X
(1.1)
Unit : mm
Part No.
ER8L-140S-0.8SV-5H(##)
HRS No.
CL0625-0046-0-##
13
No. of Pos.
Purchase
Unit
140
375pcs
per reel
61±0.13
(6.35)
1.45±0.13
(55.5)
55.25±0.13
(1.1)
1.3
2)
(φ1.57)
8.35±0.13
120-0.3±0.05
47.2
55.25
Part No.
HRS No.
ER8-120S-0.8SH(##)
CL0625-1001-4-##
No.
of Pos.
Purchase
Unit
120
200pcs
per reel
Recommended PCB Mouting Pattern (Metal Mask Thickness : t=0.15mm)
Straight Header
Connector Outline
(Do not place other components
on this area.)
(A)
2-φ1.45±0.08
(Non-plated Through-hole)
4.9±0.08
0.8±0.05
(5.6)
C±0.05
Pin No.1
1.5±0.08
B±0.08
1.1±0.08
0.8
(0.35)
2.22±0.13
4±0.13
(1.32)
(0.25)
53.8±0.2
(φ
(0.9)
1.3±0.13
(6.22)
11.35±0.13
(5.75)
N-0.5±0.04
Unit : mm
No. of Pos.
A
B
C
10
10
6.8
3.2
10.8
7.2
30
18
14.8
11.2
40
22
18.8
15.2
50
26
22.8
19.2
60
30
26.8
23.2
70
34
30.8
27.2
80
38
34.8
31.2
100
46
42.8
39.2
120
54
50.8
47.2
14
Right Angle Header
120pos.
(61)
55.25±0.05
54±0.05
2-φ1.45±0.08
120-0.5±0.04
47.2±0.05
+0.13
1.81±0.05
2-φ1.91 0
(To be soldered using paste-in-hole
technology)
140pos.
(69)
63.25±0.05
62±0.05
55.2±0.05
1.25 +0.1
0.3±0.05
3.7±0.05
1.81±0.05
1.78±0.05
4±0.05
3±0.05
+0.13
2-φ0.7 0
paste-in-hole technology)
0.8±0.05
Pin No.1
PCB
(11)
140-5±0.04
63.25±0.05
2-φ1.45±0.08
2-φ1.91 +0.13
Connector Outline
(Do not place other components on this area.)
Straight Receptacle
10-120pos.
Connector Outline
on this area.)
(A)
Pin No.1
2-φ1.45±0.08
(5.6)
0.8±0.05
5.6±0.08
C±0.05
1.5±0.08
B±0.08
1.1±0.08
N-0.5±0.04
140pos.
2-φ1.45±0.08
0.8±0.05
5.6±0.05
(5.6)
Pin No.1
1.5±0.05
2-φ0.83 +0.13
paste in hole technology)
(63.5)
61.8±0.05
58.8±0.05
55.2±0.05
+0.1
Connector Outline
on this area.)
1.1
Connector Outline
on this area.)
3.2±0.05
1.3±0.05
PCB
1.52±0.05
0.3±0.05
4±0.05
3.7±0.05
Pin No.1
(11)
1.78±0.05
+0.13
2-φ0.7 0
0.8±0.05
140-0.5±0.04
15
A
B
C
10
10
6.8
3.2
10.8
7.2
30
18
14.8
11.2
40
22
18.8
15.2
50
26
22.8
19.2
60
30
26.8
23.2
70
34
30.8
27.2
80
38
34.8
31.2
100
46
42.8
39.2
120
54
50.8
47.2
140
63.5
58.8
55.2
2.88
47.2±0.05
0.8±0.05
120-0.5±0.03
Pin No.1
11.35
0.3
2-φ1.45±0.08
(Non-plated
Through-hole)
1.78±0.05
3.7±0.05
1.95±0.05
4.35±0.05
55.25±0.05
53.8±0.05
2-φ0.63±0.08PTH
+0.1
Unit : mm
No. of Pos.
2-φ1.905±0.08PTH
Connector Outline
16
Connection Variations
Right Angle Header
ER8#-###P-0.8SH(##)
120, 140pos.
ER8-120S-0.8SH(##)
120pos. only
Straight Receptacle
Right Angle
Connection
ER8#-###S-0.8SV-#H(##)
10 to 140pos.
