RHBS402 THRU RHBS410
Voltage Range - 200 to 1000 Volts
Current - 4.0 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
HBS
Surface mount bridge, small package;
Ideal for printed circuit boards;
Glass passivated chip junction;
High forward current capability up to 4.0A;
High surge current capability;
High heat dissipation capability;
Low profile package;
Low forward voltage drop;
Plastic package has Underwrites Laboratory Flammability
Classification 94V-0;
Mechanical Data
Case : JEDEC HBS Molded plastic body
Mounting Position : Any
High temperature soldering guaranteed: Solder Reflow
260℃,10seconds
Polarity: As marked on body
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=25°C
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage
drop per diode at 4A
Maximum DC reverse current
at rated DC blocking voltage
TA=25°C
TA=125°C
Maxumum reverse recovery time(1)
Typical thermal resistance
Operating junction and Storage Temperature Range
Rating for fusing (t
很抱歉,暂时无法提供与“RHBS410”相匹配的价格&库存,您可以联系我们找货
