MUR2020DCT
MUR2020DCT
    MDD(辰达半导体)
    TO-220AB
    耐压:200V 电流:20A 反向恢复时间:35NS
MUR2020DCT 数据手册
MUR2020DCT THRU MUR2060DCT Reverse Voltage - 200 - 600 Volts Forward Current - 20.0 Ampere Ultra-Fast Recovery Diodes Features TO-220AB  High frequency operation. High surge forward current capability  High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance  Guard ring for enhanced ruggedness and long term reliability  Solder dip 275 °C max. 7s, per JESD 22-B106 PIN2 PIN1 Mechanical Data PIN2 Case : JEDEC TO-220AB Molded plastic body Weight : 0.067 ounce, 1.9 grams Lead free finish, RoHS compliant Case Material: “Green” molding compound, UL flammability classification 94V-0,“Halogen-free”. PIN3 PIN1 PIN2 PIN3 Maximum Ratings And Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter SYMBOLS MDD MUR2020DCT MDD MUR2040DCT MDD MUR2060DCT UNITS Maximum repetitive peak reverse voltage VRRM 200 400 600 V Maximum RMS voltage VRMS 140 280 420 V Maximum DC blocking voltage VDC 200 400 600 V Maximum average forward rectified current at T C=110 C per device per diode Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Maximum instantaneous forward voltage per diode at 10.0A Maximum DC reverse current at rated DC blocking voltage Maximum reverse recovery time Typical thermal resistance Operating junction temperature range Storage temperature range I(AV) 20.0 10.0 A IFSM 150.0 A VF T A =25 C T A=125 C 1.0 1.3 1.6 V IR 10 500 uA Trr 35 ns RqJC 4.0 C/W TJ -55 to +175 C TSTG -55 to +175 C Note:1.Reverse recovery time test condition: IF=0.5A IR=1.0A Irr=0.25A http://www.microdiode.com Rev:2025A2 Page :1 MUR2020DCT THRU MUR2060DCT Reverse Voltage - 200 - 600 Volts Forward Current - 20.0 Ampere Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 20 16 12 8.0 4.0 RESISTIVE OR INDUCTIVE LOAD 0.0 25 50 75 100 125 150 Instantaneous Reverse Current, (uA) Ratings And Characteristic Curves Fig.2 Typical Instaneous Reverse Characteristics 1000 100 T J =125°C 10 1.0 T J =25°C 0.1 20 0 175 T J =25°C 10 0V 40 0V 0 60 V 1 0.1 0 0.4 0.8 1.2 80 100 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) Instaneous Forward Current (A) Fig.3 Typical Forward Characteristic 20 60 Percent of rated peak reverse voltage (%) Case Temperature (°C) 100 40 1.6 Instaneous Forward Voltage (V) 2.0 150 125 100 75 50 25 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2025A2 Page :2 MUR2020DCT THRU MUR2060DCT Reverse Voltage - 200 - 600 Volts Forward Current - 16.0 Ampere Outlitne TO-220AB Package Outline Dimensions A C E B M N D L b F L1 b1 H G G TO-220AB mechanical data UNIT A B b b1 C D E F max 10.45 2.94 1.77 0.94 4.76 min 0.62 4.42 14.6 1.14 2.20 16.0 1.40 2.90 mm 9.85 2.54 1.14 G H L 2.54 TYPICAL 0.64 0.35 L1 M N 4.2 14.79 6.60 3.86 2.8 13.00 6.13 3.8 Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A2 Page :3
MUR2020DCT 价格&库存
很抱歉,暂时无法提供与“MUR2020DCT”相匹配的价格&库存,您可以联系我们找货
