LB05S THRU LB10S
MINIATURE GLASS PASSIVATED SINGLE-PHASE SURFACE MOUNT BRIDGE RECTIFIER
REVERSE VOLTAGE: 50 to 1000 VOLTS
FORWARD CURRENT: 0.5 AMPERE
LBXS
FEATURES
· Surge overload rating: 30 amperes peak
· Ideal for printed circuit board
· Plastic material has Underwriters Laboratory
Flammability Classification 94V-0
· Low leakage
· Reliable low cost construction utilizing molded
MECHANICAL DATA
Case: Molded plastic, LBXS
Epoxy: UL 94V-O rate flame retardant
Terminals: Leads solderable per MIL-STD-202,
method 208 guaranteed
Dimensions in inches and (millimeters)
Mounting position: Any
Weight: 0.00528ounce, 0.134gram
Maximum Ratings and Electrical Characteristics
Ratings at 25 ℃ ambient temperature unless otherwise specified.
Single phase, half wave, 60H Z, resistive or inductive load.
LB05S
LB1S
LB2S
LB4S
LB6S
LB8S
LB10S
Units
Maximum Recurrent Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
Volts
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
700
Volts
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
Volts
Maximum Average Forward Rectified Current
(see Fig. 1)
on glass-epoxy P.C.B (Note 2)
I(AV)
on aluminum substrate (Note 3)
0.5
Amp
0.8
Peak Forward Surge Current,
8.3ms single half-sine-wave
IFSM
30
Amp
VF
1.0
Volts
superimposed on rated load (JEDEC method)
Maximum Forward Voltage
at 0.4A DC and 25℃
Maximum Reverse Current
at TA=25℃
at Rated DC Blocking Voltage
T A=125℃
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance (Note 3)
Typical Thermal Resistance (Note 2)
Operating and Storage Temperature Range
IR
5.0
500
uAmp
CJ
13
pF
RθJA
60
℃/W
RθJL
16
℃/W
TJ,Tstg
-55 to +150
NOTES:
1- Measured at 1 MHZ and applied reverse voltage of 4.0 VDC.
2- On glass epoxy P.C.B. mounted on 0.05 x 0.05" (1.3 x 1.3mm) pads
3- On aluminum substrate P.C.B. with an area of 0.8" x 0.8" (20 x 20mm) mounted on 0.05 x 0.05" (1.3 x 1.3mm) solder pad
Characteristic Curves (TA=25 ℃ unless otherwise noted)
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
很抱歉,暂时无法提供与“LB10S”相匹配的价格&库存,您可以联系我们找货
