MUR1060CT
MUR1060CT
    MDD(辰达半导体)
    TO220AB-3
MUR1060CT 数据手册
MUR1010CT THRU MUR1060CT Reverse Voltage - 100 to 600 Volts Forward Current - 10.0 Ampere ULTRAFAST RECOVERY RECTIFIER Features TO-220AB  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Construction utilizes void-free molded plastic technique  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 250°C,0.25”(6.35mm) from case for 10 seconds 0.185(4.70) 0.175(4.44) 0.154(3.91) DIA 0.148(3.74) 0.415(10.54) MAX 0.057(1.45) 0.051(1.30) 0.113(2.87) 0.103(2.62) 0.145(3.68) 0.135(3.43) 0.410(10.41) 0.390(9.91) PIN 1 0.600(15.2) 0.530(13.4) 0.350(8.89) 0.330(8.38) 0.635(16.13) 0.625(15.87) 1.148(29.16) 1.118(28.40) 0.160 (4.05) 0.140 (3.55) 0.110(2.79) 0.100(2.54) 0.582(14.79) 0.519(13.18) Mechanical Data 0.037(0.94) 0.027(0.68) 0.105 (2.67) 0.095 (2.41) 0.105 (2.67) 0.095 (2.41) Case : JEDEC TO-220AB Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity :As marked Mounting Position : Any Weight : 0.080 ounce, 2.24 grams 0.205 (5.20) 0.195 (4.95) 0.022(0.58) 0.014(0.35) PIN 1 PIN 2 PIN 3 CASE Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current (see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 5.0A TA=25℃ Maximum DC reverse current at rated DC blocking voltage TA=100℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Maximum Reverse Reccovery time (NOTE 3) storage temperature range VRRM V RMS V DC MDD MDD MDD MDD MUR1010CT MUR1020CT MUR1030CT 100 70 100 200 140 200 MUR1040CT 300 210 300 400 280 400 MDD MDD MBUR1050CT MUR1060CT 500 350 500 600 420 600 UNITS V V V I(AV) 10.0 A IFSM 90 A VF 1.0 1.3 10 500 IR CJ 1.7 170 V uA 130 pF R θJC 3.5 ℃/W Trr 35 nS -55 to +150 ℃ TjTSTG Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to case. 3..Reverse Rcovery Test Conditions: IF=0.5A, IR=1A, Irr=0.25A. DN:T21903A1 http://www.microdiode.com Rev:2021A1 Page :1 MUR1010CT THRU MUR1060CT Reverse Voltage - 100 to 600 Volts Forward Current - 10.0 Ampere Ratings And Characteristic Curves Fig.2 TYPICAL JUNCTION CAPACITANCES 12.5 180 JUNCTIONCAPACITANCE,pF AVERAGEFORWARDCURRENT,AMPERES Fig.1 FORWARD CURRENT DERATING CURVE 10.0 7.5 5.0 2.5 150 120 90 O TJ = 2 5 C 60 100-400V 30 500-600V 0 0 0 50 1 150 100 O CASE TEMPERATURE, C 5 10 50 100 200 20 500 REVERSE VOLTAGE, VOLTS Fig.3 FORWARD CHARACTERISTICS Fig.4 TYPICAL REVERSE CHARACTERISTICS 1000 100 100-200V 10 INSTANTANEOUSREVERSECURRENT,uA INSTANTANEOUSFORWARDCURRENT, Amperes 2 300-400V 500-600V 1 0.1 O TJ = 1 2 5 C 100 10 1.0 O TJ = 2 5 C O TJ = 2 5 C 0.01 .4 .6 .8 1.0 1.2 1.4 1.6 1.8 2.0 0.1 FORWARD VOLTAGE, volts 20 40 60 80 100 120 1 40 PERCENTAGE OF PEAK REVERSE VOLTAGE,% Fig.5 PEAK FORWARD SURGE CURRENT FORWARDSURGECURRENT,AMPERES 105 90 75 60 45 30 15 1 10 100 The curve above is for reference only. http://www.microdiode.com Rev:2021A1 Page :2
MUR1060CT 价格&库存
很抱歉,暂时无法提供与“MUR1060CT”相匹配的价格&库存,您可以联系我们找货
