SI2301
SOT-23 Plastic-Encapsulate MOSFETS
SOT-23
20V P-Channel MOSFET
V(BR)DSS
-20V
RDS(on)Typ
ID Max
70mΩ@4.5V
-3.0A
78mΩ@3.3V
3
1. GATE
2. SOURCE
1
3. DRAIN
2
APPLICATION
Load Switch for Portable Devices
z
DC/DC Converter
z
Features
Trench FET Power MOSFET
MARKING
Equivalent circuit
D
A1sHB
G
S
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-23
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
330
3000
203×203×195
45000
7'
Carton Size Q'TY/Carton
(mm)
(pcs)
438×438×220
180000
Maximum Ratings and Thermal Characteristics (TA = 25°C unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±10
TA = 25 oC
Continuous Drain Current
o
TA = 70 C
Maximum Power Dissipation
o
TA = 25 C
2)
o
TA = 70 C
Operating Junction and Storage Temperature Range
Junction-to-Ambient Thermal Resistance (PCB mounted)
2)
V
-3.0
ID
A
-2.5
IDM
Pulsed Drain Current 1)
Unit
A
-12
1.2
PD
W
0.9
TJ, Tstg
-50 to 150
RthJA
100
o
C
o
C/W
Notes
1) Pulse width limited by maximum junction temperature.
2) Surface Mounted on FR4 Board, t v 5 sec.
The above data are for reference only.
DN:T19928A0
http://www.microdiode.com
Rev:2019A0
Page :1
SI2301
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
-0.6
-1
Units
Static
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID =-250µA
-20
Gate-source threshold voltage
VGS(th)
VDS =VGS, ID =-250µA
-0.4
Gate-source leakage
IGSS
VDS =0V, VGS =±10V
±100
nA
Zero gate voltage drain current
IDSS
VDS =-20V, VGS =0V
-1
µA
Drain-source on-state resistance
Forward transconductance
a
a
RDS(on)
gfs
VGS =-4.5V, ID =-3A
70
90
VGS =-3.3V, ID =-2.0A
78
100
VDS =-5V, ID =-2.8A
4.0
V
mΩ
S
b
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Turn-on delay time
td(on)
Rise time
Turn-off delay time
Fall time
tr
td(off)
tf
330
VDS =-10V,VGS =0V,f =1MHz
pF
50
45
VDS =-10V,VGS =-4.5V,ID =-3A
6.6
0.8
nC
0.7
1.4
11
VDD=-10V, RL=10Ω,
12
ID =-3A,
ns
18
VGEN=-4.5V,Rg=3.3Ω
30
Drain-source body diode characteristics
Continuous source-drain diode current
Body diode voltage
a)
b)
IS
VSD
TC=25℃
IS=-2A
-0.85
-1.5
A
-1.2
V
Pulse test: pulse width ≤ 300us, duty cycle≤ 2%
Guaranteed by design, not subject to production testing
Rev:2019A0
Page :2
SI2301
-ID, Drain-Source Current (A)
-VGS(TH), Gate -Source Voltage (V)
Typical Characteristics
Tj - Junction Temperature (°C)
-VDS, Drain -Source Voltage (V)
Fig2. Normalized Threshold Voltage Vs. Temperature
-VDS, Drain -Source Voltage (mV)
Fig1. Typical Output Characteristics
-VGS, Gate -Source Voltage (V)
Fig4. Drain -Source Voltage vs Gate -Source Voltage
-ID - Drain Current (A)
-ISD, Reverse Drain Current (A)
Fig3. Typical Transfer Characteristics
-VSD, Source-Drain Voltage (V)
Fig5. Typical Source-Drain Diode Forward Voltage
Fig6. Maximum Safe Operating Area
Rev:2019A0
Page :3
SI2301
C, Capacitance (pF)
-VGS, Gate-Source Voltage (V)
-VDS, Drain-Source Voltage (V)
Fig8. Typical Gate Charge Vs. Gate-Source Voltage
Thermal Resistance
ZqJA Normalized Transient
Fig7. Typical Capacitance Vs. Drain-Source Voltage
Qg, Total Gate Charge (nC)
Pulse Width (s)
Fig9. Normalized Maximum Transient Thermal Impedance
Fig10. Switching Time Test Circuit and waveforms
Rev:2019A0
Page :4
SI2301
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.4
0°
0.55
10°
Note:
1.
Controlling
dimension:in/millimeters. 2.General
tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2019A0
Page :5
很抱歉,暂时无法提供与“SI2301-3A”相匹配的价格&库存,您可以联系我们找货
