EVBC846-EVBC848
BC846-BC848
BC846-BC848
"S1" means SOT-23
EVBC846-EVBC848
NPN Transistors
3
2
■ Features
1
● Ideally suited for automatic insertion
1.Base
2.Emitter
3.Collector
■ Simplified outline(SOT-23)
● For switching and AF amplifier applications
■ Absolute Maximum Ratings Ta = 25℃
Parameter
Symbol
EVBC846
EVBC847
EVBC848
Collector - Base Voltage
VCBO
80
50
30
Collector - Emitter Voltage
VCEO
65
45
30
Emitter - Base Voltage
VEBO
6
6
6
Unit
V
Collector Current - Continuous
IC
100
mA
Collector Power Dissipation
PC
200
mW
Junction Temperature
TJ
150
Tstg
-55 to 150
Storage Temperature Range
1
1
EVBC846-EVBC848
■ Electrical Characteristics Ta = 25℃
Parameter
Symbol
Collector- base breakdown voltage
EVBC846
EVBC847
Test Conditions
Min
VCBO
Ic= 100 μA, IE= 0
30
Collector-base cut-off current
VCEO
Ic= 1 mA, IB= 0
45
30
VEBO
VCB= 70 V , IE= 0
ICBO
VCB= 50 V , IE= 0
ICEO
1
uA
nA
VCE= 45 V , IE= 0
VCE= 30 V , IE= 0
EVBC848
Emitter cut-off current
nA
VCE= 60 V , IE= 0
EVBC846
EVBC847
100
VCB= 30 V , IE= 0
EVBC848
Collector- emitter cut-off current
6
IE= 100μA, IC= 0
EVBC846
EVBC847
V
65
EVBC848
Emitter - base breakdown voltage
IEBO
VEB= 5V , IC=0
100
Collector-emitter saturation voltage
VCE(sat)
IC=100 mA, IB=5mA
0.4
Base - emitter saturation voltage
VBE(sat)
IC=100 mA, IB=5mA
1.1
DC current gain
EVBC846A,847A,848A
EVBC846B,847B,848B
VCE= 5V, IC= 2mA
hFE
EVBC846C,847C,848C
Collector output capacitance
110
220
200
450
420
800
VCB= 10V,f= 1 MHz
Cob
Transition frequency
Unit
50
EVBC846
EVBC847
Max
80
EVBC848
Collector- emitter breakdown voltage
Typ
fT
4.5
VCE= 5V, IC= 10mA,f=100MHz
100
V
pF
MHz
■ Classification of hfe
Type
EVBC846A-S1
EVBC846B-S1
EVBC846C-S1
EVBC847A-S1
EVBC847B-S1
EVBC847C-S1
EVBC848A-S1
EVBC848B-S1
EVBC848C-S1
Range
110-220
220-450
420-800
110-220
220-450
420-800
110-220
220-450
420-800
Marking
1A
1B
1C
1E
1F
1G
1J
1K
1L
2
2
EVBC846-EVBC848
■ Typical Characterisitics
Static Characteristic
10
(mA)
8
1000
DC CURRENT GAIN
IC
16uA
6
14uA
12uA
4
IC
COMMON EMITTER
VCE= 5V
Ta=100℃
hFE
20uA
18uA
COLLECTOR CURRENT
hFE
3000
COMMON
EMITTER
Ta=25℃
10uA
8uA
Ta=25℃
100
6uA
2
4uA
IB=2uA
2
3
4
5
COLLECTOR-EMITTER VOLTAGE
VBEsat ——
1000
6
10
7
1
VCEsat
IC
500
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (mV)
800
Ta=25℃
600
Ta=100 ℃
400
1
10
COLLECTOR CURREMT
IC
100
IC
Ta=25℃
1
10
COLLECTOR CURREMT
VBE
IC
Ta=100 ℃
(mA)
fT
500
IC
100
(mA)
IC
T =2
5℃
a
TRANSITION FREQUENCY
10
T =1
00℃
a
COLLECTOR CURRENT
IC
fT
(mA)
(MHz)
COMMON EMITTER
VCE=5V
100
(mA)
100
10
0.1
100
IC
β=20
β=20
200
0.1
10
COLLECTOR CURRENT
VCE (V)
1
100
COMMON EMITTER
VCE=5V
Ta=25℃
0.1
0.2
0.4
0.6
0.8
10
0.25
1.0
2
BASE-EMMITER VOLTAGE VBE (V)
100
Cob/Cib
VCB/VEB
COLLECTOR POWER DISSIPATION
PC (mW)
f=1MHz
IE=0/IC=0
CAPACITANCE
C
(pF)
Cib
Cob
1
0.1
0.1
10
V
30
(mA)
10
12
125
150
Ta
150
100
50
50
75
AMBIENT TEMPERATURE
(V)
8
IC
200
REVERSE VOLTAGE
6
PC
250
Ta=25 ℃
10
4
COLLECTOR CURRENT
100
Ta
3
3
EVBC846-EVBC848
■ SOT-23
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
c
bp
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
4
4
EVBC846-EVBC848
5
很抱歉,暂时无法提供与“BC846B”相匹配的价格&库存,您可以联系我们找货
