SF501ET(D) THRU SF506ET(D)
Reverse Voltage -100 to 600 Volts Forward Current - 5.0 Ampere
SUPER FAST GLASS PASSIVATED RECTIFIERS
TO-252(D-PAK)
TO-251(I-PAK)
FEATURES
High current capability
Low forward voltage drop
Low power loss, high efficiency
High surge capability
High temperature soldering guaranteed
Mounting position: any
MECHANICAL DATA
Case: TO-251/252 molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0141 ounce(approx), 0.4 grams (approx)
PACKAGE SPECIFICATIONS
Package Reel Size
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
TO-251
13'
330
2500
340×336×29
2500
353×346×365
25000
TO-252
13'
330
2500
340×336×29
2500
353×346×365
25000
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
TO-251
MCHARACTERISTICS
TO-252
SF
501ET
SF
501ED
SF
502ET
SF
502ED
SF
504ET
SF
504ED
SF
505ET
SF
505ED
SF
506ET
SF
506ED
UNITS
100
70
100
SF
503ET
SF
503ED
200
140
200
300
210
300
400
280
400
500
350
500
600
420
600
V
V
V
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
Maximum average forward rectified current
I(AV)
5.0
A
IFSM
150
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A DC
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Maximum Reverse Recovery Time(Note3)
Operating junction and storage temperature range
VF
IR
CJ
RθJA
Trr
TJ,TSTG
0.95
1.25
1.0
300
45
15
35
-55 to +150
1.70
V
uA
pF
℃/W
ns
Note:1.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C.
2.Mounted on 10cm x 10cm x 1mm copper pad area
3. Reverse Recovery Test Conditions:IF=0.5A,IR=1A,Irr=0.25A
4. The typical data above is for reference only.
DN:T18B02A0
https://www.microdiode.com
Rev:2018A0
Page :1
Rating and Characteristic Curves
FIG.2 - MAXIMUM NON-REPETITIVE
PEAK FORWARD SURGE CURRENT
160
5
4
3
2
1
RESISTIVE OR INDUCTIVE LOAD
50
75
125
100
150
175
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD CURRENT, (A)
FIG.1 - FORWARD CURRENT DERATING CURVE
8.3ms Single Half Since-Wave
JEDEC Method
140
120
100
80
60
40
o
CASE TEMPERATURE, C
1
2
5
10
100
NUMBER OF CYCLES AT 60Hz
FIG.4 - TYPICAL REVERSE CHARACTERISTICS
10
1000
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
IINSTANTANEOUS FORWARD CURRENT,
AMPERES
FIG.3 - TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
100V~200V
300V~400V
1.0
500V~600V
0.1
o
TJ=25 C
PULSE WIDTH=300uS
1% DUTY CYCLE
0.01
0.4
0.6
0.8
1.0
1.2
1.4
1.6
O
10
O
TJ= 25 C
1.0
1.8
0.1
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ= 125 C
100
60
80
100
120
PERCENT OF RATED PEAK REVERSE VOLTAGE,%
FIG.5 - TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
80
70
60
50
40
30
2
5
10
500
REVERSE VOLTAGE, VOLTS
The curve above is for reference only.
Rev:2018A0
Page :2
Outlitne Drawing
TO-252(D-PAK) Package Outline Dimensions
Rev:2018A0
Page :3
Outlitne Drawing
TO-251(I-PAK) Package Outline Dimensions
Rev:2018A0
Page :4
很抱歉,暂时无法提供与“SF506ED”相匹配的价格&库存,您可以联系我们找货
