HC-PM200-4.3H-2x4PZ-02A
    HONGCHENG(虹成)
    插件,P=2mm
    排母 间距:2mm 2x4P 直插
HC-PM200-4.3H-2x4PZ-02A 数据手册
SPECIFICATIONS Current Rating: 1.5 Amps Insulation Resistance:1000MΩ Min Contact Resistance: 20mΩ Max Withstanding Voltage: AC 500V Operation Temperature:-40°to+105° Contact Material: Brass Standard: PA6T Insrlator Material: Polyester Contact Plating: Gold Flash Max.Processing Temp: 240°C for30-60seconds (260°C for 5 seconds) RECOMMEND P.C.B LAYOUT PCB TOLERANCE:±0.05 (TOP VIEW) PIN 0.5X0.2 深圳市虹成电子有限公司 UNLESS OTHEWIXE SPECIFIED TOLERANCE X :±0.3 X.X :±0.2 X.XX:±0.1 X° :±5° X.X° :±1° X.XX°:±0.5° CHECKED: LI BEI LIN 12/03/07 DRAWM NAME: SIZE REV A4 A CHECKED: 2.0FH 2xnPin H4.3 DIP SCALE PROUCT NO. UNIT PROJECT / / HC-PM200-4.3H-2x14PZ APPROVED: PAGE 1/1 / / No. of DIM.A 1 0.00 DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B
HC-PM200-4.3H-2x4PZ-02A 价格&库存
很抱歉,暂时无法提供与“HC-PM200-4.3H-2x4PZ-02A”相匹配的价格&库存,您可以联系我们找货
  • 10+0.63953
  • 100+0.59827
  • 500+0.55701
  • 2000+0.49512
  • 5000+0.47449
  • 10000+0.46211
库存:80