Straight Header
ER8-###P-0.8SV-#H(##)
10 to 120pos.
Parallel Connection
Right Angle Connection Type
Parallel Connection Type
(Straight Header + Right Angle Receptacle)
13.03 to 16.03mm
7 to 12mm
Coplanar Connection
ER8-###S-0.8SV-#H(##)
ER8-120S-0.8SH(##)
1.98 to 4.98mm
5.6mm
(Right Angle Header + Straight Receptacle)
Coplanar Connection Type
22.35mm
16.41 to 18.33mm
ER8-120P-0.8SH(##)
ER8#-###P-0.8SH(##)
5.71 to 7.63mm
17
0.6mm
ER8-120S-0.8SH(##)
Edge Rate (Samtec) Part No. Compatibility List
Straight Header
Part No.
Samtec Part No.
ER8-10P-0.8SV-2H
CL0625-0008-8-00
ERM8-005-02.0-S-DV-K-TR
ER8-20P-0.8SV-2H
CL0625-0011-0-00
ERM8-010-02.0-S-DV-K-TR
ER8-30P-0.8SV-2H
CL0625-0012-0-00
ER8-40P-0.8SV-2H
CL0625-0013-0-00
ERM8-020-02.0-S-DV-K-TR
ER8-50P-0.8SV-2H
CL0625-0009-0-00
ERM8-025-02.0-S-DV-K-TR
ER8-60P-0.8SV-2H
CL0625-0017-0-00
ERM8-030-02.0-S-DV-K-TR
ER8-70P-0.8SV-2H
HRS No.
CL0625-0021-0-00
ERM8-035-02.0-S-DV-K-TR
ER8-80P-0.8SV-2H
CL0625-0022-0-00
ERM8-040-02.0-S-DV-K-TR
ER8-100P-0.8SV-2H
CL0625-0023-0-00
ERM8-050-02.0-S-DV-K-TR
ER8-120P-0.8SV-2H
CL0625-0003-4-00
ERM8-060-02.0-S-DV-K-TR
ER8-10P-0.8SV-5H
CL0625-0024-0-00
ERM8-005-05.0-S-DV-K-TR
ER8-20P-0.8SV-5H
CL0625-0025-0-00
ERM8-010-05.0-S-DV-K-TR
ER8-30P-0.8SV-5H
CL0625-0026-0-00
ER8-40P-0.8SV-5H
CL0625-0020-0-00
ERM8-020-05.0-S-DV-K-TR
ER8-50P-0.8SV-5H
CL0625-0027-0-00
ERM8-025-05.0-S-DV-K-TR
ER8-60P-0.8SV-5H
CL0625-0019-0-00
ERM8-030-05.0-S-DV-K-TR
ER8-70P-0.8SV-5H
CL0625-0028-0-00
ERM8-035-05.0-S-DV-K-TR
ER8-80P-0.8SV-5H
CL0625-0029-0-00
ERM8-040-05.0-S-DV-K-TR
ER8-100P-0.8SV-5H
CL0625-0030-0-00
ERM8-050-05.0-S-DV-K-TR
ER8-120P-0.8SV-5H
CL0625-0031-0-00
ERM8-060-05.0-S-DV-K-TR
Right Angle Header
Part No.
HRS No.
Samtec Part No.
ER8-120P-0.8SH
CL0625-0047-0-00
ERM8-060-01-S-D-RA-K-TR
ER8L-140P-0.8SH
CL0625-1002-0-00
ERM8-070-01-S-D-RA-L-K-TR
18
Straight Receptacle
Part No.
HRS No.
Samtec Part No.
