SM4001--SM4007
SURFACE MOUNT RECTIFIERS
FEATURES
REVERSE VOLTAGE: 50 - 1000 V
CURRENT: 1.0 A
DO - 213AB
◇ Glass passivated device
◇ Ideal for surface mouted applications
◇ Low leakage current
◇ Metallurgically bonded construction
SOLDERABLE ENDS
D2=D1 +
-0.20
D1 2.6± 0.15
MECHANICAL DATA
◇ Case:JEDEC DO-213AB,molded plastic over
passivated chip
◇ Terminals:Solder Plated, solderable per
MIL-STD-750, Method 2026
◇ Polarity: Color band denotes cathode end
◇ Weight: 0.0046 ounces, 0.116 gram
◇ Mounting position: Any
D2
0.5± 0.1
0.5± 0.1
4.9± 0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified.
Single phase,half wave,60Hz,resistive or inductive load.For capactive load,derate current by 20%.
SM
Maximum recurrent peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forword
rectified current
T A=75℃
VRRM
VRMS
VDC
SM
SM
SM
SM
SM
4001 4002 4003
4004
4005
4006
4007
50
100
200
400
600
800
1000
35
70
140
280
420
560
700
50
100
200
400
600
800
1000
SM
UNITS
V
V
V
I(AV)
1.0
A
IFSM
30
A
VF
1.1
V
Peak forward surge current 8.3ms single
half-sine-wave superimposed
on rated load (JEDEC method)
Maximum forward voltage at 1.0A
Maximum DC reverse current
@TA=25℃
at rated DC blockjing voltage @T A=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance
(NOTE 2)
(NOTE 3)
Operating temperature range
Storage temperature range
5.0
IR
Cj
RjθL
RjθA
Tj
TSTG
50
15
- 55 --- + 175
- 55 --- + 175
NOTES:1. Measured at 1.0MHz and applied average voltage of 4.0V DC.
2. Thermal resistance junction to lead, 6.0 mm 2 coppeer pads to each terminal.
3. Thermal resistance junction to ambient, 6.0 mm 2 coppeer pads to each terminal.
μA
pF
℃/W
℃/W
SM4001--SM4007
1.0
.8
.6
.4
Single Phase
Half Wave 60Hz
Resistive or
Inductive Load
.2
50
75
FIG. 2 - MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
PEAK FORWARD SURGE CURRENT, (A)
AVERAGE FORWARD CURRENT, (A)
FIG. 1 - TYPICAL FORWARD CURRENT
DERATING CURVE
100 125 150 175
AMBIENT TEMPERATURE, ( )
50
40
30
1
INSTANTANEOUS REVERSE CURRENT, (uA)
T J = 25
.1
Pulse Width = 300us
1% Duty Cycle
1.0
1.2
1.4
1.6
60 80 100
.4
.1
.04
TJ = 25
.01
60
40
TJ = 25
2
1
.2 .4
40
TJ = 100
1.0
200
.1
FIG. 5 - TYPICAL JUNCTION CAPACITANCE
10
6
4
6 8 10
1.0 2
40
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE, (%)
INSTANTANEOUS FORWARD VOLTAGE, (V)
JUNCTION CAPACITANCE, (pF)
INSTANTANEOUS FORWARD CURRENT, (A)
1.0
.8
4
FIG. 4 - TYPICAL REVERSE CHARACTERISTICS
10
.6
2
NUMBER OF CYCLES AT 60Hz
FIG. 3 - TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
.01
.4
8.3ms Single Half Sine-Wave
(JEDED Method)
10
20 40
REVERSE VOLTAGE, ( V )
100
很抱歉,暂时无法提供与“SM4003”相匹配的价格&库存,您可以联系我们找货
