RS2A THRU RS2M
Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
Open Junction chip
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.185(4.70)
0.160(4.06)
250℃/ 10 seconds at terminals
Glass passivated chip junction
0.012(0.305)
0.006(0.152)
0.096(2.44)
0.084(2.13)
Mechanical Data
0.060(1.52)
0.030(0.76)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : A n y
Weight : 0.003 ounce, 0.091 grams
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
RS2A
RS2B
RS2D
RS2G
RS2J
RS2K
RS2M
UNITS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
Maximum average forward rectified current
I(AV)
2
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
60
A
Maximum instantaneous forward voltage at 2.0A
VF
1.3
V
Maximum DC reverse current
at rated DCblocking voltage
IR
5
100
μA
Marking Code
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
VRMS
VDC
trr
150
250
500
ns
CJ
RJA
28
60
pF
RθJC
℃/W
-55 to +150
Operating junction and storage temperature range TJ,TSTG
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.P.C.B. mounted with 2.0x2.0”(5x5cm) copper pad areas
3.The typical data above is for reference only.
Rev:2021A1
Page :1
RS2A THRU RS2M
Ratings And Characteristic Curves
Fig.1 Forward Current Derating Curve
3.0
Instaneous Reverse Current(μ A)
100
Average Forward Current (A)
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
75
50
100
125
150
1.0
TJ=25°C
0.1
175
00
Case Temperature (°C)
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Characteristics TJ=25°
10
TJ=125°C
10
Fig.4 Typical Junction Capacitance
C
TJ=25°C
Junction Capacitance (pF)
Instaneous Forward Current (A)
100
1.0
0.1
pulse with 300sμ
0.0
0.5
1.0
1.5
2.0
TJ=25°C
f = 1.0MHz
Vsig = 50mVp-p
1% duty cycle
0.01
10
1
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
70
Peak Forward Surage Current (A)
60
50
40
30
00
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
100
Number of Cycles
Rev:2021A1
Page :2
RS2A THRU RS2M
Packing information
P0
P1
unit:mm
d
E
Item
F
B
A
Symbol
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
D1
T
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMB
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
13"
3,000
4.0
INNER
BOX
(mm)
REEL
DIA,
(mm)
CARTON
SIZE
(mm)
CARTON
(pcs)
190*190*41
330
365*365*360
48,000
BOX
(pcs)
6,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Rev:2021A1
Page :3
很抱歉,暂时无法提供与“RS2G-SMBG-T3-ZX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.19440
- 200+0.07528
- 500+0.07269
- 1000+0.07128
