ER8-100S-0.8SV-7H
ER8-100S-0.8SV-7H
    HRS(广濑)
    SMD,P=0.8mm
    板对板连接器 SMT 针脚数:100Pin 间距:0.8mm 排数:2
ER8-100S-0.8SV-7H 数据手册
ER8 Series Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Product Page https://www.hirose.com/en/product/series/ER8 Sep. 2022 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Features 1. Pitch : 0. 8mm Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Variations : Right Angle / Parallel / Coplanar 3. Stacking Height : 7/ 9/ 10/ 12mm 4. Number of Positions : 10/ 20/ 30/ 40/ 50/ 60 70/ 80/ 100/ 120/ 140pos. 5. Large Guide for Easy Mating Self- alignment Range:±1. 6mm 6. Unique Contact Design for Smooth Mating 7. Samtec“ Edge Rate® ” Licensed Second Source 2 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors High Speed Transmission Characteristics ● Differential Insertion Loss Supports PCIe Gen. 4 with sufficient margin. ● Differential Impedance 85Ω ( Tr= 35ps, 20% - 80% ) Insertion Loss 0 Impedance -0.5 -1 Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. -2 Z(Ω) S (dB) -1.5 -2.5 -3 -3.5 -4 IL SDD82 PCI-E-Gen4 Spec. IL -4.5 -5 0   2   4   6   8   10  12  14  16 Frequency (GHz) 18  20 Times (ns) Product Specification Rated Current (Note 1) 0.5A (Signal) Operating Temperature (Note 2) -55 to +125℃ Rated Voltage 100V AC Storage Temperature (Note 3) -10 to +60℃ Item Specifications Conditions Contact Resistance 50m Ω Max. 100mA Insulation Resistance 1000M Ω Min. 100V DC Withstanding Voltage No flashover or insulation breakdown 300V AC for 1 min. Mating Durability Contact resistance change : 15m Ω Max. No flash over or insulation breakdown. No damage, cracks or part dislocation. 100 times Vibration Resistance No electrical discontinuity of 1μ s Min. Frequency : 20 to 500Hz, Power spectral density : 0.02G2/Hz 3 times in each of the 3 directions Shock Resistance No electrical discontinuity of 1μ s Min. 980m/s2, Duration of pulse 6ms, 90 minutes each of 3-axis direction Temperature Cycles Contact resistance change : 15m Ω Max. Insulation resistance : 1000M Ω Min. No flashover or insulation breakdown No damage, cracks or part dislocation. Note 1 : Note 2 : Note 3 : Note 4 :      25℃ , 90-95% RH : 120 min. ↑ ↓ 120 min. 65℃ , 90-95% RH : 120 min. 12 times Current rating per 1 contact is used. Includes temperature rise due to current flow. The term“storage”refers to products stored for long period of time prior to mounting and use. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. 3 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Materials / Finish ● Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Straight Receptacle / Header Component Material Color / Finish Remarks Insulation LCP Black UL94V-0 Signal Contact Copper Alloy Contact Area : Gold Plating Mounting Area : Tin Plating - Right Angle Receptacle / Header Component Material Color / Finish Remarks Insulation LCP Black UL94V-0 Signal Contact Copper Alloy Contact Area : Gold