X3501WV-02BS-LPSN
X3501WV-02BS-LPSN
    XKB(中国星坤)
    插件,P=3.5mm
    线对板针座 间距P=3.50mm 2Pin(1x2P) 直插
X3501WV-02BS-LPSN 数据手册
Test Report Client Name: No.: SZXPC23001911107 Date: Aug 21, 2023 Page 1 of 8 GUANGDONG XKB HOLDING CO.LTD Client Address: BUILDING 1, NO.36 XINZHOU MIDDLE STREET, LIN VILLAGE, TANGXIA TOWN, DONGGUAN CITY, GUANGDONG PROVINCE Sample Name: PA66 The above sample(s) and information were provided by the client. ----------------------------------------------------------------------------------------------------------------------------- ---------------SGS Job No.: SZPC2308005156 Sample Receiving Date: Aug 15, 2023 Testing Period: Aug 15, 2023 ~ Aug 21, 2023 Test Requested: Select test(s) as requested by the client. Test Method(s): Please refer to next page(s). Test Result(s): Please refer to next page(s). Test Requirement EU RoHS Directive (EU) 2015/863 amending Annex II to Directive 2011/65/EU- Lead, Mercury, Cadmium, Hexavalent chromium, Polybrominated biphenyls (PBBs), Polybrominated diphenyl ethers (PBDEs), Bis(2-ethylhexyl) phthalate (DEHP), Butyl benzyl phthalate (BBP), Dibutyl phthalate (DBP) and Diisobutyl phthalate (DIBP) Signed for and on behalf of SGS-CSTC Standards Technical Services Co., Ltd. Shenzhen Branch Mescal Ye Approved Signatory Conclusion Pass Test Report No.: SZXPC23001911107 Date: Aug 21, 2023 Page 2 of 8 Test Result(s): Test Part Description: SN ID Sample No. SGS Sample ID SN1 004 SZX23-0019111-0001.C004 Remarks: (1) 1 mg/kg = 1 ppm = 0.0001% (2) MDL = Method Detection Limit (3) ND = Not Detected (< MDL) (4) “-“ = Not Regulated Description Black plastic EU RoHS Directive (EU) 2015/863 amending Annex II to Directive 2011/65/EU- Lead, Mercury, Cadmium, Hexavalent chromium, Polybrominated biphenyls (PBBs), Polybrominated diphenyl ethers (PBDEs), Bis(2-ethylhexyl) phthalate (DEHP), Butyl benzyl phthalate (BBP), Dibutyl phthalate (DBP) and Diisobutyl phthalate (DIBP) Test Method: With reference to IEC 62321-4:2013+AMD1:2017, IEC 62321-5:2013, IEC 62321-7-2:2017, IEC 62321-6:2015 and IEC 62321-8:2017, analysis was performed by ICP-OES, UV-Vis and GC-MS. Test Item(s) Cadmium(Cd) Lead (Pb) Mercury (Hg) Hexavalent Chromium (Cr(VI)) Polybromobiphenyl (PBBs) Monobromobiphenyl (MonoBB) Dibromobiphenyl (DiBB) Tribromobiphenyl (TriBB) Tetrabromobiphenyl (TetraBB) Pentabromobiphenyl (PentaBB) Hexabromobiphenyl (HexaBB) Heptabromobiphenyl (HeptaBB) Octabromobiphenyl (OctaBB) Nonabromobiphenyl (NonaBB) Decabromobiphenyl (DecaBB) Polybromodiphenyl ether(PBDEs) Monobromodiphenylether (MonoBDE) Dibromodiphenylether (DiBDE) Tribromodiphenylether (TriBDE) Tetrabromodiphenylether (TetraBDE) Pentabromodiphenylether (PentaBDE) Hexabromodiphenylether (HexaBDE) Heptabromodiphenylether (HeptaBDE) Octabromodiphenylether (OctaBDE) Nonabromodiphenylether (NonaBDE) Decabromodiphenylether (DecaBDE) Dibutyl Phthalate(DBP) Benzyl Butyl Phthalate(BBP) Limit 100 1000 1000 1000 1000 1000 1000 1000 Unit(s) mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg MDL 2 2 2 8 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 50 50 004 ND 5 ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND ND Test Report No.: SZXPC23001911107 Test Item(s) Bis-(2-ethylhexyl) Phthalate(DEHP) Diisobutyl Phthalate(DIBP) Limit 1000 1000 Date: Aug 21, 2023 Unit(s) mg/kg mg/kg MDL 50 50 Page 3 of 8 004 ND ND Notes: (1) The maximum permissible limit is quoted from RoHS Directive (EU) 2015/863. (2) IEC 62321 series is equivalent to EN 62321 series. (3) The restriction of DEHP, BBP, DBP and DIBP shall apply to medical devices, including in vitro medical devices, and monitoring and control instruments, including industrial monitoring and control instruments, from 22 July 2021. Unless otherwise stated, the decision rule for conformity reporting is based on Binary Statement for Simple Acceptance Rule (w=0) stated in ILAC-G8:09/2019. Test Report No.: Date: SZXPC23001911107 Aug 21, 2023 ATTACHMENTS Elements Testing Flow Chart These samples were dissolved totally by pre-conditioning method according to below flow chart. Sample Preparation Sample Measurement Acid digestion with microwave/ hotplate Filtration Solution Residue 1) Alkali Fusion / Dry Ashing 2) Acid to dissolve ICP-OES/AAS DATA Page 4 of 8 Test Report No.: SZXPC23001911107 Date: Aug 21, 2023 ATTACHMENTS Hexavalent Chromium (Cr(VI)) Testing Flow Chart Sample Preparation Sample Measurement Nonmetallic material ABS/PC/PVC Metallic material Others Boiling water extraction Digesting at 150~160°C Dissolving by ultrasonication Digesting at 60°C by ultrasonication Separating to get aqueous phase Adding 1,5diphenylcarba zide for color development UV-Vis pH adjustment DATA Adding 1,5diphenylcarbazide for color development UV-Vis DATA Page 5 of 8 Test Report No.: SZXPC23001911107 Date: ATTACHMENTS PBBs/PBDEs Testing Flow Chart Sample cutting/preparation Sample measurement Solvent extraction Concentration/ Dilution of extraction solution Filtration GC-MS DATA Aug 21, 2023 Page 6 of 8 Test Report No.: SZXPC23001911107 Date: ATTACHMENTS Phthalates Testing Flow Chart Sample cutting/preparation Sample measurement Solvent extraction Concentration/Dilution Filtration GC-MS DATA Aug 21, 2023 Page 7 of 8 Test Report No.: SZXPC23001911107 Date: Aug 21, 2023 Sample Photo: SZX23-0019111-0001.C004 SGS authenticate the photo on original report only *** End of Report *** Page 8 of 8
X3501WV-02BS-LPSN 价格&库存
很抱歉,暂时无法提供与“X3501WV-02BS-LPSN”相匹配的价格&库存,您可以联系我们找货
