MACM9070-102
MACM9070-102
    COILMX(迈翔)
    SMD-4P,9x7mm
MACM9070-102 数据手册
SPECIFICATION FOR APPROVAL 产品规格承认书 SMD POWER INDUCTOR 贴片共模电感 CUSTOMER. MODEL NO. MACM9070系列 CUSTOMER'S PART NO. LILE NO. DATE. 2020.03.07 REVISION. A/0 CUSTOMER APPROVE DATE: DRAWING DRAWN BY CHECK BY APPROVAL BY DATE: 深圳市迈翔科技有限公司 SHENZHEN MOTTO TECHNOLOGY Co., Ltd 香港瑞德科技有限公司 黄冈市迈翔电子有限公司 Motto Technology park, niu e ling village no#214 xintian,nghua Town, Guanlan Street, Longhua District,Shenzhen TEL: +86 0755-8948751~2 89487610 Fax: +86 0755-61624574 IATF16949 / ISO9001 / ISO14000 Http://www.coilmx.com E-mail: sales@mottotech.com 1/7 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MACM9070系列 REVISION A/0 DATE 2020.03.07 REVISIONS REW PROJECT CHANGE DESCRIPTION Date 2/7 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MACM9070系列 REVISION A/0 DATE 2020.03.07 1.PRODUCT DIMENSION UNIT:mm A 9.0±0.5 A1 9.5±0.5 B 7.0±0.5 C 4.8Max D 5.6Typ E 1.5Typ F 1.7Typ 2.ELECTRICAL REQUIREMENTS Product NO Z(Ω)100MHZ/1V Rated Rated DCR IR Current(A) Voltag(V) (mΩ)Max (MΩ)Min Max Max MARKING MIN TYP MACM9070-301 225 300 6 6 10 80 301 MACM9070-501 450 600 8 5.5 10 80 501 MACM9070-701 500 700 10 5 10 80 701 MACM9070-102 750 1000 13 4 10 80 102 MACM9070-222 1700 2200 50 3 10 80 222 MACM9070-272 2000 2700 80 2 10 80 272 3.CHARACTERISTICS (1). All test data is based on 25℃ ambient. (2). DC current(A)that will cause an approximate △T40℃ (3). DC current(A)that will cause L0 to drop approximately 10%Typ (4). Operating temperature range: -55℃~+125℃ (5).The part temperature (ambient + temp rise)should not exceed 125℃ under worst case operating conditions. circuit design, component.PWB trace size and thickness,airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the den application 4.SPECIAL REQUEST (1)Lettering on top of the body. 3/7 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MACM9070系列 REVISION A/0 DATE 2020.03.07 5.PRODUCT IDENTIFICATION XX ① XXXX ② ①、 Product Symbol ③ XXX X ④ ②、 Dimensions ④、 Tolerance: M±20%, N±30%. X ⑤ ③、 Inductance ⑤ 、Material 6.ELECTRICAL SCHEMATICS 7.APPLICATION (1)Low profile,high current power supplies. (2)Battery powered devices. (3)DC/DC converters in distributed power systems. (5)DC/DC converters for field programmable gate array. 8.FEATURES (1)ROHS compliant. (2)Super low resistance,ultra high current rating. (3)high performance(I sat)realized by metal dust core. (4)Frequency Range:up to 1MHZ. 9.RECOMMENDED PCB LAYOUT G 5.5Typ H 1.5Typ I 10.5Typ J 5.0Typ 4/7 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. 项目Item 规格与需求 Specification and Requirement 沾锡面积不得小于95%上锡面 可焊性 Solder a bility test 振动测试 Vibration test 冲击测试 Shock test 冷热冲击 Thermal shock Terminals area must have 95% min solder coverage 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break MACM9070系列 REVISION A/0 DATE 2020.03.07 测试方法Test Method 上锡升温曲线Solder heat proof: (1) 预热:160±10℃持续90s Preheating: 160±10℃ for 90 seconds (2) 恒温时段:245±5℃持续2±0.5s Retention time: 245±5℃ for 2±0.5 seconds (1) 振动频率(10Hz 55Hz 10Hz)60s为一个周期 Vibration frequency: (10Hz to 55Hz to 10Hz) in 60 seconds as a period (2) 振动时间 Vibration time: 三维正交坐标系每个方向振动 (周期) 循环2小时 Period cycled for 2 hours in each of 3 mutual perpendicular directions (3) 振幅 Amplitude: 1.5 mm Max (1) 最大振幅 Peak value: 100G (2) 脉冲波长 Duration of pulse: 11ms (3) 三维正交坐标系每个方向正负方向冲击 3次 Times in each positive and negative direction of 3 mutual perpendicular directions (1)重复以上100个循环Repeat 100 cycle as follow (-55±2℃,30±3分钟) 室温5分钟 (-55±2℃,30±3 minutes) Room temperature,5 minutes (+125±2℃,30±3分钟) 室温5分钟 (+125±2℃,30±3 minutes) Room temperature,5 minutes (2)恢复:测试于标准条件下恢复 48+4/-0小时 (参考注释1) Recovery:48+4/-0 hours of recovery under the standard condition after the test. (see Note1) 感值变化:不超过±5% 耐高温测试 且无破裂等机械损伤产生 High temperature life Inductance change: Within±5% Without test mechanical damage such as break (1)环境条件:85±2℃ Environment condition : 85±2℃ 应用电流:额定电流 Applied current: Rated current (2)持续时间:1000+4/-0 小时(参考注释1) Duration:1000+4/-0 hours (see Note1) 感值变化:不超过±5% 耐湿测试 且无破裂等机械损伤产生 Humidity Resistance Inductance change: Within±5% Without mechanical damage such as break (1)环境条件:60±2℃ Environment condition : 60±2℃ 湿度:90~95% Humidity:90~95% 应用电流:额定电流 Applied current: Rated current (2)持续时间:1000+4/-0 小时(参考注释1) Duration:1000+4/-0 hours (see Note1) 感值变化:不超过±5% 低温存放测试Low 且无破裂等机械损伤产生 temperature life test Inductance change: Within±5% Without mechanical damage such as break (1)存储温度 Store temperature -55±2℃下存放 1000+4/-0 小时 -55±2℃for total 1000+4/-0 hours 感值变化:不超过±5% 高温存放测试High 且无破裂等机械损伤产生 temperature life test Inductance change: Within±5% Without mechanical damage such as break (1)存储温度 Store temperature +125±2℃下存放 1000+4/-0 小时 +125±2℃for total 1000+4/-0 hours 5/7 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MACM9070系列 REVISION A/0 DATE 2020.03.07 11、包装 Packaging 11.1、尺寸 Dimensions 11.1.1 包装料带尺寸 Tape packaging dimensions 11.1.2 卷轴尺寸 Reel dimensions 项目 尺寸(mm) A 330 B 100 C 13 D 16.5 项目 数量(PCS) 1卷轴 700 1内箱 1400 1外箱 7000 11.1.3 外箱尺寸Carton dimensions 6/7 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MACM9070系列 REVISION A/0 DATE 2020.03.07 Reflow curve ※ Reflow Profile 1. Reflow Soldering Method 2. Soldering iron method :350±5℃ Max.3 seconds. 7/7
