SI2306
SOT-23 Plastic-Encapsulate MOSFETS
30V N-Channel MOSFET
V(BR)DSS
30V
SOT-23
RDS(on)Typ
ID Max
28mΩ@10V
5.0A
38mΩ@4.5V
3
1. GATE
2. SOURCE
1
3. DRAIN
2
APPLICATION
Load Switch for Portable Devices
z
DC/DC Converter
z
FEATURE
z Trench FET Power MOSFET
MARKING
Equivalent circuit
D
A6sHB
G
S
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-23
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
178
3000
203×203×195
45000
7'
Carton Size Q'TY/Carton
(mm)
(pcs)
438×438×220
180000
Maximum Ratings and Thermal Characteristics (TA = 25°C unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
30
Gate-Source Voltage
VGS
±20
TA = 25 oC
Continuous Drain Current
T = 70oC
Maximum Power Dissipation
1) ,2)
TA = 25 C
T = 70oC
6WRUDJH7HPSHUDWXUH5DQJH
Thermal Resistance from Junction-to-Ambient (t≤5s)
A
20.4
1.5
PD
W
0.9
A
0D[LPXP Junction 7HPSHUDWXUH
A
4
IDM
o
V
5.0
ID
A
Pulsed Drain Current 1)
Unit
TJ
150
o
Tstg
-50 to 150
o
80
RθJA
C
C
o
C/W
Notes
1) Pulse width limited by maximum junction temperature.
2) Surface Mounted on FR4 Board, t v 5 sec.
The above data are for reference only.
DN:T200218A0
http://www.microdiode.com
Rev:2020A0
Page :1
SI2306
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Static
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID=250µA
Gate-body leakage
IGSS
VGS=±20V, VDS=0V
±100
nA
Zero gate voltage drain current
IDSS
VDS =30V, VGS =0V
1
µA
VDS =24V, VGS =0V
100
µA
Gate-threshold voltage (note 1)
VGS(th)
1.6
2.5
V
Ddrain-source on-resistance (note 1)
RDS(on)
VGS =10V, ID =4A
28
36
VGS =4.5V, ID =3A
38
50
V
30
1.0
VDS =VGS, ID =250μA
7
gFS
VDS =4.5V, ID =2.5A
Gate Resistance
Rg
f=1MHz
Total Gate C harge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
1.3
Input capacitance
Ciss
240
Output capacitance
Coss
Reverse transfer capacitance
Crss
30
td(on)
4.4
Forward transconductance (note 1)
mΩ
S
Dynamic characteristics
2.5
5
7.5
Ω
6
VDS =15V,ID=4A,VGS =10V
nC
0.5
VDS =15V,VGS =0V, f=1MHz
pF
35
Switching characteristics
Turn-on delay time
Rise time
Turn-off delay time
Fall time
tr
td(off)
VDD=15V, VGS=10V,
2.6
ID =1A,RG=3.3Ω
25.5
tf
ns
3.3
Drain-source body diode characteristics
Source drain current(Body Diode)
ISD
Body diode forward voltage (note 1)
VSD
0.85
ISD=4A, VGS = 0V
1.8
A
1.2
V
Notes :
Pulse Test : Pulse Width≤ 300µs, Duty Cycle≤ 2 %.
1.
Rev:2020A0
Page :2
SI2306
ID, Drain-Source Current (A)
VGS(TH), Gate -Source Voltage (V)
Typical Characteristics
VDS, Drain -Source Voltage (V)
Fig2. Normalized Threshold Voltage Vs. Temperature
Rdson, On -Resistance (mΩ))
Fig1. Typical Output Characteristics
Tj - Junction Temperature (°C)
VGS, Gate -Source Voltage (V)
ID , Drain Current (A)
Fig4. On-Resistance vs. Drain Current and Gate
-ID - Drain Current (A)
ISD, Reverse Drain Current (A)
Fig3. Typical Transfer Characteristics
VSD, Source-Drain Voltage (V)
Fig5. Typical Source-Drain Diode Forward Voltage
Fig6. Maximum Safe Operating Area
Rev:2019A0
Page :3
SI2306
C, Capacitance (pF)
VGS, Gate-Source Voltage (V)
VDS, Drain-Source Voltage (V)
Fig8. Typical Gate Charge Vs. Gate-Source Voltage
Thermal Resistance
ZqJA Normalized Transient
Fig7. Typical Capacitance Vs. Drain-Source Voltage
Qg, Total Gate Charge (nC)
Pulse Width (s)
Fig9. Normalized Maximum Transient Thermal Impedance
Fig10. Switching Time Test Circuit and waveforms
Rev:2020A0
Page :4
SI2306
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.4
0°
0.55
10°
Note:
1.
Controlling
dimension:in/millimeters. 2.General
tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2020A0
Page :5
很抱歉,暂时无法提供与“MDD2306”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.24171
- 100+0.19192
- 300+0.16416
- 3000+0.13792
- 6000+0.12356
- 9000+0.11578
- 国内价格
- 20+0.51590
- 100+0.30770
- 800+0.21540
- 3000+0.15390
- 6000+0.14620
- 30000+0.13540
