HBS602 THRU HBS610
Voltage Range - 200 to 1000 Volts
Current - 6.0 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
HBS
Surface mount bridge, small package;
Ideal for printed circuit boards;
Glass passivated chip junction;
High forward current capability up to 6.0A;
High surge current capability;
High heat dissipation capability;
Low profile package;
Low forward voltage drop;
Plastic package has Underwrites Laboratory Flammability
Classification 94V-0;
Mechanical Data
Case : JEDEC HBS Molded plastic body
Mounting Position : Any
High temperature soldering guaranteed: Solder Reflow
260℃,10seconds
Polarity: As marked on body
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=25°C
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per diode at 6A
Maximum DC reverse current
at rated DC blocking voltage
TA=25°C
TA=125°C
Typical capacitance (note1)
Typical thermal resistance
Operating junction and Storage Temperature Range
SYMBOLS
MDD
MDD
MDD
MDD
MDD
HBS602
HBS604
HBS606
HBS608
HBS610
UNITS
VRRM
VRMS
VDC
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
IF(AV)
6.0
A
IFSM
170
A
VF
1.10
V
5
µA
IR
100
CJ
43
RθJA
68
RθJC
10
RθJL
22
Tj,TSTG
-55 to +150
pF
°C/W
°C
Note1: Measured at 1.0MHz and applied reverse voltage of 5.0V DC;
http://www.microdiode.com
Rev:2025A1
Page :1
HBS602 THRU HBS610
Ratings And Characteristic Curves
(TA = 25℃ unless otherwise noted)
FIG.1 Derating Curve Output Rectified Current
FIG.2 Typical Forward Characteristics per Diode
7.0
Instantaneous Forward Current (A)
Average Forward Current (A)
8.0
Heat Sink Mounting
6.0
5.0
4.0
3.0
PCB Mounting
2.0
1.0
0.0
50
150
100
TA=125℃
10
TA=25℃
1
0.1
0.01
0.4
Instantaneous Reverse Current (μA)
Peak Forward Surge Current (A)
140
110
80
50
1.0 Cycle
1
10
Number of Cycles at 60Hz
0.9
1.0
1.1
FIG.4 Typical Reverse Characteristics per Diode
8.3ms single half
sine-wave
0.7
1000
200
170
0.6
Instantaneous Forward Voltage (V)
Case Temperature,Tc (℃)
FIG.3 Maximum Non-Repetitive Peak Forward Surge
Current per Diode
0.5
100
TA=150℃
100
TA=125℃
10
1
TA=25℃
0.1
0.01
60
100
80
Percent of Rated Peak Reverse Voltage (%)
FIG.5 Typical Junction Capacitance per Diode
Junction Capacitance (pF)
1000
100
10
1
0.1
1
3
5
Reverse Voltage (V)
Rev:2025A1
Page :2
HBS602 THRU HBS610
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A1
Page :3
很抱歉,暂时无法提供与“HBS610”相匹配的价格&库存,您可以联系我们找货