Plating Mounting Area : Tin Plating - Retention Peg Copper Alloy Mounting Area : Tin Plating - Retention Pin Copper Alloy Mounting Area : Tin Plating - Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Straight Header ■ Straight Receptacle ER8 # - ### # - 0.8 SV - #H (##) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ■ Right Angle Header ■ Right Angle Receptacle ER8 # - ### # - 0.8 SH (##) ❶ ❷ ❸ ❹ ❺ ❻ ❽ ❶ Series Name ER8 ❺ Contact Pitch 0.8mm ❷ Specification Blank : Standard Product L : With Latch (140pos. only) ❻ Contact Type SV : Straight Type SH : Right Angle Type ❸ No. of Pos. 10-140 ❼ Height 2, 5 : Header 5, 7 : Receptacle ❹ Connector Type S : Receptacle P : Header ❽ Plating Specification 4 Blank : Contact Area Gold(0.76μ m) +Ni (2.54μ m) (10) : Contact Area Gold(0.25μm)+Ni(1.25 μ m) ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Function Chart ● Parallel Connection (10 to 120pos.) Straight Header Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ER8-###P-0.8SV-2H Stacking Height 7mm ER8-###S-0.8SV-5H ER8-###P-0.8SV-5H 9mm 10mm 12mm ER8-###S-0.8SV-7H Straight Receptacle 5 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors ● Right Angle Connection (120pos. only) (120, 140pos. ) Straight Header Right Angle Header ER8-120P-0.8SV-2H ER8-120P-0.8SV-5H ER8#-###P-0.8SH 2H Type W=(13.03) 5H Type W=(16.03) Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5H Type W=(16.41) 7H Type W=(18.33) ER8#-###S-0.8SV-5H ER8-120S-0.8SV-77H ER8-120S-0.8SH Right Angle Recectaple ● Straight Receptacle Coplanar Connection (120pos. only) Right Angle Header ER8-120P-0.8SH ER8-120S-0.8SH Right Angle Recectaple ● Stacking Height Variation No. of Pos. 10 20 30 40 50 60 70 80 100 120 7mm 〇 〇 〇 〇 〇 〇 〇 〇 〇 〇 9mm 〇 〇 〇 〇 〇 〇 〇 〇 〇 〇 10mm 〇 〇 〇 〇 〇 〇 〇 〇 〇 〇 12mm 〇 〇 〇 〇 〇 〇 〇 〇 〇 〇 Stacking Height 〇 =Available 6 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Signal Integrity ● Pin Assignment To match 85Ω differential impedance and to reduce crosstalk, a staggered GSSG pin assignment is recommended for ER8. * Analysis results only. Row a Straight Header Row b Row a Signal ● Row b Diff pair Ground pin Impedance The differential impedance is 85Ω at 35ps rise time ( 20% to 80% ) 7mm Height 12mm Height Z Z Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Receptacle Times (ns) Times (ns) 7 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors ● Insertion Loss 12mm Height 0 -0.5 -0.5 -1 -1 -1.5 -1.5 S (dB) S (dB) S (d B) 7mm Height 0 -2 -2.5 -2 -2.5 -3 -3 -3.5 -3.5 -4 IL SDD82 PCI-E-Gen4 Spec. IL -5 0   2   4   6   8   10  12  14  16 Frequency (GHz) ● -4 IL SDD82 PCI-E-Gen4 Spec. IL -4.5 -5 18  20 0   2   4   6   8   10  12  14  16 Frequency (GHz) 7mm Height 12mm Height 0 -10 -10 -20 -20 S (dB) 0 -30 -50 -50 -60 -30 -40 -40 RL SDD22 PCI-E-Gen4 Spec. RL 0   2   4   6   8   10  12  14  16 Frequency (GHz) ● 18  20 Return Loss S (dB) Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. -4.5 18  20 -60 RL SDD22 PCI-E-Gen4 Spec. RL 0   2   4   6   8   10  12  14  16 Frequency (GHz) Crosstalk The below diagram shows the NEXT and FEXT in the same row with the highest influence. 