MBRD20100
MBRD20100
    MDD(辰达半导体)
    TO-252
    肖特基势垒整流器,采用TO - 252封装,低反向泄漏,高正向浪涌电流能力
MBRD20100 数据手册
MBRD2045 THRU MBRD20200 Reverse Voltage - 45 to 200 Volts Forward Current - 20.0 Ampere SCHOTTKY BARRIER RECTIFIER Features TO-252(D-PAK)  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Construction utilizes void-free molded plastic technique  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 250°C,0.25”(6.35mm) from case for 10 seconds 4 2 1 3 2=4 Mechanical Data Case: TO-252 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.0141 ounce(approx), 0.4 grams (approx) 3 1 Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current (see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 10A Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ VRRM V RMS V DC MDD MBRD 2045 MDD MBRD 2060 MDD MBRD 20100 MDD MBRD 20150 150 105 150 45 60 100 32 45 42 60 70 100 I(AV) 20.0 IFSM 150 VF 0.65 0.75 IR 200 140 200 V V V A 0.90 0.05 15.0 UNITS A 0.85 1.0 MDD MBRD 20200 20.0 15.0 1.5 0.92 V mA Typical thermal resistance (NOTE 2) R θ JC Operating junction temperature range TJ -55 to +150 ℃ T STG -55 to +150 ℃ storage temperature range 2.0 ℃/W Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to case. http://www.microdiode.com Rev:2025A5 Page :1 MBRD2045 THRU MBRD20200 Reverse Voltage - 45 to 200 Volts Forward Current - 20.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics 20 15 ~2 00 10 V 5 0.0 20 40 60 80 100 120 140 160 180 Instaneous Reverse Current ( mA) 25 45 Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 100 45~60V 100~200V 10 T J =100°C 1.0 0.1 T J =25°C 0.01 0.001 0 Case Temperature (°C) 10 1 45V 60V 100V 150V 200V 0.1 0.2 0.4 0.6 0.8 60 80 100 1.0 Instaneous Forward Voltage (V) Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) Instaneous Forward Current (A) T J =25°C 0 40 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic(per leg) 20 20 1.2 160 140 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2025A5 Page :2 MBRD2045 THRU MBRD20200 Reverse Voltage - 45 to 200 Volts Forward Current - 20.0 Ampere Outlitne TO-252(D-PAK) Package Outline Dimensions A B C E L1 + D M N S L2 L L3 b G UNIT H G F TO-252(D-PAK) mechanical data A B b C D E F max 6.7 5.53 0.86 2.5 6.3 0.6 1.8 min 6.3 5.1 0.66 2.1 5.9 0.4 1.3 mm G 2.29 TYPICAL H L L1 L2 L3 S M N 0.60 3.4 1.2 1.0 1.75 0.15 1.98 1.3 0.40 2.7 0.8 0.6 1.40 0.0 1.58 1.2 Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A5 Page :3
MBRD20100 价格&库存
很抱歉,暂时无法提供与“MBRD20100”相匹配的价格&库存,您可以联系我们找货
MBRD20100
  • 5+1.29212
  • 50+1.01283
  • 150+0.89309
  • 500+0.74380
  • 2500+0.67728
  • 5000+0.63737
库存:865
