(6'=5.0C
7UDQVLHQW9oOWDJH 6XSSUeVVRUVfor ESD protection
62'3ODVWLF(QFDSVXODWH(6'3URWHFWLRQDLRGHV
DESCRIPTION
The ESD5Z5.0C is designed to protect voltage sensitive components from ESD and transient voltage
events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for
ESD protection on designs where board space is at a premium.This device has been specifically
designed to protect sensitive components which are connected to data and transmission lines from
overvoltage caused by ESD (electrostatic discharge), CDE (Cable Discharge Events),and EFT
(electrical fast transients).
Features
IEC61000-4-2 ( ESD) ± 15KV (Air)
± 8KV (contact)
IEC61000-4-4 ( EFT) 40A (5/50ns)
Peak power dissipation: 45W (8/20us)
Protects one directional I/O line
Low clamping voltage
Working voltages : 5.0V
Low leakage current
3in Configuration
&LUFXLW'LDJUDP
2
1
0DUNLQJ
Applications
High Speed Line :USB1.0/2.0, VGA, DVI, SDI,
Serial and Parallel Ports
Notebooks, Desktops, and Servers
Cellular handsets and accessories
Portable Instrumentation
Projection TV
Peripherals
Mechanical Characteristics
Package: SOD-523
Flammability Rating: UL 94V-0
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Packaging: Tape and Reel
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 15
±8
KV
Peak Pulse Power (8/20μs)
PPP
45
W
Operating Temperature
TOPT
−40 to +150
°C
Storage Temperature
TSTG
−40 to +150
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
The above data above is for reference only.
DN:T20318A0
http://www.microdiode.com
Rev:2020A0
Page :1
(6'=5.0C
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
bol
Param
Test Condition
Min
Typ
Max
Units
5.0
V
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown Voltage
IT = 1mA
IR
Reverse Leakage Current
VRWM = 5V
1.0
μA
VC
Clamping Voltage
IPP = 1A, tp = 8/20μs
10
V
VC
Clamping Voltage
IPP = 3A, tp = 8/20μs
15
V
CJ
Junction Capacitance
VR = 0V, f = 1MHz
12
pF
5.6
V
6.5
The above data are for reference only.
Rev:2020A0
Page :2
(6'=5.0C
ELECTRICAL CHARACTERISTICS CURVE
Rev:2020A0
Page :3
(6'=5.0C
Outlitne Drawing
SOD-523 Package Outline Dimensions
6\PERO
A
A1
b
c
D
E
E1
E2
L
Κ
'LPHQVLRQV,Q0LOOLPHWHUV
0LQ
0D[
0.510
0.770
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
'LPHQVLRQV,Q,QFKHV
0D[
0LQ
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-523
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
178
3000
183×188×80
7'
QTY/Box
(pcs)
18,000
Carton Size
(mm)
Q'TY/Carton
(pcs)
386×265×215
108,000
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its
products and specifications at any time without notice. Customers should obtain and confirm the
latest product information and specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding
the suitability of its products for any particular purpose, not does Microdiode Electronics
(Jiangsu) assume any liability for application assistance or customer product design. Microdiode
Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased
or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of
Microdiode Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components
in life support devices or systems without express written approval of Microdiode Electronics
(Jiangsu).
Rev:2020A0
Page :4
很抱歉,暂时无法提供与“ESD5Z5.0C”相匹配的价格&库存,您可以联系我们找货