8 18  20 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors ● Near-end Crosstalk (NEXT) 12mm Height S (dB) S (dB) 7mm Height Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. NEXT SDD21 PCI-E-Gen4 Spec. NEXT NEXT SDD21 PCI-E-Gen4 Spec. NEXT Frequency (GHz) ● Frequency (GHz) Far-end Crosstalk (FEXT) 7mm Height 12mm Height Frequency (GHz) Frequency (GHz) 9 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors (1.07) (D) A±0.13 (1.32) (1.5) B±0.13 Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (E) 5.6±0.13 Straight Header C±0.13 (1.1) (φ1.32) Pin No.1 N-0.23±0.06 0.8±0.1 Unit : mm Part No. HRS No. No. of Pos. A B C D E Purchase Unit 450pcs per reel ER8-10P-0.8SV-2H(##) CL0625-0008-8-## 10 10 6.8 3.2 1.605 5.965 ER8-20P-0.8SV-2H(##) CL0625-0011-0-## 20 14 10.8 7.2 1.605 5.965 ER8-30P-0.8SV-2H(##) CL0625-0012-0-## 30 18 14.8 11.2 1.605 5.965 ER8-40P-0.8SV-2H(##) CL0625-0013-0-## 40 22 18.8 15.2 1.605 5.965 ER8-50P-0.8SV-2H(##) CL0625-0009-0-## 50 26 22.8 19.2 1.605 5.965 ER8-60P-0.8SV-2H(##) CL0625-0017-0-## 60 30 26.8 23.2 1.605 5.965 ER8-70P-0.8SV-2H(##) CL0625-0021-0-## 70 34 30.8 27.2 1.605 5.965 ER8-80P-0.8SV-2H(##) CL0625-0022-0-## 80 38 34.8 31.2 1.605 5.965 ER8-100P-0.8SV-2H(##) CL0625-0023-0-## 100 46 42.8 39.2 1.605 5.965 ER8-120P-0.8SV-2H(##) CL0625-0003-4-## 120 54 50.8 47.2 1.605 5.965 ER8-10P-0.8SV-5H(##) CL0625-0024-0-## 10 10 6.8 3.2 4.605 8.905 ER8-20P-0.8SV-5H(##) CL0625-0025-0-## 20 14 10.8 7.2 4.605 8.905 ER8-30P-0.8SV-5H(##) CL0625-0026-0-## 30 18 14.8 11.2 4.605 8.905 ER8-40P-0.8SV-5H(##) CL0625-0020-0-## 40 22 18.8 15.2 4.605 8.905 ER8-50P-0.8SV-5H(##) CL0625-0027-0-## 50 26 22.8 19.2 4.605 8.905 ER8-60P-0.8SV-5H(##) CL0625-0019-0-## 60 30 26.8 23.2 4.605 8.905 ER8-70P-0.8SV-5H(##) CL0625-0028-0-## 70 34 30.8 27.2 4.605 8.905 ER8-80P-0.8SV-5H(##) CL0625-0029-0-## 80 38 34.8 31.2 4.605 8.905 ER8-100P-0.8SV-5H(##) CL0625-0030-0-## 100 46 42.8 39.2 4.605 8.905 ER8-120P-0.8SV-5H(##) CL0625-0031-0-## 120 54 50.8 47.2 4.605 8.905 10 475pcs per reel 350pcs per reel 375pcs per reel 325pcs per reel 250pcs per reel ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors 61±0.13 69±0.13 (5.75) 54±0.13 (0.35) (2.23) (4) (8) 55.25±0.13 (1.1) (φ1.57) 63.25±0.13 (φ1.57) (φ 1.3 1.3 0.8±0.1 X (1.1) (φ 120-0.3±0.05 (0.35) (2.23) (4) (8) (62) (1) (2.19) (6.12) (2.46) (6.35) (0.3) (1.32) (0.3) (1.68) (1) (1.4) (6.12) (6.35) (4.36) (4.36) 11±0.13 11±0.13 (5.75) (1.32) Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right Angle Header 2) 2) 0.8 140-0.3±0.05 ▽▽▽ 0.26 X 55.2 (63.25) 47.2±0.13 55.25±0.13 ER8-120P-0.8SH(##) ER8L-140P-0.8SH(##) Unit : mm Part No. HRS No. No. of Pos. Purchase Unit 200pcs per reel ER8-120P-0.8SH(##) CL0625-0047-0-## 120 