ERM5-040-04.0-L-DV-K-TR
    SAMTEC(申泰)
    SMD,P=0.5mm
    板对板连接器 立贴 针脚数:80Pin 间距:0.5mm 排数:2
ERM5-040-04.0-L-DV-K-TR 数据手册
RUGGED HIGH-SPEED STRIPS FEATURES & BENEFITS Edge Rate® rugged high-speed connector strips are designed for high-speed, high cycle applications, and enabled by Samtec's signal integrity-optimized Edge Rate® contact system. • Up to 1.5 mm contact wipe for a reliable connection • 20 to 200 positions • Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch • 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch • 0.635 mm pitch system with extremely slim 2.5 mm body width • Rugged latching, extended guide posts and 360° shielding Signal integrity-optimized Edge Rate® contact system reduces broadside coupling • Severe Environment Testing qualified (ERM8/ERF8); aligns with MIL-DTL-55302. Visit samtec.com/set EDGE RATE® STACK HEIGHT FLEXIBILITY (shown in mm) 5 7 8 ERM6/ ERF6 10 9 12 11 ERM5/ERF5 13 14 15 16 18 17 ERM8/ERF8 Rugged 360º shielding reduces EMI KEY SPECIFICATIONS SERIES PITCH ERM5 / ERF5 0.50 mm ERM6 / ERF6 0.635 mm ERM8 / ERF8 0.80 mm F-224 INSULATOR MATERIAL TERMINAL MATERIAL Phosphor Bronze or BeCu (ERM5), BeCu (ERF5) Black LCP Copper Alloy Phosphor Bronze or BeCu (ERM8), BeCu (ERF8) PLATING Au or Sn over 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE -55 °C to +125 °C CURRENT RATING VOLTAGE RATING 1.5 A 190 VAC 1.4 A 155 VAC 1.4 A 225 VAC LEAD-FREE SOLDERABLE Yes samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.50 mm) .0197" PITCH • RUGGED HIGH-SPEED STRIPS SERIES - ERM5 = Header ERF5 = Socket POSITIONS PER ROW –010, –020, –030, –040, –050, –060, –070, –075 - - LEAD STYLE –02.0 = 2 mm Body Height (ERM5 only) –04.0 = 4 mm Body Height (ERM5 only) –05.0 PLATING OPTION - DV - –L –K = (3.50 mm) .138" DIA Polyimide Film Pick & Place Pad (ERM5 –04.0 –05.0 and Lead Style only) –07.0 –P = 7 mm Body Height (ERF5 only & Available up to 50 Pos. only) = Plastic Pick & Place Pad (ERM5 –02.0 Lead Style only; ERM5 –010 Positions and ERF5 Not Available) 1RRI3RVLWLRQV[     Board Mates: ERF5     $   Board Mates: ERM5     % View complete specifications at: samtec.com?erm5 or samtec.com?erf5 - POSITIONS PER ROW –010, –020, –030, –040, –050 ERF5-RA Board Mates: ERM5 - 01 - PLATING OPTION - D - –02.0 (4.84) .191 –04.0 (6.84) .269 N/A –05.0 (7.84) .309 (4.91) .193 -07.0 N/A (6.91) .272 N/A MATED HEIGHT* 1RRI3RVLWLRQV[     ERF5 –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) LEAD A B STYLE (ERM5) (ERF5)   (1.00 mm) .039" Nominal Wipe Right-Angle Socket –TR = Tape & Reel = (6.00 mm) .236" DIA Polyimide Film Pick & Place Pad (ERF5 only) ERM5 "X"R (required in callout) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on Tail = 5 mm Body Height ERF5 - PICK & PLACE PAD RA - –L ERF5 LEAD STYLE ERM5 LEAD STYLE -05.0 -07.0 -02.0 (7.00) .276 (9.00) .354 -04.0 (9.00) .354 (11.00) .433 -05.0 (10.00) .394 (12.00) .472 *Processing conditions will affect mated height. "X"R –TR = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) No. of Positions x (0.50) .0197 + (10.30) .406 (6.83) .269 (4.75) .187 Note: Some lengths, styles and options are non-standard, non-returnable. View complete specifications at: samtec.com?erf5-ra samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
ERM5-040-04.0-L-DV-K-TR 价格&库存
很抱歉,暂时无法提供与“ERM5-040-04.0-L-DV-K-TR”相匹配的价格&库存,您可以联系我们找货
  • 300+32.36932300+4.02677
  • 600+31.73222600+3.94751
  • 1500+27.062731500+3.36663
  • 3000+26.436423000+3.28871
库存:469
    • 1+44.47440
    • 10+43.44840
    • 30+42.76800
    • 100+39.97296
    库存:18
    • 1+41.772501+5.19653
    • 50+38.3028350+4.76490
    • 100+35.90943100+4.46716
    库存:469
