ES2AB THRU ES2JB
Reverse Voltage - 50 to 600 Volts
Forward Current - 2.0 Ampere
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated
placement High forward surge current capability
High temperature soldering guaranteed:
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.185(4.70)
0.160(4.06)
0.012(0.305)
0.006(0.152)
250°C/10 seconds at terminals
Glass passivated chip junction
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003 ounce, 0.095 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=55℃
ES2AB
ES2BB ES2CB ES2DB
ES2EB ES2GB
ES2JB
MDD
ES2AB
MDD
MDD
MDD
MDD
MDD
ES2BB ES2CB ES2DB ES2EB ES2GB
MDD
ES2JB
VRRM
VRMS
VDC
I(AV)
50
35
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
UNITS
V
V
V
2.0
A
50
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 2.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
IR
5.0
100.0
uA
trr
35
ns
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
1
1.25
1.70
V
CJ
60.0
pF
Typical thermal resistance (NOTE 3)
RJA
40.0
℃/W
Operating junction and storage temperature range
TJ,TSTG
-55 to +150
Typical junction capacitance (NOTE 2)
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Pulse test: Pulse width 200 sec, Duty cycle 2%
4.High Temperature Solder Exemptions Applied, see EU Directive Annex 7.
DN:T20518A0
http://www.microdiode.com
Rev:2020A0
Page :1
ES2AB THRU ES2JB
Ratings And Characteristic Curves
t rr
10 ohm
Noninductive
50 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.5
300
3.0
100
I R - Reverse Current (μA)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
Case Temperature (°C)
10
T J =25°C
1.0
ES2AB~ES2DB
ES2EB/ES2GB
ES2JB
0.01
0.001
1.0
1.5
80
100
Fig.5 Typical Junction Capacitance
Junction Capacitance (pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
0.1
60
% of PIV.VOLTS
2.0
2.5
Instaneous Forward Voltage (V)
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surge Current (A)
Fig.6 Maximum Non-Repetitive Peak
80
70
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2020A0
Page :2
ES2AB THRU ES2JB
Packing information
P0
P1
unit:mm
d
E
Item
F
B
A
Symbol
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMB
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
13"
3,000
4.0
INNER
BOX
(mm)
REEL
DIA,
(mm)
CARTON
SIZE
(mm)
CARTON
(pcs)
190*190*41
330
365*365*360
48,000
BOX
(pcs)
6,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2020A0
Page :3
很抱歉,暂时无法提供与“ES2JB 框架”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.23253
- 50+0.17939
- 150+0.14980
- 500+0.13209
- 3000+0.11675
- 6000+0.10844
