MDD100N03D
MDD100N03D
    MDD(辰达半导体)
    TO-252
    30V 100A 2.8MΩ中低压功率N-MOS管
MDD100N03D 数据手册
MDD100N03D 30V N-Channel Enhancement Mode MOSFET 1. Description This N-Channel MOSFET is produced using MDD's advanced Power Trench technology. This process has been optimized to minimize on-state resistance and yet maintain superior switching performance with best in class soft body diode. 2. Features • Max RDS(on) = 3.6mΩ at VGS = 10 V, ID = 30 A • Extremely Low Reverse Recovery Charge, Qg • 100% UIS Tested • RoHS Compliant 3. Application • Power Management in Telecom.,Industrial Automation • Motor Drives and Uninterruptible Power Supplies • Current Switching in DC/DC&AC/DC(SR) Sub-systems 4. Absolute Maximum Ratings(TA=25°C unless otherwise noted) Parameter Symbol Value Unit Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V ID 100 A Single Pulsed Avalanche Energy (Note 3) EAS 156 mJ Thermal Resistance, steady-state RθJA 32 °C/W PD W TJ 3.9 -55~+150 °C Tstg -55~+150 °C Continuous Drain Current (Note 1) Power Dissipation Junction Temperature Storage Temperature Note: 1)Calculated continuous current based on maximum allowable junction temperature. 2)Repetitive rating, pulse width limited by max. junction temperature. 3)EAS condition:TJ=25°C, VDD=50V, VGS=10V, L= 0.5mH, Rg= 25Ω, IAS=23A. Rev: 2024A0 MDD100N03D 30V N-Channel Enhancement Mode MOSFET 5. Pinning information Pin Symbol Description 1 G Gate 2 3 D S Simplified outline Equivalent Circuit Drain Source Parameter V(BR)DSS Drain-Source Breakdown Voltage IGSS Gate-Source Leakage Current IDSS Drain-Source Leakage Current VGS(TH) Gate Threshold Voltage RDS(ON) Drain-Source On-State Resistance Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate Source Charge Qgd Gate Drain Charge td(on) tr td(off) tf Typ Max Unit 30 — — V — 100 nA Reverse VGS=-20V — — -100 nA VDS =30V, V — — 1 μA VDS=VGS, ID=250μA 1.2 1.5 2.2 V VGS=10V, ID=30A — 2.8 3.6 mΩ VGS=4.5V, ID=20A — 4.0 6.1 mΩ Min Typ Max Unit — 2800 — pF GS=0V Condition VGS=0V VDS =15V f=1MHz VGS=10V VDS=15V ID=30A Condition Turn on Delay Time VGS =10V VDD =15V ID=30A RG=3Ω Turn on Rise Time Turn Off Delay Time Turn Off Fall Time 9. Source Drain Diode Characteristics VSD Min — Parameter Symbol Condition VGS=20V 8. Switching Characteristics Symbol TO-252 Forward Parameter Ciss MDD 100N03D VGS=0V, ID=250μA 7. Dynamic Electrical Characteristics Symbol Package XXY: Date code 6. TA=25°C unless otherwise specified Symbol Marking Parameter Condition — — 366 310 — — pF pF — 60 — nC — 12 — nC — 13 — nC Min Typ Max Unit — 10 — ns — 30 — — 45 ns — 18 — — ns Min Typ Max Unit ns Drain-Source Diode Forward Voltage IS=30A, VGS=0V — 0.8 1.2 V trr Body Diode Reverse Recovery Time — 18 — ns Qrr Body Diode Reverse Recovery Charge IF=30A di/dt=100A/μs — 7 — nC Craftsman-Made Consciention Chip Rev: 2024A0 2/5 www.microdiode.com MDD100N03D 30V N-Channel Enhancement Mode MOSFET 10.Test Circuits And Waveforms Figure 1. Gate charge testcircuit & waveform Figure 2.Switching time testcircuit & waveforms Figure 3.Unclamped inductive switching (UIS)test circuit & waveforms Figure 4. Diode reverse recoverytest circuit& waveforms Craftsman-Made Consciention Chip Rev: 2024A0 3/5 www.microdiode.com MDD100N03D 30V N-Channel Enhancement Mode MOSFET 11.Electrical Characteristics Diagrams 100 20 VGS = 10V 80 VDS = 5V VGS = 4.0V VGS = 4.5V 16 TJ = 125°C 12 ID(A) ID(A) 60 VGS = 3.5V TJ = -55°C 40 8 20 4 TJ = 25°C VGS = 3.0V 0 0 0 1 2 3 4 5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 VGS(V) VDS(V) Figure 1. Typ. output characteristics Figure 2. Typ. transfer characteristics 10 8 7 VDD = 15V ID = 30A 8 6 5 VGS(V) RDS(ON)(mΩ) 6 VGS = 4.5V 4 3 2 VGS = 10V 2 1 0 0 10 20 4 30 40 0 50 0 10 20 30 ID(A) 40 50 60 Qg(nC) Figure 3. On-Resistance vs. Drain Current Figure 4. Gate Charge Characteristics 100 2.2 VGS = 0V VGS = 10V ID = 30A 2 10 Normalized RDS(ON) 1.8 TJ = 125°C 1.6 1.4 1 1.2 TJ = -55°C 1 TJ = 25°C 0.1 0.8 0.6 0.4 -80 -40 0 40 80 120 160 0.01 200 TJ(℃) Junction Temperature 0 0.2 0.4 0.6 0.8 1 1.2 VSD(V) Figure 5. Normalized on Resistance vs. Junction Temperature Craftsman-Made Consciention Chip Rev: 2024A0 Figure 6. Forward characteristic of body diode 4/5 www.microdiode.com MDD100N03D 30V N-Channel Enhancement Mode MOSFET 12. Outline Drawing TO-252 Package Outline Dimensions 13. Important Notice and Disclaimer Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen). Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Shenzhen). Craftsman-Made Consciention Chip Rev: 2024A0 5/5 www.microdiode.com
MDD100N03D 价格&库存
很抱歉,暂时无法提供与“MDD100N03D”相匹配的价格&库存,您可以联系我们找货
MDD100N03D
  • 5+0.93690
  • 50+0.74715
  • 150+0.65232
  • 500+0.58115
  • 2500+0.52424
  • 5000+0.49583
库存:56
MDD100N03D
  • 10+1.76400
  • 200+1.05220
  • 800+0.73660
  • 2500+0.52610
  • 5000+0.49980
  • 25000+0.46300
