MBRB30200T
MBRB30200T
    MDD(辰达半导体)
    TO-263
    电压:200V 电流:30A
MBRB30200T 数据手册
MBRB3040T THRU MBRB30200T Reverse Voltage - 40 to 200 Volts Forward Current - 30.0 Ampere SCHOTTKY BARRIER GLASS PASSIVATED RECTIFIERS TO-263(D2PAK) FEATURES High current capability Low forward voltage drop Low power loss, high efficiency High surge capability High temperature soldering guaranteed Mounting position: any K ① MECHANICAL DATA Case: TO-263 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any ② ① ② K HEAT SINK MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. MBRB MBRB MBRB MBRB MBRB MBRB 3040T 3045T 3060T 30100T 30150T 30200T VRRM 40 45 60 100 150 200 V Maximum RMS voltage VRMS 28 32 42 70 105 140 V Maximum DC blocking voltage VDC 40 45 60 100 150 200 V MCHARACTERISTICS SYMBOL Maximum repetitive peak reverse voltage Maximum average forward rectified current per diode per device Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) per device IF(AV) 15 30 A IFSM 200 A Maximum instantaneous forward voltage at 15A DC Per leg VF Maximum DC reverse current at rated DC blocking voltage IR TA=25℃ TA=125℃ UNITS 0.75 0.80 0.88 0.1 20 0.92 0.95 0.05 20 600 V mA Typical junction capacitance (NOTE 1) CJ Typical thermal resistance (NOTE 2) RθJA Operating junction temperature range TJ -55 to +150 -55 to +175 ℃ TSTG -55 to +150 -55 to +175 ℃ Storage temperature range 400 pF ℃/W 45 Note:1.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C. 2.PCB. Mounted on 10cm x 10cm x 1mm copper pad areas 3. The typical data above is for reference only. DN:T22602A0 http://www.microdiode.com Rev:2022A0 Page :1 MBRB3040T THRU MBRB30200T Reverse Voltage - 40 to 200 Volts Forward Current - 30.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics 30 25 20 0~ 15 0V 20 15 00 ~1 40 10 V Average Forward Current (A) 35 5 0.0 20 40 60 80 100 120 140 160 180 Instaneous Reverse Current ( mA) Fig.1 TYPICAL FORWARD CURRENT DERATING CURVE 100 40~100V 150~200V 10 TJ=100 °C 1.0 0.1 TJ=25°C 0.01 0.001 0 Case Temperature (°C) 20 40 60 80 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic(per leg) Fig.4 Typical Junction Capacitance TJ=25°C pF) 1000 10 JunctionCapacitance ( Instaneous Forward Current (A) 20 1 40~45V 60V 100V 150V 200V 0.1 0 0.2 0.4 0.6 0.8 1.0 500 100 40~45V 20 60~200V 10 1.2 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current °C/W) Fig.6- Typical Transient Thermal Impedance 320 100 280 240 200 160 120 80 40 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance( Peak Forward Surage Current (A) 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) The curve above is for reference only. http://www.microdiode.com Rev:2022A0 Page :2 MBRB3040T THRU MBRB30200T Reverse Voltage - 40 to 200 Volts Forward Current - 30.0 Ampere Outlitne Drawing TO-263(D2PAK) Package Outline Dimensions 0.409( 9.8) 0.387(10.4) 0.189(4.8) 0.137(4.4) 0.055(1.4) 0.047(1.2) 0.357(9.1) 0.335(8.5) 0.418(10.6) 0.378(9.6) 0.055(1.4) 0.039(1.0) 0.236(6.0) 0.197(5.0) 0.035(0.9) MAX. 0.108(2.75) 0.092(2.35) 0.108(2.75) 0.092(2.35) 0.026(0.7) 0.011(0.3) Unit:inch(mm) 8.50 3 . 00 Suggested Pad Layout Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 3 . 00 8. 4 0 1. 2 0 http://www.microdiode.com Rev:2022A0 Page :3 MBRB3040T THRU MBRB30200T Reverse Voltage - 40 to 200 Volts Forward Current - 30.0 Ampere TO-263 Embossed Carrier Tapeape Packaging Description: TO-263 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 800 units per 13" or 33.0cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). TO-263 Tape Leader and Trailer TO-263 Reel 800 pcs 13 Inch http://www.microdiode.com 1,600 pcs 340×336×66 8,000 pcs 400×353×365 Rev:2022A0 Page :4
MBRB30200T 价格&库存
很抱歉,暂时无法提供与“MBRB30200T”相匹配的价格&库存,您可以联系我们找货
