MBRD1040T(D) THRU MBRD10200T(D)
Reverse Voltage -40 to 200 Volts Forward Current - 10.0 Ampere
SCHOTTKY BARRIER GLASS PASSIVATED RECTIFIERS
TO-252(D-PAK)
TO-251(I-PAK)
FEATURES
High current capability
Low forward voltage drop
Low power loss, high efficiency
High surge capability
High temperature soldering guaranteed
Mounting position: any
MECHANICAL DATA
Case: TO-251/252 molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0141 ounce(approx), 0.4 grams (approx)
PACKAGE SPECIFICATIONS
Package Reel Size
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
TO-251
13'
330
2500
340×336×29
2500
353×346×365
25000
TO-252
13'
330
2500
340×336×29
2500
353×346×365
25000
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
TO-251
MCHARACTERISTICS
TO-252
MBRD
1040T
MBRD
1040D
MBRD
1045T
MBRD
1045D
MBRD
1060T
MBRD
1060D
MBRD
10100T
MBRD
10100D
MBRD
10150T
MBRD
10150D
MBRD
10200T
MBRD
10200D
UNITS
40
28
40
45
31.5
45
60
42
60
100
70
100
150
105
150
200
140
200
V
V
V
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
Maximum average forward rectified current
I(AV)
10.0
A
IFSM
100
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
VF
RθJA
TJ,TSTG
0.90
0.1
IR
CJ
0.85
0.75
0.70
600
400
0.92
0.05
-55 to +150
-55 to +175
V
mA
pF
℃/W
Note:1.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C.
2.Mounted on 10cm x 10cm x 1mm copper pad area
3. The typical data above is for reference only.
DN:21310A1
https://www.microdiode.com
Rev:2021A1
Page :1
Rating and Characteristic Curves
Fig.2 Typical Reverse Characteristics
8.0
6.0
15
0~
0V
~1
4.0
V
2.0
0.0
60
80
100 120 140 160 180
Instaneous Reverse Current ( mA)
10
40
Average Forward Current (A)
Fig.1 TYPICAL FORWARD CURRENT DERATING CURVE
100
40~100V
150~200V
10
T J =100°C
1.0
0.1
0.01
0.001
Case Temperature (°C)
60
80
10
1
40~45V
60V
100V
150V
200V
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1000
500
100
40~45V
60~200V
10
1.6
0.1
140
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C /W)
160
1
10
1
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
T J =25°C
T J =25°C
Junction Capacitance (pF)
Instaneous Forward Current (A)
40
Fig.4 Typical Junction Capacitance
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
T J =25°C
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2021A1
Page :2
Outlitne Drawing
TO-252(D-PAK) Package Outline Dimensions
Rev:2021A1
Page :3
Outlitne Drawing
TO-251(I-PAK) Package Outline Dimensions
Rev:2021A1
Page :4
很抱歉,暂时无法提供与“MBRD10100T”相匹配的价格&库存,您可以联系我们找货
