BAT54WS
BAT54WS
    MDD(辰达半导体)
    SOD-323
    电压:21V 电流:100MA
BAT54WS 数据手册
BAT54WS Reverse Voltage 30 Volts SCHOTTKY DIODES Features  Low forward voltage drop  Fast switching time SOD-323 insertion 0.016(0.40) 0.057(1.45) 0.007(0.20) 0.043(1.10)  Lead, Halogen and Antimony Free, RoHS Compliant 0.008(0.20)max. Cathode bar  Surface mount package ideally suited for automatic 0.070(1.80) 0.063 (1.40) "Green" Device 0.110 (2.80) 0.006 (0.15) 0.024 (0.60) 0.014 (0.35) Absolute Maximum Ratings at 25 °C 0.0019 (0.05) 0.0079 (0.20) 9° 0.008 (0.2 ) 0.016 (0.45) 0° to 0.043 (1.10) Case: JEDEC SOD-323 molded plastic body Terminals: Plated leads solderable per MILSTD-750, Method 2026 Polarity: Polarity symbols marked on case Weight : 0.0007 ounce, 0.02 grams Marking: L9 0.032 (0.80) 0.098 (2.50) Mechanical Data PARAMETER DC Blocking voltage Average rectified output current Forward continuous current Repetitive peak forward current Forward surge current Power dissipation Termal resistance,junction to ambient air Junction temperature Storage temperature Non-Repetitive peak reverse voltage Forward Current - 0.20 Ampere Dimensions in inches and (millimeters) BAT54WS SYMBOLS UNITS 21 V 100 mA IFM IFRM 200 mA 300 mA IFSM 0.6 A Pd 200 mW RΘJA 500 C /W VR IO Tj -55 to +125 C TSTG -55 to +150 C VRM 30 V Characteristics at Ta= 25 °C PARAMETER Reverse breakdomn voltage Unit V IR=100uA VF1 240 mV IF=1.0mA VF2 1000 mV IF=100mA Reverse current IR 2.0 uA Capacitance between terminals CT 10 pF Forward voltage Reverse recovery time http://www.microdiode.com V(BR)R trr Min. Typ. Conditions Max. SYMBOLS 30 5.0 ns VR=25V VR=1V,f=1.0MHz IF=10mA,IR=10mA to 1mA Rev:2024A3 RL=100 Page :1 BAT54WS Reverse Voltage 30 Volts Forward Current - 0.20 Ampere Typical Characterisitics Forward Characteristics 200 Reverse Characteristics 100 Pulsed Pulsed (uA) T= a 2 5℃ FORWARD CURRENT 10 REVERSE CURRENT IR a T IF =1 00 ℃ (mA) 100 1 0.1 0 200 400 FORWARD VOLTAGE 600 VF Ta=25℃ 0.1 0 (mV) 5 10 15 20 REVERSE VOLTAGE Capacitance Characteristics 20 1 0.01 800 Ta=100℃ 10 25 VR 30 (V) Power Derating Curve 250 (mW) f=1MHz 200 PD 16 12 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) Ta=25℃ 8 4 0 0 5 10 REVERSE VOLTAGE 15 VR (V) 20 150 100 50 0 0 25 50 75 AMBIENT TEMPERATURE URE 100 a 125 (℃) The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :2 BAT54WS Reverse Voltage 30 Volts Forward Current - 0.20 Ampere Packing information P0 unit:mm P1 d Item E F B A W Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width P D2 T D1 C W1 D Symbol Tolerance A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SOD-323 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-323 7" 3,000 4.0 45,000 210*208*203 178 430*430*235 180,000 APPROX. GROSS WEIGHT (kg) Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) Unit (inch) A 0.028 B 0.7 0.7 C 2.15 0.085 D 1.8 0.071 E 2.85 0.112 0.028 Rev:2024A3 Page :3
BAT54WS 价格&库存
很抱歉,暂时无法提供与“BAT54WS”相匹配的价格&库存,您可以联系我们找货
