DO061B-B
DO061B-B
    SENSATA(森萨塔)
    SIP-4
    固态 SPST-NC(1 Form B) 4-SIP
DO061B-B 数据手册
| DO SERIES PCB MOUNT Features • Mini-SIP SSR • Ratings to 1A @ 60 VDC • Bi-polar Transistor Output • DC Control • Normally Open or Normally Closed Output PRODUCT SELECTION Control Voltage 1A 3-9 VDC DO061A, DO061A-B 1.7-9 VDC DO061B, DO061B-B SPECIFICATIONS Output(1) Description Parameters Operating Voltage Range (47-63Hz) [Vdc] 3-60 Maximum Off-State Leakage Current @ Rated Voltage [µA] 200 Maximum Load Current [Adc] 1.0 Minimum Load Current [Adc] 0.02 Maximum Surge Current [Adc] 5 (1 sec) Maximum On-State Voltage Drop @ Rated Current (2) 1.5 Maximum Power Factor (with Maximum Load) 0.5 Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com Input (1) Description DO061A DO061B Control Voltage Range 3-9 VDC 1.7-9 VDC Must Turn On Voltage 3.0 VDC 1.7 VDC Must Turn Off Voltage 1.0 VDC 0.8 VDC Typical Input Current @ 5 VDC 15 mAdc 15 mAdc Nominal Input Impedance 1800 Ohm 270 Ohm Maximum Turn-On Time [µsec] 50 50 Maximum Turn-Off Time [µsec] 50 150 General Description Parameters Dielectric Strength, Input/Output/Base (50/60Hz) (3) 4000 Vrms Minimum Insulation Resistance (@ 500 VDC) (3) 109 Ohm Maximum Capacitance, Input/Output 8 pF Ambient Operating Temperature Range -30° to 80°C Ambient Storage Temperature Range -30° to 125°C Weight (typical) 0.15 oz. (4.3 g) Encapsulation Thermally Conductive Epoxy WIRING DIAGRAM (4) Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com
DO061B-B 价格&库存
很抱歉,暂时无法提供与“DO061B-B”相匹配的价格&库存,您可以联系我们找货
DO061B-B
  • 1+395.030801+49.17763
  • 10+376.2410010+46.83848
  • 50+359.0796750+44.70205
  • 100+348.53270100+43.38905
库存:89
