USB2.0 HUB 控制器集成电路
USB 2.0 HIGH SPEED 4-PORT HUB CONTROLLER
SL2.1S
数据手册
Data Sheet
深圳市和芯润德科技有限公司 V1.0
CoreChips ShenZhen CO.,Ltd
内容目录
第一章 管脚分配 ......................................................................................... 3
1.1 SL2.1S 管脚图 ................................................................................................................ 3
1.2 SL2.1S 管脚定义 ............................................................................................................ 4
第二章 功能叙述 ......................................................................................... 5
2.1 综述 ................................................................................................................................. 5
2.2 充电支持 ......................................................................................................................... 5
第三章 电气特性 ......................................................................................... 5
3.1 极限工作条件 ................................................................................................................ 5
3.2 工作范围 ........................................................................................................................ 6
3.3 直流电特性 .................................................................................................................... 6
3.4 HS/FS/LS 电气特性 ........................................................................................................ 6
3.5 ESD 特性......................................................................................................................... 6
附录一 封装 ................................................................................................. 7
表格目录
表格 1: 最大额定值 .................................................................................... 5
表格 2: 工作范围 ........................................................................................ 6
表格 3: 直流电特性 .................................................................................... 7
插图目录
图 1:SL2.1S 管脚图 ................................................................................. 3
图 2:附录 封装图 ................................................................................... .7
深圳市和芯润德科技有限公司 V1.0
第一章 管脚分配
SL2.1S 管脚图
图 1:SL2.1S 管脚图
深圳市和芯润德科技有限公司 V1.0
SL2.1S 管脚定义
管脚名称
16
Pin#
DM2
1
B
DP2
2
B
DM1
3
B
DP1
4
B
UDM
5
B
UDP
6
B
VDD5
7
P
VSS
8
P
VDD33
9
P
VDD18
10
P
XOUT
11
O
XIN
12
I
DM4
13
P
DP4
14
P
DM3
15
B
DP3
16
B
注释:
Die
IO
类型
定义
下行口 2 的USB DM信号
下行口 2 的USB DP信号
下行口 1 的USB DM信号
下行口 1 的USB DP信号
上行口的USB DM信号
上行口的USB DP信号
5v输入
芯片地
内部 3.3v
内部 1.8v
晶振输出
晶振输入
下行口 4 的USB DM信号
下行口 4 的USB DM信号
下行口 3 的USB DM信号
下行口 3 的USB DP信号
,输出;I 输入;B 双向;P 电源/接地;
O
深圳市和芯润德科技有限公司 V1.0
第二章 功能叙述
2.1 综述
SL2.1S 是一颗高集成度,高性能,低功耗的 USB2.0 集线器主控芯片;该芯片
采用 STT 技术,单电源供电方式,芯片供电电压为 5v, 内部集成 5V 转 3.3V,只需
在外部电源添加滤波电容;芯片自带复位电路,低功耗技术让他更加出众。
完美支持 USB2.0 高速(480MHz),USB2.0 全速(12MHz),和低速模式(1.5MHz)
SL2.1S外部需使用12M晶体振荡。
集成 12MHz-to-480MHz PPL(Phase Lock Loop)
采用 Single Transaction Translator (STT)技术,是*TT 系列中最具成本和效率方案
支持自供电到总线供电的自动枚举切换
2.2 充电支持
SL2.1S 支持标准的 BC1.2 充电协议。
第三章 电气特性
3.1 极限工作条件
表格 1: 最大额定值
符号
参数
最小值 最大值 单位
VDDM
Power Supply
-0.5
+5.5
V
VIN
Input Voltage for digital I/O
-0.5
+5.5
V
Input Voltage for USB signal (DP, DM) pins
-0.5
+3.6
V
Storage Temperature under bias
-60
+100
VINUSB
TS
FOSC
Frequency
12 MHz ± 0.05%
深圳市和芯润德科技有限公司 V1.0
3.2 工作范围
符号
参数
表格 2: 工作范围
最小值 典型 最大值 单位
VDD
Power Supply
4.0
5.0
5.25
V
VIND
Input Voltage for digital I/O pins
-0.5
3.3
5.5
V
0.5
3.3
5.25
V
VINUSB
TA
Ambient Temperature
3.3 直流电特性
符号
参数
表格 3: 直流电特性
最小值 典型 最大值 单位
IDD
Supply Current
50
120
mA
ISUS
Suspend Current
2.5
mA
3.4 HS/FS/LS 电气特性
参看 USB2.0 标准。
3.5 ESD 特性
本芯片端口 ESD 能力为±4KV(HBM)。
深圳市和芯润德科技有限公司 V1.0
附录 封装
SL2.1S
SSOP16
图 2:封装尺寸图
深圳市和芯润德科技有限公司 V1.0
很抱歉,暂时无法提供与“SL2.1S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.03434
- 30+1.00009
- 100+0.93159
- 500+0.86309
- 1000+0.82884
