HXY
CMMSH1-100GTR
ELECTRONICS CO.,LTD
SCHOTTKY RECTIFIER DIODES
HUAXUANYANG
Features
z
Average Forward Current:IF(AV) =1A
z
Polarity: Color band denotes cathode
Package Marking and Ordering Information
Product ID
Pack
Marking
Qty(PCS)
CMMSH1-100GTR
SOD-123FL
K110
3000
SOD-123FL
Maximum Ratings (Ta=25°C unless otherwise noted)
Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 %
Type Number
Limit
Units
Maximum Recurrent Peak Reverse Voltage
100
V
Maximum RMS Voltage
70
V
Maximum DC Blocking Voltage
100
V
Maximum Average Forward Rectified Current See Fig. 1
1.0
A
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
30
A
0.85
V
0.2
mA
mA
Maximum Instantaneous Forward Voltage at 1.0A
Maximum DC Reverse Current
Ta=25°C
at Rated DC Blocking Voltage
Ta=100°C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
10
110
80
-65 +150
-65 +150
pF
°C/W
°C
°C
Notes:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Ambient.
Shenzhen HuaXuanYang Electronics CO.,LTD
www.hxymos.com
HXY
CMMSH1-100GTR
ELECTRONICS CO.,LTD
HUAXUANYANG
Typical Characteristics
FIG.2-TYPICAL FORWARD
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
50
1.0
0.8
0.6
0.4
0.2
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE ( C)
PEAK FORWARD SURGE CURRENT,(A)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
1.2
10
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
30
.01
24
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
18
8.3ms Single Half
Tj=25 C
Sine Wave
12
JEDEC method
6
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
1
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
350
300
250
200
150
100
10
1.0
Tj=75 C
.1
Tj=25 C
50
.05
.1
.5
1
5
REVERSE VOLTAGE,(V)
10
50
100
.01
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
www.hxymos.com
HXY
CMMSH1-100GTR
ELECTRONICS CO.,LTD
HUAXUANYANG
SOD-123FL Package Outline Dimensions
1.8± 0.1
1.0 ±0.15
Cathode Band
Top View
1.1± 0.2
0.12-0.20
2.7 ±0.15
0.8±0.1
3.7 ±0.15
www.hxymos.com
HXY
CMMSH1-100GTR
ELECTRONICS CO.,LTD
HUAXUANYANG
Attention
■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle
applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications
whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG
ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein
in such applications.
■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products
specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein.
■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance,
characteristics, and functions of the described products in the independent state, and are not guarantees of the performance,
characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and
states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the
■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with some probability. It is possible that these probabilistic failures could
give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other
property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures
include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design.
■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein
are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the
export license from the authorities concerned in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including
photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production.
HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding
its use or any infringements of intellectual property rights or other rights of third parties.
■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc.
When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use.
www.hxymos.com
