BZX84C13
BZX84C13
    MDD(辰达半导体)
    SOT-23
    BZX84C13
BZX84C13 数据手册
BZX84C2V4 THRU BZX84C43 Zener Voltage - 2.4 to 43 Volts Peak Pulse Power - 0.3 W SURFACE MOUNT ZENER DIODE SOT-23 Features  Planar Die Construction.  300mW Power Dissipation  Zener Voltages from 2.4V - 43V  Ultra-Small Surface Mount Package Power Dissipation Mechanical Data Case : JEDEC SOT-23Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Dimensions in inches and (millimeters) MAXIMUM RATING @ Ta=25℃ unless otherwise specified Parameter Symbol Value Unit VF 0.9 V Power Dissipation Pd 300 mW Typical thermal resistance juncting to ambient RθJA 417 ℃/W Junction temperature Tj -55 to+150 ℃ Storage temperature range Tstg -55 to+150 ℃ Forward Voltage http://www.microdiode.com @ IF=10mA Rev:2024A3 Page :1 BZX84C2V4 THRU BZX84C43 Zener Voltage - 2.4 to 43 Volts Peak Pulse Power - 0.3W ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Maximum Temperature Reverse Coefficent of Current Zener voltage Maximum Zener Impedance ZenerVoltage Range (Note 2) Type (Note 3) Number Code @ IZT=5mA VZ@IZT IZT Nom(V) Min(V) Max(V) (mA) ZZT@IZT ZZK@IZK (Ω) mV/°C IZK IR VR (mA) (μA) (V) Min Max BZX84C2V4 Z11 2.4 2.20 2.60 5 100 600 1.0 50 1.0 -3.5 0 BZX84C2V7 Z12 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 BZX84C3V0 Z13 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 BZX84C3V3 Z14 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 BZX84C3V6 Z15 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 BZX84C3V9 Z16 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 BZX84C4V3 Z17 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 BZX84C4V7 Z1 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 BZX84C5V1 Z2 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 BZX84C5V6 Z3 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 BZX84C6V2 Z4 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 BZX84C6V8 Z5 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 BZX84C7V5 Z6 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 BZX84C8V2 Z7 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 BZX84C9V1 Z8 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 BZX84C10 Z9 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 BZX84C11 Y1 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 BZX84C12 Y2 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 BZX84C13 Y3 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 BZX84C15 Y4 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 BZX84C16 Y5 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 BZX84C18 Y6 18 16.8 19.1 5 BZX84C20 Y7 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 BZX84C22 Y8 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 BZX84C24 Y9 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 BZX84C27 Y10 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 BZX84C30 Y11 30 28.0 32.0 2 BZX84C33 Y12 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 BZX84C36 Y13 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 BZX84C39 Y14 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 BZX84C43 Y15 43 40.0 46.0 2 100 700 1 0.1 32 45 80 225 300 1.0 0.5 0.1 0.1 12.6 21.0 12.4 24.4 10 16.0 29.4 12 Notes: 1. Valid provided that device terminals are kept at ambient temperature. 2. Tested with p ulses, p eriod=5ms,pulse width =300μs. 3. f=1KHz http://www.microdiode.com Rev:2024A3 Page :2 BZX84C2V4 THRU BZX84C43 Zener Voltage - 2.4 to 43 Volts Peak Pulse Power - 0.3W Ratings And Characteristic Curves o ( TA=25 C Unless otherwise noted ) Zener Characteristics(VZ Up to 10 V) Zener Characteristics(11 V to 43 V) 100 100 PD =300mW Pulsed 0.5 1 2 3 4 6 7 10 0.5 10 11 15 20 30 43 39 36 40 45 50 Typical Leakage Current 100 Pulsed FOR BZX84CXXX SERIES 10 IR, LEAKAGE CURRENT (uA) 30 25 20 VZ @ IZT 15 10 5 1 0.1 0.01 Ta=100℃ 1E-3 0 Ta=25℃ 0 4 8 12 16 20 24 28 32 36 40 1E-4 44 0 5 VZ, NOMINAL ZENER VOLTAGE (V) 10 15 20 25 30 35 40 45 VZ, NOMINAL ZENER VOLTAGE (V) Effect of Zener Voltage on Zener Impedance Typical Capacitance 1000 1000 Ta=25℃ Ta=25℃ f=1MHz ZZT, DYNAMIC IMPEDANCE(Ω) 100 1V BIAS BIAS AT 50% OF VZ NOM 10 1 10 IZ(AC)=0.1IZ(DC) IZ=1mA 0V BIAS C, CAPACITANCE (pF) 35 TYPICAL Ta VALUES 35 1 33 30 27 25 VZ, ZENER VOLTAGE (V) Temperature Coefficients 40 θVZ, TEMPERATURE COEFFICIENT (mV/℃) 20 22 1 VZ, ZENER VOLTAGE (V) -5 24 10 1 10 18 8.2 9.1 7.5 6.2 6.8 5.1 5.6 4.7 2.4 10 PD =300mW 11 12 13 IZ, ZENER CURRENT (mA) Pulsed IZ, ZENER CURRENT (mA) Ta =25℃ 15 16 Ta =25℃ 100 f=1kHz 100 IZ=5mA 10 1 1 VZ, NOMINAL ZENER VOLTAGE (V) 10 VZ, NOMINAL ZENER VOLTAGE (V) Power Derating Curve 350 250 POWER DISSIPATION PD (mW) 300 200 150 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 150 (℃ ) The cruve raph is for reference onl , can't be the basis for ud ment 曲线图仅供参考 ! http://www.microdiode.com Rev:2024A3 Page :3 BZX84C2V4 THRU BZX84C43 Zener Voltage - 2.4 to 43 Volts Peak Pulse Power - 0.3W Outlitne Drawing SOT-23 Package Outline Dimensions θ 1 e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 0.65 1.40 0.20 0.00 0.30 0.55 0.20 0.08 2.70 3.10 1.15 1.65 2.80 2.10 1.70 2.10 0.15 0.50 0.35 0° 0.70 12° Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 http://www.microdiode.com inches mm Rev:2024A3 Page :4
BZX84C13 价格&库存
很抱歉,暂时无法提供与“BZX84C13”相匹配的价格&库存,您可以联系我们找货
