KBPC1510
KBPC1510
    MDD(辰达半导体)
    BR-8
    普通一般通用整流器,可用于开关电源,PD快充等桥式整流
KBPC1510 数据手册
KBPC15005 THRU KBPC1510 Reverse Voltage - 50 to 1000 Volts Forward Current -15.0 Amperes SILICON BRIDGE RECTIFIERS Features KBPC-8/BR-8 .158(4.00) .154(3.90) .770(19.6) .730(18.5)  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Ideal for printed circuit boards .520(13.21) .480(12.19) ~ - 260°C/10 seconds,5 lbs. (2.3kg) tension ~  High forward surge current capability  High temperature soldering guaranteed: .770(19.6) .730(18.5) +  Low reverse leakage .520(13.21) .480(12.19) Mechanical Data Case : JEDEC KBPC-8/BR-8 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 1.02 ounce, 29 grams .049(1.25) DIA. .045(1.15) .750 (19.1) MIN (0.27+.025) (6.99+.64) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unless otherwisespecified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward output rectified current at TC=55°C ( N o t e 1 ) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Rating for Fusing(t
KBPC1510 价格&库存
很抱歉,暂时无法提供与“KBPC1510”相匹配的价格&库存,您可以联系我们找货