ER8-10S-0.8SV-5H
CL0625-0007-5-00
ERF8-005-05.0-S-DV-K-TR
ER8-20S-0.8SV-5H
CL0625-0014-0-00
ERF8-010-05.0-S-DV-K-TR
ER8-30S-0.8SV-5H
CL0625-0015-0-00
ER8-40S-0.8SV-5H
CL0625-0016-0-00
ERF8-020-05.0-S-DV-K-TR
ER8-50S-0.8SV-5H
CL0625-0010-0-00
ERF8-025-05.0-S-DV-K-TR
ER8-60S-0.8SV-5H
CL0625-0018-0-00
ERF8-030-05.0-S-DV-K-TR
ER8-70S-0.8SV-5H
CL0625-0032-0-00
ERF8-035-05.0-S-DV-K-TR
ER8-80S-0.8SV-5H
CL0625-0033-0-00
ERF8-040-05.0-S-DV-K-TR
ER8-100S-0.8SV-5H
CL0625-0034-0-00
ERF8-050-05.0-S-DV-K-TR
ER8-120S-0.8SV-5H
CL0625-0035-0-00
ERF8-060-05.0-S-DV-K-TR
ER8L-140S-0.8SV-5H
CL0625-0046-0-00
ERF8-070-05.0-S-DV-L-K-TR
ER8-10S-0.8SV-7H
CL0625-0036-0-00
ERF8-005-07.0-S-DV-K-TR
ER8-20S-0.8SV-7H
CL0625-0037-0-00
ERF8-010-07.0-S-DV-K-TR
ER8-30S-0.8SV-7H
CL0625-0038-0-00
ER8-40S-0.8SV-7H
CL0625-0039-0-00
ERF8-020-07.0-S-DV-K-TR
ER8-50S-0.8SV-7H
CL0625-0040-0-00
ERF8-025-07.0-S-DV-K-TR
ER8-60S-0.8SV-7H
CL0625-0041-0-00
ERF8-030-07.0-S-DV-K-TR
ER8-70S-0.8SV-7H
CL0625-0042-0-00
ERF8-035-07.0-S-DV-K-TR
ER8-80S-0.8SV-7H
CL0625-0043-0-00
ERF8-040-07.0-S-DV-K-TR
ER8-100S-0.8SV-7H
CL0625-0044-0-00
ERF8-050-07.0-S-DV-K-TR
ER8-120S-0.8SV-7H
CL0625-0045-0-00
ERF8-060-07.0-S-DV-K-TR
Part No.
ER8-120S-0.8SH
HRS No.
Samtec Part No.
CL0625-1001-4-00
ERF8-060-01-L-D-RA-TR
19
Mating Operation
● Mating Self- Alignment Tolerance ( Note)
±1.6
±1.6
Y - Direction
X - Direction
● Mating Angle Tolerance ( Note)
A mating angle of 5°is allowed in the longitudinal ( X) direction.
Mating at an angle in the lateral ( Y) direction is not recommended.
5°Max.
X - Direction
Y - Direction
Note : The above mating conditions show the allowed values for the mating self-alignment and mating angles separately.
The self alignment tolerance and angle tolerance are not satisfied at the same time.
Recommended Spacer Height
Spacers are required to support PWB’s and protect the SMT solder joints.
Unit : mm
Stacking Height
Recomended Spacer Height
7
7.15 ± 0.05
9
9.15 ± 0.05
10
10.15 ± 0.05
12
12.15 ± 0.05
Mounting Temperature Profile (Reference)
● Pb- Free Assembly
Preheat /
Soak
(150 to
200℃ )
Max. Ramp Up
Rate
Reflow Time
(217℃ Min.)
Peak
Temperature
Peak Temperature
Time
Cooling
Rate
Time Between Normal
Temperature and
Peak
60 - 120 sec.
3℃ Max./s
40 - 150
sec.
260℃
30 sec. Max.
6℃ Max./s
8 min Min.
Peak Temperature
Liquidus Temperature
Reflow
Temperature
Recommended Temperature Profile
25
Preheat/Soak
Time 25℃ to Peak
Time
Temperature profile may change depending on the solder paste types, manufacturers, PCB size, and other soldering
materials. Please fully check the mounting conditions before use.
Cleaning Conditions
● Cleaning with Organic Solvent
Solvent
Cleaning at Normal Temperature
Heated Cleaning
IPA (Isopropyl Alcohol)
Yes
Yes
HCFC (Hydrochlorofluorocarbon)
Yes
Yes
● Cleaning with Water
When water- type cleaning agents ( terpene, alkaline saponification agents) are used, select cleaning agents based on the
' table of influence' on metals and resins issued by the cleaning agent manufacturer.
Caution : Do not leave the connector with any water content left on it.
● Cleaning Precautions
If flux or cleaning agent remains on the connector during part cleaning with organic solvent and water- based agents,
it may cause deterioration of electrical performance. Confirm cleaning is performed properly.
21
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
※ The contents of this catalog are current as of date of 9/ 2022. Contents are subject to change without notice for the purpose of improvements.
22
