1N4148W-E
Forward Current - 0.15 Ampere
Reverse Voltage 100 Volts
FAST SWITHING DIODES
Features
SOD-123
for automatic insertion
For general purpose switching applications High
0.028(0.70)
0.071(1.80)
0.018(0.45)
0.055(1.40)
0.008(0.20)max.
Cathode bar
Fast switching speed
Surface mount package ideally suited
0.110(2.80)
0.098(2.50)
conductance
0.154 (3.90)
Absolute Maximum Ratings at 25 °C
0.026 (0.65)
0.014 (0.35)
Dimensions in inches and (millimeters)
Symbols
1N4148W-E
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
100
V
Maximum RMS voltage
V RMS
75
V
Average rectified output current
IF(AV)
150
mA
Parameter
0.5
at 1s
I FSM
1
4
A
P tot
400
mW
RθJA
280
°C/W
T j , T stg
-55 ~ +125
°C
Symbols
1N4148W-E
Units
V (BR)R
75
V
VF
0.715
0.855
1.00
1.25
V
IR
0.025
1
30
50
uA
Typical Junction Capacitance
Cj
2
pF
Maximum Reverse Recovery Time
t rr
4
ns
Non-reptitive Peak Forward Surge Current
at 1ms
at 1us
Total Power Dissipation
Typical Thermal Resistance
(1)
Operating and Storage Temperature Range
(1)P.C.B. mounted with 5 X 5 mm copper pad areas.
Characteristics at Ta= 25 °C
Parameter
Reverse BreakdownVoltage at I R=1μA
at 1m A
at 10 m A
at 50 m A
at 150mA
Maximum Forward Voltage
Peak Reverse Current
http://www.microdiode.com
at V R =20V T j =25°C
at V R =75V T j =25 °C
at VR=25V Tj=150 °C
at VR=75V Tj=150 °C
Rev:2024A1
Page :1
0.0019 (0.05)
0.006 (0.15)
0.0087 (0.22)
9°
0.018 (0.45)
0.008 (0.2 )
Case: JEDEC SOD-123 molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.00056ounce, 0.016grams
Marking: T4
0° to
0.049 (1.25)
Mechanical Data
0.037(0.95)
0.138 (3.50)
1N4148W-E
Typical Characterisitics
Forward
300
Characteristics
(nA)
REVERSE CURRENT IR
10
T=
a 2
5℃
T=
a 1
00
3
1
0.3
0.1
0.0
0.4
0.8
1.2
FORWARD VOLTAGE
VF
300
100
Ta=25℃
30
10
3
(V)
40
60
REVERSE VOLTAGE
Capacitance Characteristics
1.6
Ta=100℃
1000
1
1.6
Ta=25℃
f=1MHz
1.4
80
VR
100
(V)
Power Derating Curve
500
(mW)
(mA)
30
IF
FORWARD CURRENT
Characteristics
3000
100
BAV16W
400
PD
1N4148W -E
1.2
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Reverse
10000
1.0
0.8
0.6
8
12
REVERSE VOLTAGE
16
VR
(V)
200
100
50
75
100
AMBIENT TEMPERATURE
Ta
125
150
The curve above is for reference only.
Rev:2024A1
Page :2
1N4148W-E
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-123
E
F
B
A
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
3.2
0.126
D
2.0
0.079
E
4.4
0.173
0.047
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights or Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“1N4148W-E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.04494
- 500+0.03698
- 3000+0.03259
- 6000+0.02996
- 24000+0.02766
- 51000+0.02389