ER8L-140P-0.8SH(##) CL0625-1002-0-## 140 11 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors 5.6±0.13 Straight Receptacle (1.1) 0.8±0.1 N-0.23±0.06 (1.5) Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C±0.13 (1.32) B±0.13 (φ1.32) 1.04 (D) A±0.13 Pin No.1 Unit : mm Part No. HRS No. No. of Pos. A B C D Purchase Unit ER8-10S-0.8SV-5H(##) CL0625-0007-5-## 10 10 6.8 3.2 5.335 475pcs per reel ER8-20S-0.8SV-5H(##) CL0625-0014-0-## 20 14 10.8 7.2 5.335 500pcs per reel ER8-30S-0.8SV-5H(##) CL0625-0015-0-## 30 18 14.8 11.2 5.335 475pcs per reel ER8-40S-0.8SV-5H(##) CL0625-0016-0-## 40 22 18.8 15.2 5.335 ER8-50S-0.8SV-5H(##) CL0625-0010-0-## 50 26 22.8 19.2 5.335 ER8-60S-0.8SV-5H(##) CL0625-0018-0-## 60 30 26.8 23.2 5.335 ER8-70S-0.8SV-5H(##) CL0625-0032-0-## 70 34 30.8 27.2 5.335 ER8-80S-0.8SV-5H(##) CL0625-0033-0-## 80 38 34.8 31.2 5.335 ER8-100S-0.8SV-5H(##) CL0625-0034-0-## 100 46 42.8 39.2 5.335 ER8-120S-0.8SV-5H(##) CL0625-0035-0-## 120 54 50.8 47.2 5.335 ER8-10S-0.8SV-7H(##) CL0625-0036-0-## 10 10 6.8 3.2 7.25 400pcs per reel ER8-20S-0.8SV-7H(##) CL0625-0037-0-## 20 14 10.8 7.2 7.25 375pcs per reel ER8-30S-0.8SV-7H(##) CL0625-0038-0-## 30 18 14.8 11.2 7.25 400pcs per reel ER8-40S-0.8SV-7H(##) CL0625-0039-0-## 40 22 18.8 15.2 7.25 ER8-50S-0.8SV-7H(##) CL0625-0040-0-## 50 26 22.8 19.2 7.25 ER8-60S-0.8SV-7H(##) CL0625-0041-0-## 60 30 26.8 23.2 7.25 ER8-70S-0.8SV-7H(##) CL0625-0042-0-## 70 34 30.8 27.2 7.25 ER8-80S-0.8SV-7H(##) CL0625-0043-0-## 80 38 34.8 31.2 7.25 ER8-100S-0.8SV-7H(##) CL0625-0044-0-## 100 46 42.8 39.2 7.25 ER8-120S-0.8SV-7H(##) CL0625-0045-0-## 120 54 50.8 47.2 7.25 12 375pcs per reel 300pcs per reel (1.04) (0.94) 63.5±0.13 (5.335) 5.6±0.13 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors (0.64) (0.25) (61.8) Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 55.2 0.8 140-0.23±0.06 ▽▽▽ 0.26 (1.32) (1.5) 58.8±0.13 X (φ1.32) X (1.1) Unit : mm Part No. ER8L-140S-0.8SV-5H(##) HRS No. CL0625-0046-0-## 13 No. of Pos. Purchase Unit 140 375pcs per reel ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Right Angle Receptacle 61±0.13 (6.35) 1.45±0.13 (55.5) 55.25±0.13 (1.1) 1.3 2) (φ1.57) 8.35±0.13 120-0.3±0.05 47.2 55.25 Part No. HRS No. ER8-120S-0.8SH(##) CL0625-1001-4-## No. of Pos. Purchase Unit 120 200pcs per reel Recommended PCB Mouting Pattern (Metal Mask Thickness : t=0.15mm) ● Straight Header Connector Outline (Do not place other components on this area.) (A) 2-φ1.45±0.08 (Non-plated Through-hole) 4.9±0.08 0.8±0.05 (5.6) C±0.05 Pin No.1 1.5±0.08 B±0.08 1.1±0.08 Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.8 (0.35) 2.22±0.13 4±0.13 (1.32) (0.25) 53.8±0.2 (φ (0.9) 1.3±0.13 (6.22) 11.35±0.13 (5.75) N-0.5±0.04 Unit : mm No. of Pos. A B C 10 10 6.8 3.2 20 14 10.8 7.2 30 18 14.8 11.2 40 22 18.8 15.2 50 26 22.8 19.2 60 30 26.8 23.2 70 34 30.8 27.2 80 38 34.8 31.2 100 46 42.8 39.2 120 54 50.8 47.2 14 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors ● Right Angle Header 120pos. (61) 55.25±0.05 54±0.05 2-φ1.45±0.08 120-0.5±0.04 (Non-plated Through-hole) 47.2±0.05 +0.13 1.81±0.05 2-φ1.91 0 (To be soldered using paste-in-hole technology) 140pos. (69) 63.25±0.05 62±0.05 55.2±0.05 1.25 +0.1 0 0.3±0.05 3.7±0.05 1.81±0.05 1.78±0.05 4±0.05 3±0.05 +0.13 2-φ0.7 0 (To be soldered using paste-in-hole technology) 0.8±0.05 Pin No.1 PCB (11) 140-5±0.04 63.25±0.05 2-φ1.45±0.08 (Non-plated Through-hole) 2-φ1.91 +0.13 0 (To be soldered using paste-in-hole technology) Connector Outline (Do not place other components on this area.) ● Straight Receptacle 10-120pos. Connector Outline (Do not place other components on this area.) (A) Pin No.1 2-φ1.45±0.08 (Non-plated Through-hole) (5.6) 0.8±0.05 5.6±0.08 C±0.05 1.5±0.08 B±0.08 1.1±0.08 N-0.5±0.04 140pos. 2-φ1.45±0.08 (Non-plated Through-hole) 0.8±0.05 5.6±0.05 (5.6) Pin No.1 1.5±0.05 2-φ0.83 +0.13 0 (To be soldered using paste in hole technology) (63.5) 61.8±0.05 58.8±0.05 55.2±0.05 +0.1 0 Connector Outline (Do not place other components on this area.) 1.1 Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Connector Outline (Do not place other components on this area.) 3.2±0.05 1.3±0.05 PCB 1.52±0.05 0.3±0.05 4±0.05 3.7±0.05 Pin No.1 (11) 1.78±0.05 +0.13 2-φ0.7 0 (To be soldered using paste-in-hole technology) 0.8±0.05 140-0.5±0.04 15 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors A B C 10 10 6.8 3.2 20 14 10.8 7.2 30 18 14.8 11.2 40 22 18.8 15.2 50 26 22.8 19.2 60 30 26.8 23.2 70 34 30.8 27.2 80 38 34.8 31.2 100 46 42.8 39.2 120 54 50.8 47.2 140 63.5 58.8 55.2 Right Angle Receptacle 2.88 47.2±0.05 0.8±0.05 120-0.5±0.03 Pin No.1 11.35 0.3 2-φ1.45±0.08 (Non-plated Through-hole) 1.78±0.05 3.7±0.05 1.95±0.05 4.35±0.05 55.25±0.05 53.8±0.05 2-φ0.63±0.08PTH +0.1 0 1.25 +0.1 0 ● 3.13 Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm No. of Pos. 2-φ1.905±0.08PTH Connector Outline (Do not place other components on this area.) 16 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Connection Variations Right Angle Receptacle Right Angle Header ER8#-###P-0.8SH(##) 120, 140pos. ER8-120S-0.8SH(##) 120pos. only Straight Receptacle Right Angle Connection ER8#-###S-0.8SV-#H(##) 10 to 140pos. Straight Header ER8-###P-0.8SV-#H(##) 10 to 120pos. Parallel Connection Right Angle Connection Type Parallel Connection Type (Straight Header + Right Angle Receptacle) 13.03 to 16.03mm 7 to 12mm Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Coplanar Connection ER8-###S-0.8SV-#H(##) ER8-###P-0.8SV-#H(##) ER8-###P-0.8SV-#H(##) ER8-120S-0.8SH(##) 1.98 to 4.98mm 5.6mm Right Angle Connection Type (Right Angle Header + Straight Receptacle) Coplanar Connection Type 22.35mm 16.41 to 18.33mm ER8#-###S-0.8SV-#H(##) ER8-120P-0.8SH(##) ER8#-###P-0.8SH(##) 5.71 to 7.63mm 17 0.6mm ER8-120S-0.8SH(##) ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Edge Rate (Samtec) Part No. Compatibility