MDDG10R04P
100V N-Channel Enhancement Mode MOSFET
1. Description
This N-Channel MV MOSFET is produced using MDD Semiconductor's advanced Power Trench process that
incorporates Shielded Gate technology. This process has been optimized to minimize on-state resistance and yet
maintain superior switching performance with best in class soft body diode.
2. Features
• Max RDS(on) = 4.4 mΩ at VGS = 10 V, ID = 100 A
• Extremely Low Reverse Recovery Charge, Qrr
• 100% UIS Tested
• RoHS Compliant
3. Application
• Synchronous Rectification for ATX / Server / Telecom PSU
• Motor Drives and Uninterruptible Power Supplies
• Micro Solar Inverter
4. Absolute Maximum Ratings(TA=25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
100
V
Gate-Source Voltage
VGS
±20
V
ID
130
A
Pulsed Drain Current (Note 2)
IDM
520
A
Single Pulsed Avalanche Energy (Note 3)
EAS
306
mJ
Thermal Resistance, steady-state
RθJA
75
°C/W
PD
150
W
TJ
-55~+150
°C
Tstg
-55~+150
°C
Continuous Drain Current (Note 1)
Power Dissipation
Junction Temperature
Storage Temperature
Note:
1)Calculated continuous current based on maximum allowable junction temperature.
2)Repetitive rating, pulse width limited by max. junction temperature.
3)EAS condition:TJ=25°C, VDD=50V, VGS=10V, L= 0.5mH, Rg= 25Ω, IAS=35A.
Rev: 2024A0
MDDG10R04P
5. Pinning information
Pin
Symbol
Description
1
G
Gate
2
3
D
S
Simplified outline
Equivalent Circuit
Drain
Source
6. TA=25°C unless otherwise specified
Symbol
Parameter
Marking
Package
MDD
G10R04P
TO-220C-3L
Condition
VGS=0V, ID=250μA
V(BR)DSS
Drain-Source Breakdown Voltage
IGSS
Gate-Source Leakage Current
IDSS
Drain-Source Leakage Current
Gate Threshold Voltage
VDS=VGS, ID=250μA
Drain-Source On-State Resistance
VGS=10V, ID=100A
VGS(TH)
RDS(ON)
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
tr
td(off)
tf
100
V
100
nA
Reverse
VGS=-20V
-100
nA
VDS =100V, VGS=0V
1
μA
2.0
3.0
4.0
3.2
4.4
mΩ
Min
Typ
Max
Unit
5900
pF
950
pF
140
pF
52
nC
19
nC
12
nC
Min
Typ
Max
Unit
25
ns
55
ns
45
ns
16
ns
Min
Typ
Max
Unit
Condition
VGS=0V
VDS =50V
f=1MHz
VGS=10V
VDS=50V
ID=100A
Parameter
Condition
Turn on Delay Time
VGS=10V
VDD =50V
ID=100A
RG=6Ω
Turn on Rise Time
Turn Off Delay Time
Turn Off Fall Time
9. Source Drain Diode Characteristics
Symbol
Unit
8. Switching Characteristics
Symbol
Max
VGS=20V
Parameter
Ciss
Typ
Forward
7. Dynamic Electrical Characteristics
Symbol
Min
Parameter
Condition
V
Drain-Source Diode Forward Voltage
IS=100A, VGS=0V
1.0
trr
Body Diode Reverse Recovery Time
Body Diode Reverse Recovery Charge
ns
Qrr
IF=100A
di/dt=100A/μs
85
V
VSD
Craftsman-Made Consciention Chip
Rev: 2024A0
2/5
100
nC
www.microdiode.com
MDDG10R04P
10.Test Circuits And Waveforms
Figure 1. Gate charge testcircuit & waveform
Figure 2.Switching time testcircuit & waveforms
Figure 3.Unclamped inductive switching (UIS)test circuit & waveforms
Figure 4. Diode reverse recoverytest circuit& waveforms
Rev: 2024A0
3/5
www.microdiode.com
MDDG10R04P
11.Electrical Characteristics Diagrams
400
500
Tj=25℃
VGS= 10V
VDS=5V
7V
150℃
25℃
300
6V
ID-Drain Current (A)
400
300
200
200
100
100
5V
1
3
4
2
Figure 1. Typ. output characteristics
6
8
Figure 2. Typ. transfer characteristics
8
6
5
VGS = 6V
4
VGS = 10V
3
2
1
10
15
RDS(on)-Drain to Source resistance (mΩ)
100
7
RDS(ON)(mΩ)
4
Vgs-Gate to Source Voltage (V)
VDS-Drain to Source Voltage (V)
ID=65A
Tj=25℃
80
60
40
ID(A)
6
7
8
9
10
VGS-Gate to Source Voltage (V)
Figure 4. On-Resistance vs. Gate Voltage
Figure 3. On-Resistance vs. Drain Current
6
5
100
ID=250uA
Is-Reverse Drain Current (A)
VGS(th)-Threshold Voltage
Normalized
5
4
3
2
1
-25
25
75
125
Tj-Junction Temperature (℃)
Figure 5. Normalized Threshold Voltage vs.
Rev: 2024A0
175
150℃
25℃
10
1
0.4
0.5
0.6
0.7
0.8
0.9
1
Vsd- Source to Drain Voltage (V)
Figure 6. Forward characteristic of body diode
4/5
www.microdiode.com
MDDG10R04P
12. Outline Drawing
TO-220C-3L Package Outline Dimensions
13. Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information
and specifications before final design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for
application assistance or customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept
any liability with products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics
(Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Shenzhen).
Rev: 2024A0
5/5
www.microdiode.com
很抱歉,暂时无法提供与“MDDG10R04P”相匹配的价格&库存,您可以联系我们找货
