SS36-SMB-AJ-T3-ZX
SS36-SMB-AJ-T3-ZX
    MDD(辰达半导体)
    DO-214AA
    电压:60V 电流:3A
SS36-SMB-AJ-T3-ZX 数据手册
SS32 THRU SS3200 Reverse Voltage - 20 to 200 Volts Forward Current - 3.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER DO-214AA/SMB Features  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency 0.155(3.94) 0.130(3.30) 0.086 (2.20) 0.071 (1.80)  Built-in strain relief,ideal for automated placement 0.185(4.70) 0.160(4.06)  High forward surge current capability  High temperature soldering guaranteed: 0.012(0.305) 0.006(0.152) 250 °C/10 seconds at terminals 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. Mechanical Data 0.220(5.59) 0.200(5.08) Case: JEDEC DO-214AA/SMB molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight : 0.003 ounce, 0.095 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS SS32 SS33 SS34 SS35 SS36 SS38 SS310 SS3150 SS3200 UNITS Maximum repetitive peak reverse voltage VRRM Maximum RMS voltage Maximum DC blocking voltage VRMS VDC 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 80 56 80 100 70 100 150 105 150 200 140 200 V V V Marking Code Maximum average forward rectified current I(AV) 3 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 80 A Maximum instantaneous forward voltage at 3.0A VF Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=100℃ Typical junction capacitance (NOTE 1) 0.55 IR CJ 0.5 0.7 0.85 5 450 400 V 0.95 0.3 3 mA pF Typical thermal resistance (NOTE 2) RJA 60 ℃/W Operating junction temperature range TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Storage temperature range Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas Rev:2021A1 Page :1 SS32 THRU SS3200 Reverse Voltage - 20 to 200 Volts Forward Current - 3.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics 3.5 3.0 2.4 1.8 1.2 0.6 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Average Forward Current (A) Fig.1 Forward Current Derating Curve 10 4 10 3 10 2 TJ=100°C TJ=75°C SS32/SS36 TJ=25°C 0 10 0 Case Temperature (°C) 40 60 80 100 Fig.4 Typical Junction Capacitance TJ=25°C 20 1000 10 1.0 Junction Capacitance (pF) 500 SS32/SS34 SS36 SS38/SS312 SS315/SS3200 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 200 100 20 SS32~SS36 SS38~SS3200 10 0.1 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 10 100 Fig.6- Typical Transient Thermal Impedance 100 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance(°C/W) 100 80 00 1 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Instaneous Forward Current (A) SS38~SS3200 101 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) Rev:2021A1 Page :2 SS32 THRU SS3200 Reverse Voltage - 20 to 200 Volts Forward Current - 3.0 Ampere Packing information unit:mm P0 P1 Item Symbol Tolerance SMB Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 3.81 5.41 2.42 1 50 . 330.00 50.00 13.00 1.75 5.55 8.00 4.00 2.00 0.30 12.00 12.30 d E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) BOX (pcs) INNER BOX (mm) REEL DIA, (mm) SMB 13" 3,000 4.0 6,000 190*190*41 330 CARTON SIZE (mm) 365*365*360 CARTON (pcs) 48,000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout Unit (inch) Symbol Unit (mm) A 2.8 0.110 B 0.094 C 2.4 4.6 0.181 D 2.2 0.086 E 7.0 0.276 Rev:2021A1 Page :3
SS36-SMB-AJ-T3-ZX 价格&库存
很抱歉,暂时无法提供与“SS36-SMB-AJ-T3-ZX”相匹配的价格&库存,您可以联系我们找货
