ESD2105L
ESD2105L
    MDD(辰达半导体)
    SOT-23
ESD2105L 数据手册
ESD2105L Dual Line CAN Bus Protector SOT-23 Plastic-Encapsulate CAN bus ESD Protection Diodes DESCRIPTION The ESD2105L has been designed to protect the CAN transceiver in high-speed and fault tolerant networks from ESD and other harmful transient voltage events. This device provides bidirectional protection for each data line with a single compact SOT-23 package, giving the system designer a low cost option for improving system reliability and meeting stringent EMI requirements. Features  350 Watts Peak Pulse Power per (8/20μs)  Transient protection for asymmetrical data lines to IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC61000-4-4 (EFT) 40A (5/50ns) IEC61000-4-5 (Lightning) 8A (8/20μs)  Working voltages : 24V  Low leakage current  Low clamping voltage  Meets MSL 1 Requirements Applications      Industrial Control Networks Smart Distribution Systems Automotive Networks Low and High-Speed CAN Fault Tolerant CAN Pin Configuration Circuit Diagram Mechanical Characteristics Package: SOT-23 Flammability Rating: UL 94V-0 Terminal: Matte tin plated. High temperature soldering guaranted: 260℃/10s  Marking: 27E  Packaging: Tape and Reel     Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Peak Pulse Power(8/20us ) Symbol Value Unit PPP 350 W VESD ± 30 ± 30 KV Operating Temperature TOPT −55 to +150 °C Storage Temperature TSTG −55 to +150 °C TL 260(10 sec.) °C ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Lead Solder Temperature – Maximum (10 Second Duration) The above data are for reference only. DN:T21B15A1 http://www.microdiode.com Rev:2021A1 Page :1 ESD2105L Dual Line CAN Bus Protector Electrical Characteristics (TA=25°C unless otherwise specified) Symbol Parameter Test Condition VRWM Reverse Working Voltage Pin 1,2 to Pin3 VBR Reverse Breakdown Voltage IR Reverse Leakage Current VC1 Clamping Voltage 1 IT = 1mA Pin 1,2 to Pin3 VRWM = 24V Pin 1,2 to Pin3 IPP = 1A, tp = 8/20μs Pin 1,2 to Pin3 VC2 Clamping Voltage 2 IPP = 5A, tp = 8/20μs Pin 1,2 to Pin3 CJ Junction Capacitance VR = 0V, f = 1MHz Pin 1,2 to Pin3 Min Typ 26.2 15 25 Max Units 24 V 32 V 100 nA 36 V 46 V 30 pF The above data are for reference only. http://www.microdiode.com Rev:2021A1 Page :2 ESD2105L Dual Line CAN Bus Protector ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2021A1 Page :3 ESD2105L Dual Line CAN Bus Protector Outlitne Drawing SOT-23 Package Outline Dimensions e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 0.89 1.40 1.00 0.10 0.06 0.01 0.37 0.50 0.44 0.20 0.09 0.13 3.10 2.80 2.90 1.20 1.60 1.30 2.40 2.10 2.80 1.78 2.04 1.90 0.30 0.10 0.69 0.35 0.54 0° 10° Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 http://www.microdiode.com inches mm Rev:2021A1 Page :4 ESD2105L Dual Line CAN Bus Protector SOT-23 Tape and Reel Packaging Description: SOT-23 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 3,000 units per 7" or 17.8cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). 3000 pcs http://www.microdiode.com 7 Inch 45,000 pcs 203×203×195 180,000 pcs 438×438×220 Rev:2021A1 Page :5
ESD2105L 价格&库存
很抱歉,暂时无法提供与“ESD2105L”相匹配的价格&库存,您可以联系我们找货
ESD2105L
  • 20+1.03140
  • 100+0.61520
  • 800+0.43070
  • 3000+0.30760
  • 6000+0.29220
  • 30000+0.27070
