新增带济德
料号
LOGO Optional/标志可选
Seal Grommet/防水硅胶
Contacts/端子
Housing/塑胶主体
广东济德精密电子有限公司
新增带济德
料号
Sealing Surface/密封面
PCB Layout
Mounting Panel Size (Maximum Gauge5.0mm)
安装面板尺寸(最大厚度5.0mm)
Section/截面 Z-Z
Optional Construction IF Panel Thickness Is Greater Than 2.0
厚度大于2.0(可选)
Scale/比例:4:1
Sealing Surface/密封面
Key Feature/定位柱
(99X-35X-2001/99X-35X-5067/99X-353-6067)
Section/截面 Z-Z
Optional Construction IF Panel Thickness Is Greater Than 1.0
厚度大于1.0(可选)
Scale/比例:4:1
Key Feature/定位柱 (99X-35X-7067/99X-35X-9067)
广东济德精密电子有限公司
新增带济德
料号
Without JIDC LOGO Material Specification/无济德LOGO物料规格表
NO
Part Number (With Seal)
Part Number (Without Seal)
1
992-351-2002
991-351-2002
2
992-353-2002
991-353-2002
3
992-351-7067
991-351-7067
4
992-353-7067
991-353-7067
Gold
Tin
5
992-351-5067
991-351-5067
6
992-353-5067
991-353-5067
7
992-351-9067
991-351-9067
8
992-353-9067
991-353-9067
9
992-353-6067
991-353-6067
Color
Black
Natural
Gray
Blue
Orange
Connector Plug/连接器插头
Plating
Tin
Gold
Tin
Mounting Panel/安装面板
Gold
Tin
Gold
Gold
Four Mounting Screws/4个安装螺丝
Torque/扭矩0.6N.m-0.8N.m
WITH JIDC LOGO Material Specification/有济德LOGO物料规格表:
NO
1
992-351-2002-1
991-351-2002-1
2
992-353-2002-1
991-353-2002-1
3
992-351-7067-1
991-351-7067-1
4
992-353-7067-1
991-353-7067-1
5
992-351-5067-1
991-351-5067-1
6
992-353-5067-1
991-353-5067-1
7
992-351-9067-1
991-351-9067-1
8
992-353-9067-1
991-353-9067-1
9
992-353-6067-1
991-353-6067-1
Color
Black
Natural
Gray
Blue
Orange
Plating
Tin
Gold
Tin
Gold
Tin
Gold
Tin
Gold
Gold
Flat Panel Mounting/面板安装平整
Performance Parameters/性能参数:
1.Material/材质:
Housing/塑胶主体:PBT UL94-V0
Contacts/端子:Brass/铜合金, Tinned Or Gold Plated/镀锡或镀金
2. Rated Current/额定电流:8A(Tin/镀锡);17A(Au/镀金);Rated Voltage/额定电压:250V AC
3. Operating Temperature/操作温度:-40°C~+105°C (Tin/镀锡);-40°C~+125°C (Au/镀金) ;
4. Insulation Voltage/绝缘耐压:
4.1:Insulation resistance is greater than 100MΩ at 1000V AC/绝缘电阻大于100MΩ;
4.2:Leakage current is less than 50mΩ at 48V DC/在48V DC/电压下漏电流小于50mΩ;
5. Insertion and extraction life cycle is greater than 100 times, insertion and extraction force is
less than 50N after 100 times/插拔寿命大于100次:对插后插拔力小于50N;
6. Meet neutral salt spray test for 48 hours (35±2°C)/满足中性盐雾测试48小时(35±2°C);
7. Mounting screws are 3.0 self-tapping screws with torque range 0.6N.m-0.8N.m/
安装螺钉采用3.0自攻螺丝,扭矩范围0.6N.m-0.8N.m
8. RoHS Compliance /产品符合RoHS.
广东济德精密电子有限公司
很抱歉,暂时无法提供与“992-351-2002-1”相匹配的价格&库存,您可以联系我们找货