List ● Straight Header Part No. Samtec Part No. ER8-10P-0.8SV-2H CL0625-0008-8-00 ERM8-005-02.0-S-DV-K-TR ER8-20P-0.8SV-2H CL0625-0011-0-00 ERM8-010-02.0-S-DV-K-TR ER8-30P-0.8SV-2H CL0625-0012-0-00 ER8-40P-0.8SV-2H CL0625-0013-0-00 ERM8-020-02.0-S-DV-K-TR ER8-50P-0.8SV-2H CL0625-0009-0-00 ERM8-025-02.0-S-DV-K-TR ER8-60P-0.8SV-2H CL0625-0017-0-00 ERM8-030-02.0-S-DV-K-TR ER8-70P-0.8SV-2H Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. - CL0625-0021-0-00 ERM8-035-02.0-S-DV-K-TR ER8-80P-0.8SV-2H CL0625-0022-0-00 ERM8-040-02.0-S-DV-K-TR ER8-100P-0.8SV-2H CL0625-0023-0-00 ERM8-050-02.0-S-DV-K-TR ER8-120P-0.8SV-2H CL0625-0003-4-00 ERM8-060-02.0-S-DV-K-TR ER8-10P-0.8SV-5H CL0625-0024-0-00 ERM8-005-05.0-S-DV-K-TR ER8-20P-0.8SV-5H CL0625-0025-0-00 ERM8-010-05.0-S-DV-K-TR ER8-30P-0.8SV-5H CL0625-0026-0-00 ER8-40P-0.8SV-5H CL0625-0020-0-00 ERM8-020-05.0-S-DV-K-TR ER8-50P-0.8SV-5H CL0625-0027-0-00 ERM8-025-05.0-S-DV-K-TR ER8-60P-0.8SV-5H CL0625-0019-0-00 ERM8-030-05.0-S-DV-K-TR ER8-70P-0.8SV-5H CL0625-0028-0-00 ERM8-035-05.0-S-DV-K-TR ER8-80P-0.8SV-5H CL0625-0029-0-00 ERM8-040-05.0-S-DV-K-TR ER8-100P-0.8SV-5H CL0625-0030-0-00 ERM8-050-05.0-S-DV-K-TR ER8-120P-0.8SV-5H CL0625-0031-0-00 ERM8-060-05.0-S-DV-K-TR ● - Right Angle Header Part No. HRS No. Samtec Part No. ER8-120P-0.8SH CL0625-0047-0-00 ERM8-060-01-S-D-RA-K-TR ER8L-140P-0.8SH CL0625-1002-0-00 ERM8-070-01-S-D-RA-L-K-TR 18 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors ● Straight Receptacle Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. Samtec Part No. ER8-10S-0.8SV-5H CL0625-0007-5-00 ERF8-005-05.0-S-DV-K-TR ER8-20S-0.8SV-5H CL0625-0014-0-00 ERF8-010-05.0-S-DV-K-TR ER8-30S-0.8SV-5H CL0625-0015-0-00 - ER8-40S-0.8SV-5H CL0625-0016-0-00 ERF8-020-05.0-S-DV-K-TR ER8-50S-0.8SV-5H CL0625-0010-0-00 ERF8-025-05.0-S-DV-K-TR ER8-60S-0.8SV-5H CL0625-0018-0-00 ERF8-030-05.0-S-DV-K-TR ER8-70S-0.8SV-5H CL0625-0032-0-00 ERF8-035-05.0-S-DV-K-TR ER8-80S-0.8SV-5H CL0625-0033-0-00 ERF8-040-05.0-S-DV-K-TR ER8-100S-0.8SV-5H CL0625-0034-0-00 ERF8-050-05.0-S-DV-K-TR ER8-120S-0.8SV-5H CL0625-0035-0-00 ERF8-060-05.0-S-DV-K-TR ER8L-140S-0.8SV-5H CL0625-0046-0-00 ERF8-070-05.0-S-DV-L-K-TR ER8-10S-0.8SV-7H CL0625-0036-0-00 ERF8-005-07.0-S-DV-K-TR ER8-20S-0.8SV-7H CL0625-0037-0-00 ERF8-010-07.0-S-DV-K-TR ER8-30S-0.8SV-7H CL0625-0038-0-00 - ER8-40S-0.8SV-7H CL0625-0039-0-00 ERF8-020-07.0-S-DV-K-TR ER8-50S-0.8SV-7H CL0625-0040-0-00 ERF8-025-07.0-S-DV-K-TR ER8-60S-0.8SV-7H CL0625-0041-0-00 ERF8-030-07.0-S-DV-K-TR ER8-70S-0.8SV-7H CL0625-0042-0-00 ERF8-035-07.0-S-DV-K-TR ER8-80S-0.8SV-7H CL0625-0043-0-00 ERF8-040-07.0-S-DV-K-TR ER8-100S-0.8SV-7H CL0625-0044-0-00 ERF8-050-07.0-S-DV-K-TR ER8-120S-0.8SV-7H CL0625-0045-0-00 ERF8-060-07.0-S-DV-K-TR ● Right Angle Receptacle Part No. ER8-120S-0.8SH HRS No. Samtec Part No. CL0625-1001-4-00 ERF8-060-01-L-D-RA-TR 19 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Mating Operation ● Mating Self- Alignment Tolerance ( Note) Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ±1.6 ±1.6 Y - Direction X - Direction ● Mating Angle Tolerance ( Note) A mating angle of 5°is allowed in the longitudinal ( X) direction. Mating at an angle in the lateral ( Y) direction is not recommended. 