BAT46WS
SCHOTTKY DIODES
Features
SOD-323
High breakdown voltage
Low turn-on voltage
Guard ring construction for transient protection
0.016(0.40)
0.057(1.45)
0.007(0.20)
0.043(1.10)
Marking
0.008(0.20)max.
Cathode bar
0.070(1.80)
0.063 (1.40)
0.110 (2.80)
0.098 (2.50)
0.006 (0.15)
0.024 (0.60)
0.014 (0.35)
0.0019 (0.05)
0.0079 (0.20)
Case : SOD-323
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.00019 ounce, 0.00548 grams
9°
0.008 (0.2 )
0.016 (0.45)
0° to
0.043 (1.10)
Mechanical Data
0.032 (0.80)
S9
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics, Single Diode @Ta=25℃
SYMBOLS
Limit
UNITS
VRRM
VRWM
100
VOLTS
Forward Continuous Current
IO
150
mA
RRepetitive peak forward current (Note 1)
@ tp < 1.0s, Duty Cycle < 50%
IFRM
350
mA
Non-reptitive Peak Forward Surge Current@ t = 8.3ms
IFSM
25
A
PARAMETER
Peak repetitive peak reverse voltage
Working peak reverse voltage
Power dissipation
Thermal resistance junction to ambient
Operating Junction Temperature Range
Pd
200
mW
RΘJA
500
°C/W
TJ
-55 to +150
C
Storage temperature Range
TSTG
-55 to +150
C
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
PARAMETER
Reverse breakdomn voltage (Note 2)
Forward voltage (Note 2)
Reverse voltage leakage current
Diode capacitance
SYMBOLS
VR
Min.
Typ.
Max.
100
Unit
Conditions
V
IR=100uA
VF
0.25
V
IF1=0.1mA
VF
0.45
V
IF2=10mA
VF
IR
1.0
V
IF3=250mA
0.3
IR
0.5
IR
1.0
uA
uA
uA
VR1=1.5V
VR2=10V
VR3=50V
IR
2.0
CT
uA
pF
VR4=75V
VR=0V,f=1.0MHz
CT
12
pF
VR=1V,f=1.0MHz
NOTES:
(1) Part mounted on FR-4 board with recommended pad layout.
(2)Short duration pulse test used to minimize self-heating effect.
http://www.microdiode.com
Rev:2024A2
Page :1
BAT46WS
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
POWER DISSIPATION PD (W)
Fig.1 Power Derating Curve
0.30
Reverse Current ( uA)
1000
0.25
0.20
0.15
0.10
0.05
0.00
T J =100°C
100
10
T J =25°C
1.0
0.1
25
75
50
100
125
150
Ambient temperature Ta(℃)
Junction Capacitance (pF)
INSTANTANEOUS FORWARD CURRENT (mA)
2 5°
C
=1
Ta
Ta =
00
°C
100
80
100
100
T J =25°C
f=1MHz
10
1
1
0.2
0.3
0.4
1.0
0.5
10
36
30
24
18
12
06
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C /W)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Reverse Voltage (V)
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
Peak Forward Surage Current (A)
60
Fig.3 Typical Junction Capacitance
Fig.2 TYPICAL FORWARD VOLTAGE
10
40
Reverse Voltage VR (V)
Fig.6 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
BAT46WS
Packing information
P0
unit:mm
P1
d
Item
E
F
B
A
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
T
D1
C
W1
D
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-323
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.028
B
0.7
0.7
C
2.15
0.085
D
1.8
0.071
E
2.85
0.112
0.028
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“BAT46WS”相匹配的价格&库存,您可以联系我们找货
