MUR1560CT
MUR1560CT
    MDD(辰达半导体)
    TO-220AC
    耐压:600V 电流:15A 反向恢复时间:35NS
MUR1560CT 数据手册
MUR1520CT THRU MUR1560CT Reverse Voltage - 200~600 Volts Forward Current - 15.0 Ampere Fast Recovery Epi Diodes Features TO-220AC  High frequency operation. High surge forward current capability  High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance  Guard ring for enhanced ruggedness and long term reliability  Solder dip 275 °C max. 7s, per JESD 22-B106 PIN2 Mechanical Data PIN1 Case : JEDEC TO-220AC Molded plastic body Weight : 0.065 ounce, 1.855 grams Terminals: Lead solderable per MIL-STD-202, Method 208 Lead free finish, RoHS compliant Case Material: “Green” molding compound, UL flammability classification 94V-0,“Halogen-free”. PIN3 PIN1 PIN2 PIN3 Maximum Ratings And Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols MUR1520CT MUR1540CT MUR1560CT Units Maximum Recurrent Peak Reverse Voltage V RR M 20 0 40 0 60 0 V Maximum RMS voltage V RMS 14 0 280 420 V Maximum DC blocking Voltage V DC 200 400 600 V Maximum Average Forward Rectified Current I F(AV) 15 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 150 A Instantaneous forward voltage at 15 A VF Maximum Reverse Recovery Time(1) trr 35 ns Maximum instantaneous reverse Tj=25℃ current at rated Tj=125℃ DC blocking voltage IR 10 500 uA RθJ C 4 °C/W T j, T stg -55 ~ +175 °C Maximum Thermal Resistance Junction To Case Operation Junction Temperature and Storage Temperature 1.0 1.3 1.6 V NOTE 1:I F =0.5A,I R =1A,Irr=0.25A http://www.microdiode.com Rev:2025A0 Page :1 MUR1520CT THRU MUR1560CT Reverse Voltage - 200~600 Volts Forward Current - 15.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics 25 20 15 10 5 0.0 25 50 75 100 125 150 175 Case Temperature (°C) Instantaneous Reverse Current, (mA) Average Forward Current (A) Fig.1 Typical Forward Current Derating Curve 1000 100 T J =150°C 10 T J =25°C 1.0 0.1 200V 400V 600V 20 0 Peak Forward Surage Current (A) Instaneous Forward Current (A) 0V 0V V 20 40 600 1 0.1 200V 400V 600V 0 0.5 1.0 1.5 2.0 Instaneous Forward Voltage (V) 100 80 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current T J =25°C 10 60 Percent of rated peak reverse voltage (%) Fig.3 Typical Forward Characteristic 100 40 2.5 200 175 150 125 200~600V 100 75 50 25 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles at 60Hz The curve above is for reference only. http://www.microdiode.com Rev:2025A0 Page :2 MUR1520CT THRU MUR1560CT Reverse Voltage - 200~600 Volts Forward Current - 15.0 Ampere Outlitne TO-220AC Package Outline Dimensions A C E B M N D L b F L1 b1 H G UNIT mm mil TO-220ACW mechanical data b b1 C D E F max 10.45 2.94 1.77 0.94 4.76 16.0 1.40 4.76 min 9.85 2.54 1.14 0.62 4.42 14.6 1.14 2.49 max 411 116 70 37 187 630 55 187 min 388 100 45 24 174 575 45 98 A B G 5.1 typ. 201typ. H L L1 M 0.64 4.20 14.79 6.5 0.35 2.80 13.00 6.3 25 165 582 256 14 110 512 248 N 3.84 typ. 151 typ. Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). http://www.microdiode.com Rev:2025A0 Page :3
MUR1560CT 价格&库存
很抱歉,暂时无法提供与“MUR1560CT”相匹配的价格&库存,您可以联系我们找货