5°Max. X - Direction Y - Direction Note : The above mating conditions show the allowed values for the mating self-alignment and mating angles separately. The self alignment tolerance and angle tolerance are not satisfied at the same time. Recommended Spacer Height Spacers are required to support PWB’s and protect the SMT solder joints. Unit : mm Stacking Height Recomended Spacer Height 7 7.15 ± 0.05 9 9.15 ± 0.05 10 10.15 ± 0.05 12 12.15 ± 0.05 20 ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors Mounting Temperature Profile (Reference) ● Pb- Free Assembly Preheat / Soak (150 to 200℃ ) Max. Ramp Up Rate Reflow Time (217℃ Min.) Peak Temperature Peak Temperature Time Cooling Rate Time Between Normal Temperature and Peak 60 - 120 sec. 3℃ Max./s 40 - 150 sec. 260℃ 30 sec. Max. 6℃ Max./s 8 min Min. Peak Temperature Liquidus Temperature Reflow Temperature Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended Temperature Profile 25 Preheat/Soak Time 25℃ to Peak Time Temperature profile may change depending on the solder paste types, manufacturers, PCB size, and other soldering materials. Please fully check the mounting conditions before use. Cleaning Conditions ● Cleaning with Organic Solvent Solvent Cleaning at Normal Temperature Heated Cleaning IPA (Isopropyl Alcohol) Yes Yes HCFC (Hydrochlorofluorocarbon) Yes Yes ● Cleaning with Water When water- type cleaning agents ( terpene, alkaline saponification agents) are used, select cleaning agents based on the ' table of influence' on metals and resins issued by the cleaning agent manufacturer. Caution : Do not leave the connector with any water content left on it. ● Cleaning Precautions If flux or cleaning agent remains on the connector during part cleaning with organic solvent and water- based agents, it may cause deterioration of electrical performance. Confirm cleaning is performed properly. 21 Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ER8 Series/PCIe Gen.4 High Speed Transmission (16+Gbps), 0.8mm Pitch, Board-to-Board Connectors While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 9/ 2022. Contents are subject to change without notice for the purpose of improvements. 22
ER8-100S-0.8SV-7H 价格&库存
很抱歉,暂时无法提供与“ER8-100S-0.8SV-7H”相匹配的价格&库存,您可以联系我们找货
ER8-100S-0.8SV-7H
  • 1+63.010411+7.83854
  • 10+51.3396810+6.38670
  • 25+47.3282425+5.88767
  • 50+44.5066850+5.53667
  • 100+41.85413100+5.20669
库存:216
ER8-100S-0.8SV-7H
  • 300+42.10732300+5.23819
  • 600+40.09891600+4.98834
  • 900+38.96914900+4.84779
  • 1500+37.591301500+4.67639
  • 2100+36.710612100+4.56683
库存:216
ER8-100S-0.8SV-7H
    • 300+39.97404300+4.97280
