B5819W-SL(S)-T3-ZX
B5819W-SL(S)-T3-ZX
    MDD(辰达半导体)
    SOD-123
    电压:40V 电流:1A
B5819W-SL(S)-T3-ZX 数据手册
B5817W THRU B5819W Reverse Voltage 20-40 Volts Forward Current - 1.0 Ampere SCHOTTKY DIODES Features SOD-123  Fast switching speed  Surface mount package ideally suited 0.071(1.80) 0.028(0.70) 0.020(0.50) 0.059(1.50)  for automatic insertion  For general purpose switching applications High 0.008(0.20)max. Cathode bar 0.110(2.80) 0.098(2.50)  conductance 0.154 (3.90) Absolute Maximum Ratings at 25 °C 0.019 (0.475) ref. B5817W B5818W B5819W Units Maximum Repetitive Peak Reverse Voltage V RRM 20 30 40 V Maximum RMS voltage V RMS 14 21 28 V Average rectified output current I0 Continuous Forward Current 1 A IFRM 1.5 A I FSM 25 A PD 500 mW RθJA 160 °C/W Operating Temperature Range Tj -55 ~ +125 °C Storage Temperature Range Tstg -55 ~ +125 °C Non-reptitive Peak Forward Surge Current at 8.3ms Power Dissipation Typical Thermal Resistance (1) (1)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. Characteristics at Ta= 25 °C Parameter Reverse BreakdownVoltage at IR=1mA Symbols B5817W V (BR)R 20 30 0.45 0.55 0.60 0.75 0.875 0.90 at 1A Maximum Forward Voltage Peak Reverse Current VF at 3A at VR=20V Tj=25°C Tj=100°C 0.0035 (0.09) 0.0087 (0.22) 8° 0.010 (0.25) Dimensions in inches and (millimeters) Symbols Parameter 0.018 (0.45) 0.008 (0.2 ) Case: JEDEC SOD-123 molded plastic body Terminals: Plated leads solderable per MIL-STD-750, Method 2026 Polarity: Polarity symbols marked on case Weight : 0.00056 ounce, 0.016grams Marking: B5817W:SJ, B5818W:SK, B5819W:SL 0° to 1.250 (0.049) Mechanical Data 1.050 (0.041) 0.142 (3.60) Cj Non-Repetitive peak reverse voltage VRM B5819W 40 1.0 IR Typical Junction Capacitance B5818W Units V V mA 10.0 pF 110 20 30 Rev:2021A1 40 V Page :1 B5817W THRU B5819W Reverse Voltage 20-40 Volts Forward Current - 1.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics Fig.1 Forward Current Derating Curve Average Forward Current (A) 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 Instaneous Reverse Current ( μA) 1.2 10 4 10 3 10 2 10 TJ=25°C 0 0 40 20 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 TYPICAL FORWARD VOLTAGE Fig.4 Typical Junction Capacitance 500 10 200 Junction Capacitance (pF) INSTANTANEOUS FORWARD CURRENT AMPERS TJ=75°C 101 Case Temperature (°C) 1.0 40V 30V 20V 0.1 0.01 0 0.2 0.4 0.6 0.8 100 50 20 10 1.0 0.1 1000 8.3 ms Single Half Sine Wave (JEDEC Method) 25 20 15 10 05 00 1 10 100 Fig.6 Typical Transient Thermal Impedance 100 Number of Cycles at 50Hz Transient Thermal Impedance(°C/W) 30 10 1 Reverse Voltage (V) INSTANTANEOUS FORWARD VOLTAGE, VOLTS Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) TJ=100°C 100 10 0.01 0.1 1 10 100 t, Pulse Duration(sec) The curve above is for reference only. Rev:2021A1 Page :2 B5817W THRU B5819W Reverse Voltage 20-40 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SOD-123 E F B A W P D2 T D1 C W1 D Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-123 7" 3,000 4.0 45,000 210*208*203 178 430*430*235 180,000 APPROX. GROSS WEIGHT (kg) 9.0 Suggested Pad Layout Symbol A Unit (mm) Unit (inch) 0.047 B 1.2 1.2 C 3.2 0.126 D 2.0 0.079 E 4.4 0.173 0.047 Rev:2021A1 Page :3
B5819W-SL(S)-T3-ZX 价格&库存
很抱歉,暂时无法提供与“B5819W-SL(S)-T3-ZX”相匹配的价格&库存,您可以联系我们找货
