SI2300
SOT-23 Plastic-Encapsulate MOSFETS
20V N-Channel Advanced Power MOSFET
V(BR)DSS
3
19.4mΩ @ 4.5V
20V
SOT-23
ID
RDS(on)MAX
6.2A
21.5mΩ @ 3.3V
1. GATE
2. SOURCE
3. DRAIN
FEATURE
z
z
1
2
APPLICATION
Low RDS(on) @VGS=4.5V
z
3.3V Logic Level Control
z
Load Switch
DC/DC Converter
Switching Circuits
Power Management
z
z
Equivalent circuit
MARKING
D
2300
G
S
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-23
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
203×203×195
45000
438×438×220
180000
7'
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Limit
Drain-Source Voltage
V(BR)DSS
Gate-Source Voltage
VGS
TA=25℃
Continuous Drain Current
Maximum Power Dissipation
TA=70℃
TA=25℃
2)
TA=70℃
V
±10
6.2
ID
A
4.3
1.56
PD
W
0.9
IDM
Pulsed Drain Current 1)
Unit
24.8
A
Maximum Junction Temperature
TJ
150
o
Storage Temperature Range
Tstg
-50 to 150
o
Thermal Resistance Junction-Ambient
RθJA
80
C
C
o
C/W
Notes
1) Pulse width limited by maximum junction temperature.
2) Surface Mounted on FR4 Board, t v 5 sec.
DN:T200108A0
http://www.microdiode.com
The above data are for reference only.
Rev:2020A0
Page :1
SI2300
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Off characteristics
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID=250µA
Gate-body leakage
IGSS
VGS=±10V, VDS=0V
Zero gate voltage drain current
IDSS
V
±100
nA
VDS =16V, VGS =0V
1
µA
VDS =16V, VGS =0V
100
µA
0.6
1.0
V
VGS =4.5V, ID =4A
19.4
25
VGS =3.3V, ID =3A
21.5
28
On characteristics
Gate-threshold voltage (note 1)
VGS(th)
Static drain-source on-resistance (note 1)
RDS(on)
0.45
VDS =VGS, ID =250μA
gFS
VDS =10V, ID =0.25A
Gate Resistance
Rg
f=1MHz
Total Gate C harge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
2
Input capacitance
Ciss
457
Output capacitance
Coss
Reverse transfer capacitance
Crss
66
td(on)
4.1
Forward transconductance (note 1)
100
mΩ
mS
Dynamic characteristics (note 2)
Ω
7.8
6.6
VDS =10V,ID=4A,VGS =4.5V
nC
0.4
VDS =10V,VGS =0V, f=1MHz
pF
71
Switching characteristics
Turn-on delay time (note 1,2)
Rise time (note 1,2)
Turn-off delay time (note 1,2)
Fall time (note 1,2)
VDD=10V, VGS=4.5V,
tr
11.6
ID =1A,RG=3.3Ω
td(off)
ns
24
tf
7.6
Drain-source body diode characteristics
Source drain current(Body Diode)
ISD
Body diode forward voltage (note 1)
VSD
0.79
ISD=4A, VGS = 0V
0.2
A
1.2
V
Notes :
1. Pulse Test : Pulse Width≤ 300µs, Duty Cycle≤ 2%.
2.
These parameters have no way to verify.
Rev:2020A0
Page :2
SI2300
ID, Drain-Source Current (A)
VGS(TH), Gate -Source Voltage (V)
Typical Characteristics
VDS, Drain -Source Voltage (V)
Tj - Junction Temperature (°C)
Fig2. VGS(TH) Voltage Vs. Temperature
Rdson, On -Resistance (mΩ))
Fig1. Typical Output Characteristics
Fig3. Typical Transfer Characteristics
Fig4. On-Resistance vs. Drain Current and Gate
-ID - Drain Current (A)
ID , Drain Current (A)
ISD, Reverse Drain Current (A)
VGS, Gate -Source Voltage (V)
VSD, Source-Drain Voltage (V)
Fig5. Typical Source-Drain Diode Forward Voltage
Fig6. Maximum Safe Operating Area
The curve above is for reference only.
Rev:2019A0
Page :3
SI2300
C, Capacitance (pF)
VGS, Gate-Source Voltage (V)
VDS, Drain-Source Voltage (V)
Fig8. Typical Gate Charge Vs. Gate-Source Voltage
Thermal Resistance
ZqJA Normalized Transient
Fig7. Typical Capacitance Vs. Drain-Source Voltage
Qg, Total Gate Charge (nC)
Pulse Width (s)
Fig9. Normalized Maximum Transient Thermal Impedance
Fig10. Switching Time Test Circuit and waveforms
Rev:2020A0
Page :4
SI2300
Outlitne Drawing
SOT-23 Package Outline Dimensions
L
L1
E
E1
θ
1
e
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.4
0°
0.55
10°
Suggested Pad Layout
0.037
0.95
0.037
0.95
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2020A0
Page :5
很抱歉,暂时无法提供与“MDD2300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.43355
- 200+0.14375
- 1500+0.09028
- 3000+0.07176
