MURD1020D THRU MURD1060D
Reverse Voltage -200 -600 Volts Forward Current - 10.0 Ampere
FAST RECOVERY EPI DIODES
TO-252(D-PAK)
FEATURES
4
High frequency operation
High surge forward current capability
High purity, high temperature epoxy encapsulation
for enhanced mechanical strength and moisture
resistance
Guard ring for enhanced ruggedness and long
term reliability
2=4
2
1
3
1
3
MECHANICAL DATA
Case: TO-252 molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0141 ounce(approx), 0.4 grams (approx)
PACKAGE SPECIFICATIONS
Package Reel Size
TO-252
13'
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
330
2500
340×336×29
2500
Carton Size Q'TY/Carton
(mm)
(pcs)
353×346×365
25000
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MCHARACTERISTICS
SYMBOL
MDD
MURD1020D
MDD
MDD
MURD1040D MURD1060D
200
400
600
140
200
280
400
420
600
UNITS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
Maximum average forward rectified current
I(AV)
10
A
IFSM
50
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Maximum Reverse Recovery Time
VDC
VF
IR
CJ
Trr
Typical thermal resistance (NOTE 2)
RθJA
Operating junction and storage temperature range
TJ,TSTG
Note:1.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C.
2.Mounted on 10cm x 10cm x 1mm copper pad area
3. The typical data above is for reference only.
https://www.microdiode.com
1.0
1.3
10
100
45
35
50
-55 to +175
Rev:2025A2
1.6
V
V
V
V
uA
pF
ns
℃/W
Page :1
Rating and Characteristic Curves
Fig.2 Typical Reverse Characteristics
10
8.0
6.0
4.0
2.0
RESISTIVE OR INDUCTIVE LOAD
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current ( mA)
Average Forward Current (A)
Fig.1 Typical Forward Current Derating Curve
10
1.0
T J =125°C
0.1
0.01
T J =25°C
0.001
0.0001
Case Temperature (°C)
Peak Forward Surage Current (A)
0V
60
0V
40
0V
1.0
Instaneous Forward Current (A)
T J =25°C
0.1
1.0
60
80
100
Fig.4 Maximum Non-Repetitive Peak
10
0.5
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
0.01
Instaneous Forward Voltage (V)
2.0
180
150
120
90
60
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
The curve above is for reference only.
Rev:2025A2
Page :2
Outlitne Drawing
TO-252(D-PAK) Package Outline Dimensions
A
B
C
E
L1
D
M
N
S
L2
L
L3
b
G
UNIT
H
G
F
TO-252(D-PAK) mechanical data
A
B
b
C
D
E
F
max
6.7
5.53
0.86
2.5
6.3
0.6
1.8
min
6.3
5.1
0.66
2.1
5.9
0.4
1.3
mm
G
2.29
TYPICAL
H
L
L1
L2
L3
S
M
N
0.60
3.4
1.2
1.0
1.75
0.15
1.98
1.3
0.40
2.7
0.8
0.6
1.40
0.0
1.58
1.2
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A2
Page :3
很抱歉,暂时无法提供与“MURD1060D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.53198
- 50+1.24589
- 150+1.12320
- 500+0.97028
- 2500+0.69952
- 5000+0.65859
